Question about Kenwood KDW243A Builtin Dishwasher
Kenwood KDW243A - It blew the circuit breaker.
I switched it back on, the machine switches on, the programme choice lights all light up then go out as normal, but it won't select the programme, no lights show. also the 1/2 load does not work. thanks
  • alan tunniclife Oct 26, 2012
    thanks, but it does not show an error, it stopped half way through a programme, blew the RCD and when I reset it, the machine switches on but it won't let me select a programme
Hi it probably the heater element had a similar problem on ours.
Posted on Oct 30, 2012
  • alan tunniclife Oct 30, 2012
    Thanks - yes it was the element.
4 Suggested Answers
  • 16 Answers
SOURCE: wont go on to programme when switched on starts
Check that you have tuned on the inlet water tap(faucet usa).
Posted on Jan 24, 2010
  • 4 Answers
SOURCE: SHOWING E3 ON DISHWASHER
Had the same problem (apart from the code) and the answer is to stop putting plastic in the machine ! It seems the dishwashers need the heat radiated from the Ceramic plates, stell knives etc to help dry. The plastic simply absorbs some water and then your dishwahser spends most of its drying time trying to get that water out again. Also Plastic doesn't radiate any heat to help. As soon as we stopped putting plastic plates and tupperware containers in, hey presto the dishes are drying again
Posted on Apr 13, 2010
  • 246 Answers
SOURCE: My kenwood dishwasher kdw60x10 had a small leak and now although it switches on I can not programme it to start
sounds like water got into the electronics of it..
Posted on Jun 09, 2012
How to reset electric box after vacuum cleaner blew power out
One of your circuit breakers is tripped internally and didn't trip the handle. You'll need a voltmeter to find the defective breaker and replace it.
Aug 22, 2014 | Electrical Supplies
The red indicator light for the intermatic light timer EJ351 does not even go on - what can I do?
Hello Barb.
EJ351 timer indicator light problem:
Reset timer and try again.
This timer is rated for incandescent lighting only, 500 watt max, 40 watt minimum, and timer has two wires.
When replacing switch, either wire can connect to timer wires.
Check circuit breaker: click breaker all the way off, and then back on.
Use non-contact voltage tester to see if wires are live at timer.
If the timer does not work, then it has 1 year limited warranty for defects in workmanship.
Copy following link for EJ351 timer manual with instructions for resetting timer.
http://waterheatertimer.org/pdf/Intermatic-ej351c.pdf
Jul 18, 2012 | Intermatic Programmable 24 Wall Switch...
A light circuit doesn't work (no lights on) with good bulbs. Circuit has 4 switches, no outlets. The breaker does not trip (swapped breaker, no change). At each switch ,115 VAC across switch terminals,...
If I understand correctly you have a circuit with 4 light switches.
None of the 4 switches work, yet all 4 test for 115Vac.
Test each screw on switch to bare ground to get reading.
This problem could be loose neutral wire inside the switch boxes or anywhere along the line, or inside breaker box. Check white wires.
All 4 switches connect back to breaker box on white neutral wire that connects to neutral busbar inside breaker box.
http://waterheatertimer.org/240-v-water-heater-circuit.html#120-240
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 10, 2011 | Cooper Wiring Devices COOPER WIRING SINGLE...
How do I wire the timer in a 3-way switch?
Woods 59013 59017 59018 59720 59028 etc wall timers are not made for 3-way application. They replace a simple on-off switch.
Atube T1032-3W programmable timer shows it can replace 3-way switch.
See manual
Smarthome
Intermatic ST01C & EJ500 programmable times can replace 3-way switch. Look at diagrams carefully. Circuit is limited to 100' distance because of battery.
See wiring diagram
Aplus
Lutron makes several 3-way countdown timers that turn on light for certain length of time and then turn off light
Tip for 3-way switch replacement: Mark wire that connects to dark-colored screw. This is called the 'common' wire.
Depending on location of switch, the 'common' wire either goes to Load (lights) or it comes from breaker box as Hot wire.
Oct 02, 2010 | Woods Hardware & Accessories
My Kenwood KDW243A built in dishwasher is desplaying what I assume is an error code, E3. What does this mean? The washer is not washing properly.
E3 means the base is full of water. A quick fix is to tilt the machine back for 10 mins or so but you need to find the cause of the leak and repair it
Jun 03, 2010 | Kenwood KDW243A Builtin Dishwasher
Opened breaker to change light switch.closed breaker numerous times before it engaged.
When you relaced the light switch, did you use the "quick stab" holes on the back or the side screws? The arc fault breakers can trip if using the quick stab holes on the back because they may not make a tight contact. This could be represented if the circuit breaker trips when the light switch is turned from "off" to "on". Try connecting using the screws on the side of the device instead.
Jan 18, 2010 | Siemens 20Amp 1-pole arc-fault circuit...
One of our lights blew and the main trip switch is now stuck on
those stips are just on there by pressure its is easy to change them but if you never done it call some one
Oct 26, 2009 | Electrical Supplies
Dish washer is not working
Hi kssami9,
I'm Harvey the Master Plumber.
Your problem is: Your dish washer kenwood model kdw243a is not working and displaying the error code E3 please give you the solution.
First try to reset the d/w. Just turn it off at the circuit breaker for ten minutes.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 27, 2008 | EuroTech Dishwashers
Kenwood KDW243A Builtin Dishwasher Logo
254 people viewed this question
Top Kenwood Dishwashers Experts
Oloyede Monsuru
Owen Barnes
Are you a Kenwood Dishwasher Expert? Answer questions, earn points and help others
