Question about Roper RAS6233KQ Top Load Washer
Roper washing machine- unbalanced spin - rocking agitator
Roper washing machine has an unbalanced spin which sounds like the tub is hitting along the insides of the washer. I normally stop it in the spin and rearrange the clothes but that doesn't work either. I want to take off the front washing machine panel to see if there is a hook broken on the tub causing the unbalanced spin sounds but can't figure out how to do that. On my previous washing machine (Sears brand) you could put a wedge between the top panel and the front panel of the washing machine and flip down the front panel. That doesn't work on this model. So my question is how do I get the front panel of the washing machine off to expose the tub to see if there is anything broken or unattached from the tub causing the unbalancing in the spin cycle. Thank for any helpful ideas.
  • Anonymous Apr 07, 2009
    On spin cycle the washer bounces around the walls of the inside , makes a loud banging noise...
  • 148 Answers
I usually stand in front of the washer and take the plams of my hands and forcefully provide a force with the heel of my hands on the side front corners and the lip comes up
Another option is to pull the washer out and remove 2 clips (usually requires quarter inch nut driver to allow the top to come up
This should allow you to get the top off to see if a spring has broken or slipped off
Posted on Jan 04, 2009
My washer makes a lot of noise while on the spin cycle
If the washload is not distributed evenly around the agitator when the final spin cycle starts, the tub will be unbalanced and will wobble and thump loudly. This is especially true if you are washing something heavy such as a rug or jeans. You may have to distribute the load more than once to get results.
Sep 04, 2012 | Roper Washing Machines
My GE WHDRR418GWW was spinning and started making a loud unbalanced sound, stopped and now I cannot restart it.
Here is a common one. The coupler has worn and the agitator may also need to be replaced. Grab a belt and slide it under the agitator. Then pull the agitator out making sure it does not pop up and hit you in the face. Once the agitator is out check the coupler 310 and the base of the agitator. It's very likely they are worn and need replacing.
Some models don't have agitator, then, the problem in this case is going to be the tub bearing. Click HERE to order the part, this will not be an easy repair since you will need to take the top off and remove the inner and outer drum.
Hope helps.
Jan 07, 2012 | GE 3.5 cu. ft. King Size Capacity Top Load...
The agitator in my washing machine is trying and notting all of the clothes up, resulting in the machine becoming unbalanced. I have taken the lid off and wached what happens and the agitator only seems to...
Is this a GE Washing Machine? This sounds like one, it sounds like the shifter coil has failed, this it's not locking to engage the agitator. So it's basically stuck in spin mode, this way, even though the tub does not turn.
Mar 12, 2011 | Washing Machines
Maytag Neptune tl- about 6 years old. Wont finish out the final spin cycle on any setting and also sounds like tub/drum is hitting against side of machine. It also rocks like crazy. Shows the code for...
You have a Clutch malfunction common problem with the FAV6800A and FAV9800A TL's. Owners very seldom report all the conditions of wild tub swings. You are on the ball with info feedback.
See if this post Clutch Fix will get you started.
Post back if you have questions or need help.........Rich
Jul 17, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Rooper washing machine- unbalanced spin - rocking agitator
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
Jan 03, 2009 | Roper RAS6233KQ Top Load Washer
Roper washing machine-unbalanced spin always-how to remove panel
tilt it back to see all the mechanics of it. and make sure that the machine is level in both directions. this site may help you with what parts look like enter model number and scroll down to the red 100 and it brings up even more parts for your model. Good Luck
Jan 03, 2009 | Roper RAS8445KQ Top Load Washer
Roper(whirlpool) washer will not spin model # ras7133kq1
check the motor coupler between the motor and the transmission
Mar 17, 2008 | Roper RAS8445KQ Top Load Washer
check the tub casting under the agitator or it the gearcase
Mar 17, 2008 | Roper RAX4233PQ Top Load Washer
Washer fills and spins but does not agitate
Im sorry to say, it sounds like the transmission in the washer may have gone out, the unit it self sits at the bottem of the main agitator shaft under the the tub, you may be able to have this replaced, but shop around for the right price.
Jan 26, 2008 | Washing Machines
Roper RAS6233KQ Top Load Washer Logo
859 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
