Question about Kenwood KSC-310CCS Center Channel Speaker Car Speaker
Display is out
KDC-MP632U is the unit I have I was listening to the radio today and notcied the whole display was no longer lit no clck channel nothing. Any ideas for troubleshooting the problem would be great?
    Problem Solver:
  • 10 Answers
Is it detachable face?? do you detach it a lot? it could be the connection between the faceplate and the stereo. gently push against the faceplate and see if it flashes back on?? BE GENTLE!!! maybe a slight wiggle while you push. if it flashes on at all you should try to have it serviced or replace it altogether. Good luck.
Posted on Oct 10, 2009
Hello I have the KDC MP632U and I need help on how to turn the aux on since my display faceplate does not work
well you can actually get your display working again in under 15 minutes with a soldering iron.(i know not exactly what you asked, but a more effective solution if you still have this stereo). take the deck out, remove the three screws holding the metal casing on. carefully move the cd player back an inch or two (make sure you don't pull out the ribbon cable for the cd by accident or unclip it if you know how) on the right side of the board you will see a 'chain' of resistors/ little black rectangles with R27 on them. resolder the ends of each one, either just remelt the solder that is there, or get the very fine electronics solder and add a bit on each spot. i am a lady and i did this today in about 15 minutes, and now my display works, so it is not too hard. i did get my hubby to remove the deck from the truck for me though :-)
Jul 18, 2012 | Kenwood KDC-MP632U
Kenwood kdc-mp632u display is blank
Possible that the display is faulty or there is a fault in the power line. Also check if the strip that connects to the display is faulty. If the unit works perfectly except for the display then the fault is only with the panel and a voltage check on the panel will confirm the loss .Use a multimeter to test the voltage and also check on the tracks for continuity.
Sep 28, 2011 | Car Audio & Video
My faceplate does not show display on my Kenwood kdc-mp632u. The lights work and the head unit in general plays the radio and cd's ect. now I have read somewhere that there are resistors inside so that...
I had the same problem and I resoldered the resistors on the board inside the stereo and it worked. Unscrew and remove the top cover and the CD slot. There are 10 of them located on the lower right side of the board. Good luck.
Jun 12, 2010 | Kenwood KDC-MP632U
My display is out. unit works otherwise
you probably have bad solder connections on some surface mount resistors inside the radio itself.
Aug 19, 2009 | Kenwood KDC-MP632U
Set clock
press source and go to stby press and hold the menu button till menu appears using the change station button select clock press and hold the change station button in till clck adj appears then press the source button then to have clock appear go to cd or radio and then press and hold the change station button in for clock to display
Mar 29, 2009 | Kenwood KDC-135 CD Player
I have a kdc mp632u and i cant get any sound out of my subwoofers. The amp comes on and there is power to the amp but still no sound. can someone tell step by step what i have to do to get it to work with...
First, make sure that the RCA's from the HU to your amp are properly connected, and fully seated on both ends. There are 2 sets of outputs. You should be using the ones on the left as you face the rear of the HU. Here is a link to the manual. Page 40 shows the connections on the back:
http://inform3.kenwoodusa.com/manuals/KDCX590.pdf
After making sure that everything is connected OK, check to see if you have the subwoofer output turned on your MP632U.
To do this, push the control knob on the right toward AM (toward the bottom). Subwoofer output switches off/on each time you push it. When it is on, the display reads "SW ON".
If this does not solve the problem, you most likely have a defect in either the HU or the amp.
Hope this helps! If it does, please rate as "FixYa." Thanks!
Mar 28, 2009 | Kenwood KDC-MP632U
Display is OUT but everything functions....... what to do?
I just followed tech48's solution by resoldering the resistors on the main board.
Dec 29, 2008 | Kenwood KDC-MP632U
No display and trying to find resistors.
SYMPTOM: No Display.
COUNTERMEASURE: Re-solder the following components on PCB X34-415:
R43, R44, R46, R47, R48, R49, R50, R51, R55, and R57
They all say 2r7 on them
Jul 27, 2008 | Kenwood KDC-X590 CD Player
Kenwood KDC-MP632U display not working can I pull a dispay from another model? Any sugestions on how to fix? Thanks, Phil
Are a face detachable or the conector to the main board are a flat connector,because if are connected with a flat connector thats the problem
Apr 13, 2008 | Car Audio & Video
IPOD hookup for kdc-mp632u not working
Make sure your aux is turned on, and that should be the "source" that you use when playing your ipod.
Feb 08, 2008 | Kenwood KDC-MP632U
Car Audio & Video Logo
179 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
