Question about Magnadyne Backup Monitoring System
I hit the brake and now my magnadyne remote start shut down my car
My car won't start with the key but it will start with the remote start and when its started with the remote and turn the key when I hit the brake it shuts off
The shutting off is standard procedure for the remote start if the brake is pressed without the key being in the on position. That said, it seems you may have an issue with the ignition switch. When you turn the key to the ON position, do all the warning lights on the dash come on like they are supposed to, or does it just sit there? If the lights do not come on, then you need to check out the ignition switch circuitry. The remote start bypasses all that when in use, but in order to drive the car once started, the ignition switch must function properly.
Oct 30, 2015 | Cars & Trucks
Need wiring diagram pin out for a magnadyne
not sure what model magnadyne ,follow this link for more info and manual download
Download Magnadyne M9900CDS Installation And Operations Manual
May 14, 2014 | 2010 Toyota Land Cruiser
I have a viper alarm on my 94 caprice it was on the car when I bought it it was working fine but now will start with the remote but not the key and now after I put the key in once I hit the brake where the...
hi
you will have to get a wiring diagram of the alarm and check the wires are still working and connected to the right parts
it sounds like the wire to confirm the key is turned on so you can drive off is disconnected
but you will need to check this via the alarm diagram
aires
Sep 26, 2013 | Vehicle Parts & Accessories
How to resolve service light staying on problem
Apparently, there is something that is not receiving power. What is the year, make and model of the vehicle?
Jun 23, 2013 | Viper SmartStart Module
Car shut down when foot not on the accelerator
For this types of problem,there are few help links.I suggest you to click the link below and go through the troubleshooting procedure :-----Car only starts when gas pedal is pressed? http://technoanswers.blogspot.com/2012/01/car-only-starts-when-gas-pedal-is.html-----------Car won't start without hitting the gas pedal? http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-without-hitting-gas.html
----------Complete loss of brake pedal then all gets normal? http://repairhelpcenter.blogspot.com/2012/01/complete-loss-of-brake-pedal-then-all.html
----------Car dies when gas pedal is pressed? http://schematicsdiagram.blogspot.com/2011/12/car-dies-when-gas-pedal-is-pressed.html
--------------Pushing on the gas pedal, but the car slows down? Gas pedal to the floor and the car slows down? http://technoanswers.blogspot.in/2012/02/pushing-on-gas-pedal-but-car-slows-down.html
-------------Idles rough and quits when gas pedal is pressed less? http://technoanswers.blogspot.in/2012/01/1999-ford-f-150-idles-rough-and-quits.html----------This will help.Thanks.
Feb 02, 2012 | 2002 Toyota Camry
I have a 2001 Chev Cavlier Z24, rpn 479V/P/C. The car will start with the remote start but as soon as you push the brake the car will shut down. I have the key in the ignition and have turned it over. Its...
The remote starter shuts down when you step on the brake?!? That's exactly what it's supposed to do. To operate a proper "takeover" from the remote starter the key must be turned to ignition on, not accessory.
Jun 15, 2011 | Directed Electronics 479V Remote Gen 2...
Mts mode for preset manual trans auto start function enable,does not allow car to start, instead the park light blinks seven times and give an error tone ... Thank you
There is a sequence necessary to set the Viper every time you exit the vehicle: park the vehicle, put in neutral, place foot on brake, set parking brake,remove foot from brake, remote start vehicle with remote, remove key (vehicle should remain running), exit vehicle and close door, arm the alarm with remote (vehicle should shut down). The system is now set for MTS remote start. Test the system by remote starting the vehicle now (it should remote start at this point). If you open any door after the MTS remote start has been set, you will have to do the programming sequence again.This is a safety feature because something may have changed, i.e. parking brake released when the door was opened. You have to do this sequence each time you park the vehicle if you intend to use the remote start feature.
If this does not work, there may be an issue with the installation, i.e., the door trigger connection. Using dome supervision as a door trigger won't work because during the arming portion of the above mention programming sequence(when the vehicle shuts down), the interior lights will illuminate and the Viper will read it as a door opening. So, actual door trigger wires must be used.
Oct 23, 2010 | 5900 SST 2-Way Security System / Remote...
Key will not shut vehicle off after staring with viper starter
The brake is what shuts it off. To keep the car on You first put key in to IGN position then hit the brake. If you hit brake first then the remote start shuts off
Nov 24, 2009 | Remote Start System
The vehicle starts with the remote but not with the key.It won't turn over.It shuts off when the brake is pushed.
It sounds like the ignition switch is shot. Part of the security of a remote start system is that, unless the key is in and turned, it'll shut down if the brake is pressed (since the brake has to be pressed to put it in gear to drive). If you put the key in, turn it, and hit the brake, and the car stops, or if you turn the key and it doesn't start, it means the ignition switch (the electronic portion, not the barrel where you stick the key - the electronics are on the backside of the barrel) is not recognizing that the key is in. I'd replace the ignition switch and try again. It's not a keyed part - you can go to a salvage yard and get one to install. You'll have to remove the trim for your steering column and then you'll see the switch on the back of the key cylinder. Should be a couple screws that mount it and a harness that plugs into it, and it'll come right off.
Nov 08, 2009 | Crimestopper RS1505DP CoolStart(TM) FM/FM...
Vehicle shuts off after remote start
I will need to know the make and model of your car to answear this possitively but this sounds like a problem with your bypass module. That is if your car has a immobility system. an easy way to check this is stick your key in the ignition "Do not turn the key" just insert it in the ignition then hit the remote start. if the car does not shut down that is where your problem lies. if the car still shuts down then your problem is due to either a bad brain or faulty wiring.
Hope that helps,
Luis
Nov 25, 2008 | Car XR9000 Two-Way Confirming Remote Start...
Magnadyne Backup Monitoring System Logo
91 people viewed this question
Top Magnadyne Home Security Experts
Lawrence Oravetz
Are you a Magnadyne Home Security Expert? Answer questions, earn points and help others
