Question about HP (DVD740RI) DVD RW Dual Layer Burner
Have multiple burners and neither are recognizing media anymore
Here goes... I have two burners installed on my pc: HP dvd740i and Pioneer DVD-RW DVR-106D Up until about 3 to 4 months ago these two burners worked flawlessly! And then almost at the exact same time - both burners now are no longer recognizing any type of blank media and often not even cd's or dvd's! I have tried asking both HP and Pioneer and many other various sites about this problem, but always seem to get the same response: "Try a different media" or "Install the current drivers" or "Make sure the cables are connected firmly." Let me save you a lot of time here: (1) I know for a fact it is not the media!!!!! (2) All connections are securely attached and correct!!! (3) I have downloaded and installed current drivers for both burners (4) I have disconnected and attempted reinstallations on both burners (5) I have uninstalled every burning application (Nero, Roxio, etc) and reinstalled only one - Nero. I don't mean to sound like I don't appreciate them for trying to help, but I am very desperately upset other this and really need some other options here!! Recently I have read on other sites about a copy-protection software called "StarForce" which is installed via different PC games!!!!!! I checked my system and sure enough this StarForce was on my PC and I immediately removed it; however, according to http://www.glop.org/starforce/remove.php removing it doesn't repair whatever damage it does to your burners!!!!!!! PLEASE HELP!!!!!!!!!!!!!! I am quite desperate and would appreciate anyone out there who can recommend something to get these burners going!! As I said, I can sometimes finally get them to recognize a blank media and even (by some miracle) get them to burn one, but as far as the Dual Layer burner is concerned - It no longer will burn a dual layer at all!!!! I can't afford to buy another one and feel pretty sure there has got to be something that can be done to fix this one!!!! I leave this into your expert hands and please help me!!! Very Sincerely, Chris Hopkins
    Genius:
  • 2,985 Answers
Your plea sounds as if the Burners work pretty hard. It seems to me that you have laser burnout. There is as far I know noway to check this You will simply have go get a new one by hook or by crook. You could peruse this list to see if anything turns up. http://www.fixya.com/support/p489676-hp_dvd740ri_dvd_rw_dual_layer_burner
Posted on May 18, 2007
SOURCE:
My HP DVD 740 won't recognize blank CDs
Sounds like the lens is dirty. Run a cd cleaner through the drive. That should take care of it.
Dec 15, 2009 | HP dvd740i DVD±RW Dual Layer Burner
Hp dvd740 not recognize hp dvd-r
Check in device manager if the cd/dvd drive is detected. Uninstall and Reinstall.
Go and Delete upper and Lower Filters in the registry
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318} and Restart the Computer. Should Work
Regards
Naveen
Oct 11, 2009 | HP dvd740i DVD±RW Dual Layer Burner
Dvd 740 media problem
jovanis114 --
If your drive was able to recognize a disk before, but now has stopped... POSSIBLE solution... (don't shoot the messenger on this one, lol!)
I'm sure you have tried, but have you cleaned your optics lately?
Using a Q-tip and a small amount of rubbing alcohol, and GENTLY rotate the swab across the lens, rotating it in the opposite direction you are wiping. This should "lift" any dust or grime from the lens. I would also clean the tray with a soft lint-free cloth (using an air-can just moves the dirt around, doesn't solve the problem)
Hope this helps!
-- RT
PS - Don't forget to vote!
Sep 09, 2009 | HP dvd740i DVD±RW Dual Layer Burner
HP dvd740b does not detect blank CDs and DVDs
i think you,ve hit the nail-on-the-head.
The laser has to power up highrer to write a DVD, or ocassionally have a dual laser. 1 for read/write CD. And 1 For Read/Write DVD.
Certain cd roms, only use CD- media. it,s probably worth checking which media is supported by the drive.
Also check the drives aren,t conflicting, on the same ide channel, sometimes swapping channels, ide primary/secondary can help, or swiitching Master/Slave/cable select jumpers on the drives Themselves.
Mike @ Compurepair.
Sep 04, 2009 | HP dvd740i DVD±RW Dual Layer Burner
Windows won't recognize dvd writer
email me and i will send the driver in an attachment file.please not though that the hp 740i burner is an internal I D E supported drive not a USB. as long as its a 740 model the driver should work, wether its usb or ide is up to the computer to associate it with.
billfox1966@yahoo.com
Jul 19, 2009 | HP dvd740i DVD±RW Dual Layer Burner
My computer wont reconnize dvd r verbatim disks for burning wont can i do to solve this problem
Don't use verbatim brand, some model are brand specific, some problems are due to write capability of both media and burner.
Or check at manufacturer's site for any support of updating your burner media brand support.
If you want, try to experiment which media are good on your unit.
Jun 03, 2009 | HP dvd740i DVD±RW Dual Layer Burner
DVD RW DVR-K16 does not recognize blank DVD-R
I have a Pioneer DVDRW DVR-K16, in a sony dv81114Notebook. Running Windows XP. It cannot play dvd's and cd's, It will recognize blank CD-R's but when I insert a DVD-R it say's no disc installed. I have firmware version 1.15.
Nov 26, 2008 | Pioneer (DVR-K16) DVD RW Dual Layer Burner
Hd dvd 740with light scrib
Disk's can also fail...but not all...else you have a problem with the drive...you try cleaning the lens...
PLEASE don't forget to RATE ME (FIXYA) for my help..........
Aug 15, 2008 | HP dvd740i DVD±RW Dual Layer Burner
Wrong DVD/CD drive type
Did the Pioneer come with its own drivers if so then install those if not search google.com for the correct drivers youll find it will recognize the dvd?.
Aug 16, 2007 | Pioneer DVR-111D (DVR111DBK) DVD RW Dual...
HP (DVD740RI) DVD RW Dual Layer Burner Logo
95 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
