Question about Accton CheetaHub Classic 2040 Networking Hub
Our local LAN is connected for 6 windows 7 computers using an Accton CheetaHub 2040. LAN speed is 10Mbps. We get a lot of lost connections to our local server. How can we increase from 10Mbps to 100Mbps?
  • 2,878 Answers
100Mbps in not the solution, because the computer NICs are not being utilizing nearly to 10Mbs. You may have a 10/100 or even 1000 (1GB) Network Interface Card, but you will never get those speeds. Not on a desktop anyway.
Example: COX offers Internet Professional a max of 15Mbps download, and 3Mbps upload for $200 a month w/3yr plan. You would need 4 such connection totaling $800 dollars a month to reach 10Mbs, and this is one the cheapest plans out there. I'm don't know your service plan, but I assume the budget is a great concern.
T1 = 1.54Mps
http://www.t1shopper.com/
Enough rambling, let's talk solutions. Get another hub to test out. Like a Netgear or Linksys. Get new cat 5 cables.
Then the server needs to inspected to see if the failure is there. Check the event viewer for warnings and errors. These can be very technical though. Is there high CPU usage? What about the NIC setting? These actually matter.
Finally what about the DATA provider and their equipment. Have them test out since they are the first point of entry.
GL
Posted on Oct 26, 2012
4 Suggested Answers
SOURCE: Accton CheetaHub Power 3016P not working
replace with the same one...
Posted on Feb 25, 2008
  • 59 Answers
SOURCE: got an accton eh 2024 etherhub and wanna network 2 computers
Forget Windows XP networking wizard.Go to control panel>network connections>right-click on LAN connection>properties>select TCP/IP>click properties IP: 192.168.1.100Subnet: 255.255.255.0make the other PC's IP: 192.168.1.101To allow file sharing go to Control Panel>windows firewall>check file and printer sharing and click ok
Posted on Jun 16, 2009
  • 101 Answers
SOURCE: No have Drivers Accton CheetHub Classic 2040 Win XP
If this is a hub no driver is required, connect your CAT5 cable to it and the other end to your Network interface card and it is done.
Visit http://www.accton.com/ for more informtion.
Posted on Jul 30, 2009
Driver for win 7 pc
You dont need any driver for your device.
Jan 22, 2014 | Accton CheetaHub Power 3016P (EH3016P)...
Tip
How to Fix Blinking Power Light on Linksys routers......
If you have a blinking power light on the router try to turn off the router for about a minute then turn it back on again. If the power light is still blinking follow the steps below to troubleshoot the problem.
1.HARD RESET- Reset the device to factory default.
a.Press and hold the reset button for 30 sec., after that
b.Unplug the power keep holding down the reset button for another 30 sec.
c.Then, plug back the power keep holding down the reset button for 30sec., after that
d. Release the reset button.
Make sure that you have downloaded the correct firmware version for your router from the Linksys website at http://www.linksys.com/download. You would be able verify the exact version of your router from the sticker at the bottom portion of the router.
2. Connect your PC to port 1 of the router.
3. Assign a static IP to the PC:
To statically assign an IP address
Windows 2000 and XP:
1. Click start, choose Control Panel
2. Double click Network Connections
3. Right click Local Area connections then select properties
4. Select “Use the following IP address” then enter on the IP address type 192.168.1.45 Subnet mask is 255.255.255.0 then Default Gateway is 192.168.1.1
Windows 95, 98 and ME:
1. Click Start, choose Settings then Control Panel.
2. Double click network.
3. Highlight TCP/IP -> for your network adapter (Ex. TCP/IP->Linksys Etherfast 10/100 Network Adapter)
4. Click Properties
5. Select Specify an IP address then under IP address, type 192.168.1.45 Subnet mask is 255.255.255.0 then
6. Select on Gateway tab. On New Gateway type 192.168.1.1 and click Add. Click OK all the way until it prompts you to reboot the computer.
7. Reboot PC.
4. Force the Ethernet card of the PC to 10Mbps
To force the Ethernet Card to 10 Mbps:
Windows 9x and ME:
Go to Start > Settings > Control Panel>Network > Highlight the LAN card you are using with a green icon beside it > Properties > Advance Tab:
-Under Properties set the value of:
“Media Type”; “Connection Type” or “Speed and Duplex Mode” to “10mbps/half-duplex”; “10BaseT” or “10Mbps HD”.
Windows XP and 2000:
Go to Start > Control Panel > Network Connections > Right Click Local Area Network Connection that you are using > Properties > Configure > Advance Tab:
5. Ping the router
a. On WinXP/2000:
Click Start > Run. On the Open field type cmd then hit OK. On the DOS prompt type ping 192.168.1.1
If it replies 4 times, proceed to the next step
b. On Win98/Me
Click Start > Run. On the Open field type command then hit OK. On the DOS prompt type ping 192.168.1.1
If it replies 4 times, proceed to the next step.
6. Proceed in upgrading the firmware of the router.
7. After upgrading the firmware, power down the router and then power it back up and see if the power light is now steady.
To upgrade the firmware follow the steps below:
Access the router’s Web Base Utility [http://192.168.1.1]> Administration TAB > Click on Firmware Upgrade > Click on Browse > Browse or look for the *.bin file > click on OPEN > Hit UPGRADE button. (Just wait for the message “You have successfully upgraded the firmware”) > Click on the Continue.
After upgrading the firmware try to turn off the router for about 30secs then turn it back on again. Hard reset the router then reconfigure it to work on the Internet.
Hope this procedure works for everyone......
on Jan 04, 2010 | Linksys Wireless-G Broadband Router
LAN Network, both PC's with static IP's and defaullt and DNS addresses are 192.1683.1.1 tried the other defaults. Both machines connected. when i ping each others IP's request timed out. please help
Can not really understand what exactly you have done. Please try the following steps:
1. Assign static IP on pc 1 as 192.168.1.2 assign subnet mask as 255.255.255.0. 2. No need to assign default gateway and DNS. 3. Assign static IP on pc 2 as 192.168.1.3 assign subnet mask as 255.255.255.0. 4. No need to assign default gateway and DNS.
Open dos and try to ping. In case if the ping fails then disable all the firewall on both the pc's and try again.
If you are running windows vista then in network and sharing center make sure network discovery and file sharing is enabled.
Regards,
Rashish
Aug 06, 2010 | Accton CheetaHub Classic 2040 Networking...
No network connection for windows xp
Hello kenji, hi, it would really help if you could add more information about the no connection problem, anyway there are several reason why you have no connection;
  1. Bad Lan card, or built in lan port,
  2. Lan card device driver not properly installed, check your driver CD.
  3. loose lan cable. check using a lan cable tester device.
  4. bad router or router setup.
  5. bad dsl or modem setup.
  6. bad telephone connection. check also telephone cable.
  7. no internet service, call your ISP.
  8. if you are using a wireless lan card, check the device.
  9. bad Operating system installation.
  10. check your connectivity setup, is it enabled?
Go through each from one to ten, see which one is the fault.
Jan 14, 2010 | Acer Computers & Internet
What is the ip address to accton chtah hub router
It will be 192.168.2.1 ... or you can try default IP for other routers ... 192.168.1.1 / 192.168.0.1.
Regards,
Shrey
Oct 08, 2009 | Accton CheetaHub Classic 2040 Networking...
Moderm speed
Your question is garbled but I'll try to explain some of it.
Your ethernet LAN jack on your computer is probably 100mbps and the ethernet LAN jack on the modem is also 100mbps, connect them together and it will tell you that it is connected at 100mbps because they are both working at the same speed.
As for the other connections, you are mixing usb and ethernet up so much that I can not tell from what you are connecting together.
Sep 14, 2009 | Computers & Internet
Lan only showing 10mbps
What is the speed of your network switch or router? If your computer is hooked to a 10 MBPS switch, that is all the speed you will get. My only other suggestion would be to look in the motherboard BIOS and see if there is a setting that affects the onboard lan speed.
Jul 30, 2009 | Computers & Internet
Jul 03, 2009 | Accton CheetaHub Classic 2040 Networking...
Got an accton eh 2024 etherhub and wanna network 2 computers
Mar 27, 2009 | Accton EtherHub 24S (EH2024) Networking...
The built in power supply of the switch will be defective. Please contact any good TV technician since it is a SMPS power supply. The repair procedure is same since TV has a SMPS power supply.
Oct 29, 2007 | Accton CheetaHub Power 3016P (EH3016P)...
Accton CheetaHub Classic 2040 Networking Hub Logo
112 people viewed this question
Top Accton Computers & Internet Experts
David Payne
David Payne
Are you an Accton Computer and Internet Expert? Answer questions, earn points and help others
