Question about IBM NetVista A30 6824-xxx 256MB DDR PC-2100 Desktop Memory
Ive formatted IBM 6824 harddisk but startup no display
The hard disk i've formatted using another PC and put in back to IBM 6824.when startup no display at all and i can't go to CMOS setup also.
  • joecoolvette
    joecoolvette Oct 27, 2012
    You just wiped the harddrive clean when you Formatted. Should have put the harddrive in the IBM, and the Windows disk. Take the harddrive out, and see if you can get to BIOS Setup.
    New Friend:
    Problem Solver:
  • 11 Answers
The operating system is no more.
Posted on Nov 12, 2013
2 Suggested Answers
SOURCE: IBM Netvista 6059 - Can't upgrade to windows XP
Right well XP Pro really MUST be formatted with NTFS only... I suggest you get a third party partitioning program like Partition magic and completely remove the partition & redo it all again & this time Format NTFS. Or if ya have a WIN98 boot disk, and ya can use FDISK, Delete ALL partitions, and remake them again, using all the disk space, then format as NTFS, then proceed as below Then using your windows XP PRO setup Disk, start the install ...then when asked about where you want the install located, select C & REFORMAT it AGAIN with the windows setup using again NTFS file system... this should finish & then the Install should "see" your entire hard drive and format it accordingly and then when finished you can proceede to install XP.
Posted on Sep 04, 2007
Harddisk not showing on pc
is the disk backup or in the pc internal hard-disk if external no need software download just get another pc or use recovery software to get your data from it and then format and re backup your data
Jun 27, 2017 | Buffalo Technology DriveStation HD-HC500U2...
Recover data from wd 500 gb which is not working
You should use easy data recover software because this software support "raw" type of bad drive file system .
visit here
Apr 04, 2013 | Computers & Internet
I just got the HITACHI SimpleDrive 1TB USB 2.0 External Hard Drive HSD1000 recently and downloaded some files from a mac on to it, now I'm trying to access the information from it from a Windows &...
The external hard disk must be formated in a file system that both the pc and the mac can use - best is FAT32. In your case the file system that the mac put on the disk is incompatible with the pc.
Make sure the files you want to move are still on the mac (if not copy them back from the disk), plug the disk in the pc and format it there in FAT32 (don't use the quick option), plug it in the mac and copy the files and unmount the disk before disconnecting it from the USB connector. Now you can put it in the pc - in there always use the Safely disconnect icon, don't just yank out the cable.
Aug 15, 2011 | SimpleTech 1TB HITACHI SIMPLEDRIVE IIUSB...
My seagate st3250820a has been setup in old pc in dos fat32 mode using device driver and running ok before..now i put my harddisk into new pc has detected 137 mb..can you pls to inform how i fix it to 250...
Please format the disk. You will get the disk space back. If your new pc is running windows NT, 2000, XP, or Vista, while formatting keep the file system NTFS.
Dec 13, 2010 | Seagate Computers & Internet
Need a boot disk form my ibm 2647 is there link to go to and copy to disk?
Place an empty floppy in the drive. Double click on My Computer and find the floppy drive. Right hand mouse click and select Format. When the Format menu is displayed, select Make System Disc from the list.
That will format your floppy and include the operation system startup files.
Hope that helps.
Nov 08, 2010 | IBM ThinkPad T20 2647 Notebook
I have an IBM ThinkPad 2861that displays "operating system not found" during start up. I downloaded a user manual that wasn't much help in solving the problem. Any advice?
message means there is no working operating system(OS) installed on the harddisk, like windows XP,vista or a lunix version. if you have a working cd-rom, i use a win 98 install cd that boots from startup then install win98 to find out if there are any hardware issues. if the invalid OS was a version that used the NTFS file system the drive will have to be re-formatted/erased to install win98. if you have a bootable cd-rom version of the OS you use or if the factory IBM restore partition is intact you can use them. they may not save any data you have on the drive. if you have data you need to retrive from the disk drive it is a different procedure.
Oct 09, 2010 | IBM ThinkPad R40 2681
IBM Netvista desktop bios problem
this is more like a workaround that I used on a laptop which cd room drive just failed (and which I did not want to replaced as it was more expensive than the whole laptop)
If you can't select the device you want to boot from.. you may want to partition your hdd and format it so it loads a dos operating sytem .. use another machine and a win98 startup disk to do this then copy your I386 folder from your winxp cd into the new formatted hdd so when you put the hdd back into the IBM machine it loads dos and then going into the I386 folder you can run a winnt command for you to install the os.
Jul 31, 2008 | IBM NetVista PC Desktop
Hard drive failure on IBM T43
I have a ThinkPad T43,
Now it's hard drive is broken so when i change the new hard drive Hitachi 160GB it display the message as below.
Could you help me to terminate this error message.
2010: Warning: Your internal hard disk drive (HDD) may not function correctly on this system. Ensure that your HDD is supported on this system and that the latest HDD firmware is installed. Press <Esc> to continue
I try to update firmware of the harddrive but still appear the message the same.
Apr 23, 2008 | IBM ThinkPad T43 Notebook
Sep 04, 2007 | IBM NetVista PC Desktop
IBM NetVista A30 6824-xxx 256MB DDR PC-2100 Desktop Memory Logo
42 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
