Question about Homelite Consumer Products Backpack Blower/Vac, Carb
Homelite 2 cycle backpack leafblower won't run.
The only way to start unit is to spray starting fluid into carb., then full choke. Unit will start but will only run at idle and only if I keep spraying starter fluid. Had this problem prior to rebuilding the carb. No change after the carb rebuild. Another clue; the carb primer bulb only gets approximately 1/3 full after being pumped. Engine has good compression and a new plug. Other engines run on this gas mixture. Your suggestions would be much appreciated.
Thanks, Joe...
  • leaferickson Jan 08, 2009
    Same exact problem.
    almost feels like it is starving for gas.
    If I move the gas line around, it has a impact on the response.
    I am wondering if the gas line is impinged
    All filters clean
    New Friend:
Two cycle engines have a habit of vibrating enough to cause bolts to come loose. You could have a leaky head gasket or crank cover gasket and still be getting excellent compression at the spark plug. If there are leaks then the piston won't be able to create enough suction on the up stroke to pull the gas/oil mixture from the carb at low rpms.
Posted on May 09, 2013
Sounds like the exhaust port is clogged with carbon/oil buildup. My three yr old Craftsman Blower/Vac did the same thing and all I could think of was the carburetor or fuel lines were clogged. But after replacing the fuel lines and air blowing out the carburetor it wouldn't start and then when it did start it only idled. A friend suggested I take off the muffler and cylinder head. Clean out all the old carbon and oil buildup from the exhaust port. It was so clogged up that maybe a bb could have only passed thru. Once I removed all the carbon, put it back together, it fired right up, idled like it was brand new and went to full speed with no problems
Posted on Oct 01, 2011
  • 398 Answers
Yea check the gas lines and throttle cables for strech, probably need replacing or tightening.
Posted on Mar 02, 2009
I need a gastank for my homelite-backpack leafblower, model#uto8580a.It leakes around the screw that holds it own. This is the second time i've had to replace it. There must be a defect in these.
There is a recall for leaking fuel tanks on your unit.
The Homelite #UT08580/UT08580A Backpack blower service recall and all related questions and issues, are being handled through the Homelite customer service phone staff at 1-800-242-4672, for records purposes.
Aug 22, 2011 | Homelite Consumer Products Backpack...
MY homelite BP-240 backpack blower will not run with out the assist of starting fluid. First I tried to start it with just pushing the gas primer bulb. after no success I just sprayed start fluid . It will...
dont spray starting fluid in there to start it has to have a gas oil mix for the piston to have lubrication it will scar or burn the piston and cylinder wall check the fuel lines to see if they need replaced and the fuel filter also the priming buld to for cracks etc.
May 18, 2011 | Homelite Consumer Products Backpack...
I have the homelite mighty lite backpack blower. i don't have a problem starting it. The problem is when i turn the choke to 1/2 and then full running position, i strap it on my back and then this is where...
you have a dirty or blocked carb jets strip down the carb and clean out the running jet
dont poke wire into any of the jets to clean them this will distroy them!!! use car cleaner and cmprest air if you can,,good luck mike
Nov 04, 2010 | Homelite Consumer Products Backpack...
Trimmer will only run in choke position
You have a few possibilities. Make sure you have good fresh gas in the tank. You're not getting enough gas, so choking helps get more gas than air, making it run better. Could be the carb diaphram (not very expensive if you replace yourself), when they get old they don't perform like they should. Could be the filter in the gas tank is bad, plugged. Also might be just an easy adjustment on the carb Low, and High speed screws. The choke has three positions, full choke, partial choke, and no choke, which means run position.
Apr 28, 2010 | Homelite Consumer Products 4.0 Amp, 13 In....
2-cycle blower starts up but wont run full power rpm
Have you tried choking it about half way and see if that helps? Does it do the same after it is warmed up?
Mar 11, 2010 | Homelite Consumer Products Backpack...
How do I adjust needle valves on a 25cc Homelite UT08111A Backpack leaf blower?
Set the lowend & highend needles to about 1 3/4 to 2 turns each. Choke the carb or prime it, until the carb is wet. Fire up the engine and let it warm up. Let's set the topend first since it's the easier of the two. Go to full throttle. Adjust the topend needle for peak RPM. Leave it wide open for about a minute to see if it changes any. Should the engine go lean, open the lowend needle slightly, if this dosen't work... you will have to adjust the needle valve inside the carb.( I will explain this later) If the topend runs OK, then slowly pull the throttle down until the engine begins to "four cycle" hold the throttle there. Adjust the lowend needle until the "four cycling" barely stops. Now lower the throttle more until it "four cycles" again, and adjust the lowend again. Keep doing this until you reach full idle. Now, from full idle begin to throttle up until the engine starts to bog or hesitate. Open up the lowend needle just enough to eliminate the bog or hesitation.
http://tech.flygsw.org/walbro_tuneup.htm
hope this helps :)
if it does please vote
Oct 23, 2009 | Homelite Consumer Products Backpack...
Homelite Lightnin Bug Generator not getting gas
try leaving your choke partially on it may not be getting all the gas it needs,see if it will run then, it wont run full throttle, but this will tell you its not getting enough gas
Oct 05, 2009 | Electrical Supplies
Carburetor adjustment for Homelite 2 cycle engine The product doesn't start easy, and it does come to full throttle. If I run it on partial choke it runs fairly good, but it has been getting worse. Last...
I have the same problem with my MightyLite 26cc Blower/Vac. If it does start it runs rough on full choke and stalls on 1/2 choke or run. I've tried everything, fresh fuel, Seafoam, etc. Nothing works. First time I used it the exhaust burned a hole in my brand new Carhartt hooded sweatshirt. Best solution, throw it away, never buy another Homelite product and tell anyone who will listen what a piece of junk Homelite products are.
Sep 20, 2009 | Homelite Mighty Lite Lawn Trimmer
Hard to start.runs well once started
Some engines are just hard to start, go to any auto parts store and buy a can of "Starting Fluid" spray a short burst near the air intake or near the carbuerator and it should start first pull.
May 17, 2009 | Homelite Consumer Products Backpack...
Craftsman gas leafblower
Hey Karl,
To me this sounds like its getting too much fuel after it has been warmed up so either there is too much gas flow to the unit or there is not enough. check your primer bulb once this happens if there is a full bulb when it shuts down chances are its getting too much gas, if its empty then its not getting enough and your fuel filter could be starting to plug up or is not in the tank properly.
Nov 16, 2008 | Garden
Homelite Consumer Products Backpack Blower/Vac, Carb Logo
1,144 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
