Question about SAMTRON 55V 15" CRT Monitor
Monitor screen turned into pink
I am having a 56v samtron color monitor. my monitor's entire screen turned into light pink color n only some colors like red,black,white,blue appear.others will be in pink or orange.First when i got this problem i used to hit the degauss button 2 to 3 times and the screen becomes normal.but now there is no use of that degauss.please tell me should i change my monitor or it can get repaired. thanks in advance...
  • 3 more comments
  • Anonymous Sep 05, 2008
    I have a relisys monitor for 4 years and it gets pink ,it happens some time to get to normal(3-4 minutes,and then gets pink again)and I don't know what's the problem.IF somebody can give me sugestions please, Thanks.:(:)
  • swarby Nov 24, 2008
    My screen goes pink and orange then every so often reverts to normal then back to the weird colours again.
  • ritarose39 Dec 20, 2008
    The colors have faded away. I get blues, orange and pinks only, can someone help me? Thanks.
    19 inch LCD monitor.
  • Anonymous Jan 27, 2009
    i hv dell 19' monitor turns pink
  • Anonymous Apr 13, 2009
    i have no clue whats going on but all the whites seem to be pink now please help.
A defective monitor cable can cause the monitor to turn pink.
Posted on Sep 01, 2007
    Problem Solver:
  • 16 Answers
Check and replace if needed the monitor VGA Cable.
  • 12,061 Answers
Hi, It seems to me that your monitor has a problem on it's Motherboard/PSU.. these days what with the cheap prices of 2nd hand monitors, $30 - $50 I would suggest another one, as repair would almost certainly cost more than a good 2nd hand unit. Good Luck
Posted on Jul 31, 2007
Check once ur display card
Posted on Apr 22, 2011
In your Monitor CRT Board Problem is there May Be Color IC is Fail or Sometimes Presets of R G B are faulty so change presets or IC
Posted on Aug 10, 2007
4 Suggested Answers
SOURCE: problem with samtron 56v 15" monitor
IT IS REULATION COMPLIANT PLEASE CHANGE THE 7805REGULATOR IC NEAR THE MEMORY IC
Posted on May 12, 2007
SOURCE: Samtron 56v
change the 5v regulator 7805 which is the supply for microprocesor
Posted on Sep 03, 2007
SOURCE: Monitor display in blue shade
It may be due to the loose contact of the monitor signal cable
Contact the nearest Repairman
Let me know that your problem is solved and rate me as Fixya!
Posted on Jun 17, 2008
Samtron 56v pc monitor video background with gray vertical lines
How to Tell If A Computer Monitor Is Going Bad
Computer monitors are designed to work properly for years.
Whether it's from a defective part or power surge, they go bad eventually, and you'll probably know it when it happens.
Look for vertical or horizontal lines across your monitor screen that shouldn't be there.
Time how long it takes for your computer monitor to come out of sleep mode. It shouldn't take more than 5 or 10 seconds for the screen to be fully operational when taken out of sleep mode or turned on after being turned off. If the screen is not operating as quickly as it should, it could be a sign it's getting old.
Read more :
How to Tell If Computer Monitor Is Going Bad eHow
Oct 13, 2015 | Samsung SAMTRON 56E/57E/56V
Samtron 55e computer desktop,monitor screen is pink and then with the blue coded plug that goes in back of tower is on it turns black and then when i take the blue colored coded plug out the screen turns...
Samtron (a former subsidiary of Samsung) as an entity no longer exists, and I have been unable to find any legitimate links to archived support documentation.
The symptoms you describe indicate that the monitor has failed. One way to verify this is to connect another, known good monitor to the same output on your computer. If that other monitor works, then yours does not and it is not the computer's output that is bad.
Looks like time for a new monitor.
Hope that's helpful.
Jan 17, 2011 | Samtron 96BDF 19" CRT Monitor
In my SAMTRON 56V monitor problem
my samtron 56v problem stand by when i power off yet i power on it is off position whats problem with me.switch is many time pressing then is on position.what is parts of my monitr suplly fault.wich part is spoil
Jul 02, 2009 | SAMTRON 78DF 17" CRT Monitor
Display color has been changed to rainbow.
AS hit the monitor on its top the color changes to normal. so what can i do AS IT COMES TO normal position after hitting that cleary indicates that there is no parts failure. 1 there is a loose contact in or near crt base. 2 loose contact in connector. 3 computer to monitor cable loose.
Sep 15, 2007 | SAMTRON 55V 15" CRT Monitor
Monitor color has been changed to yellowish.
There are three Cathod Ray guns responsible for the millions of
colors.All colors are produced by mixing the three basic colors namely
Red Green and Blue (RGB) at suitable proportion. If any one of the
three guns fail firing then we get improper colors.
Try
(1) Simply tap on the monitor and see the result.(Keep the monitor on during this trial.)
(2) Disconnect the Monitor.and Slap it at the back by keeping it on a pillow with the screen facing down - it will resolve the problem if the failure is due to the loosening of the Head due to repeated thermal expansion and contraction.
(3) check the signal cable for loose connection, twisting etc on both ends - at the back of the CPU and Monitor (it is fixed) -
(4)tighten the screws at the backside of the CPU
Best of luck
ProfSweetlin
Sep 14, 2007 | Samtron 76df 17" CRT Monitor
Need solution for the yellow display of my monitor
You can see one ic in right of crt base,plz resolder it (90%sure)
Sep 14, 2007 | SAMTRON 55V 15" CRT Monitor
Samtron Monitor 56v 15''
samtron 56 v problum: switch on the monitor no ON, but two or three times switch on now ON. what is the problum
Sep 06, 2006 | SAMTRON 55V 15" CRT Monitor
SAMTRON 55V 15" CRT Monitor Logo
2,163 people viewed this question
Top Samtron Computers & Internet Experts
William Miller
William Miller
pankaj rautela
pankaj rautela
Richard Lilja
Richard Lilja
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
