When I turn on the tv it makes a noise and in one minute the screen is black, and two red lights comes out. Is there anything I can do myself?
  • 4 Answers
Unfortunately you have to call repairman since your tv electricity sircuit was burned. Nothing major just the circuit which limits the amount of eletricity goes into your tv
Posted on Oct 26, 2012
SOURCE: power light comes on, but no sound or picture
I had the same problem and my tv was out of warranty. I took it to a local repair shop and they told me didn't work on that brand. They said they charge $300 minimum for labor, plus parts. So probably at least $500 to fix. Since I figured we had nothing to lose my buddy and I took it to our shop at work and decided to take it apart and look for any obvious problems such as blown fuses, burned components, etc. All of the printed circuit boards are connected to what appears to be similar to a motherboard via data1.gif ribbons. We disconnected the data ribbon of each PCB to the microprocessor PCB and turned on the TV. Each time it turned back off after about 3 seconds. When we disconnected the Y-Main PCB the TV stayed on and I got the sound back, but no picture. We then disconnected the buffer PCB's from the Y-Main to ensure they were not the problem. Finally, we pulled the fuse on the Y-Main PCB and reconnected the data ribbon and the TV and sound stayed on again. I found a site that sells the Y-Main for $179 and I am deciding whether to try it or not. Any suggestions or comments would be helpful.
Posted on Jan 25, 2008
mistersony
  • 320 Answers
SOURCE: 42 in SONY LCD flat screen has red light blinking and won't turn on
Does the red light blink in a discernible pattern? How many times does it flash or blink?
Posted on Oct 19, 2008
  • 718 Answers
SOURCE: TV was playing, then the screen turned black.
If the screen is black and you have sound then lightly press and shine a strong flashlight against the screen. If you see an image around the edge of the flashlight, an image is being 'displayed'. The problem is probably in the Inverter/CCFT or the power going to the Inverter.
Posted on Feb 24, 2009
welcomejee
  • 10594 Answers
SOURCE: Sony KDL-46V3000 Bravia LCD Black screen
Please count Sony KDL-46V3000 standby light blinks as there would be interval of 3 seconds between blinks. Let me know how many times light blinks as its an error code.
Posted on May 17, 2009
SOURCE: Green noise on all black images on my SAMSUNG LN LCD TV screen
I had a similar problem with my LG plasma. I used the Image Sticking Minimization
(Pixel Orbitor, White Wash, and Inversion) feature which is designed to prevent image burn in and ghosting. This ISM feature may be available on the Samsung or any other brand under a different name. I activated the "white wash" option for about 30 mins, the screen turns white and somehow the pixels get reset. The green noise disappeared after that.
I hope this helps. Phezbuster
Posted on Jul 05, 2009
Older-model Toshiba TV shuts off by itself
There is a large sand filled resistor on the main board close to where the power cord attaches that cracks. This will stop power until it cools enough to make the connection then heats up rapidly to open it again. It may be worth the trouble if you're handy with a soldering gun and can get the back off the TV. If not then I'd consider getting a flat screen.
Aug 21, 2014 | Televison & Video
Why does my Samsung LED TV have sound but no picture?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
Apr 30, 2014 | Samsung Televison & Video
My sony wega KDP57WS655 tv wont turn on...makes noise like it is coming on, clicks then turns back off and standby light is flashing
If the red light is blinking in front that sasy lamp. Your lamp needs to be replaced. They cost about $100.00 at your TV Fix It shop. Very easy to replace yourself
Nov 20, 2012 | Sony Grand WEGA KDP-57WS655 57" Rear...
Screen went dark
Ur video ic inverter board is dead.
U need a new one.
Aug 25, 2009 | Televison & Video
Sony bravia
what model of Sony is it? On many of the Sony projectors, a 3 flash error code indicates the lamp is not properly seated/installed or the lamp door is not closed properly
May 15, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Red light stays on
First before a reset the set must turn on, if the set just sits there with the red LED on you have further problems, so does the set display anything?
Oct 08, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Electro Med Services...
