Question about Indesit Dryers
Fit newbelt for indesit idc 85 dryer
HOW TO FIT NEW BELT
barkencoa
  • 3463 Answers
SOURCE: I need to fit a new belt to a Creda Tumble Dryer
Hi.
On some models it is possible to fit the belt on the tensioning pulley or pulleys , the wrong way.
Assuming you have the correct belt, then I suggest you try the belt on the pulley a different way.
Hope this helps.
Posted on Nov 29, 2008
  • 156 Answers
SOURCE: fitting a dryer belt
depends on dryer but remove are lift the top up remove front panel slide new belt over drum with rib part belt toward drumaround motor and pulley
Posted on Feb 28, 2008
AlmostBob
  • 550 Answers
SOURCE: how to fit a belt on a tumble dryer
unplug the dryer,
220v is not fun
dryers are generic inside, regardless of maker
while you got it apart to replace the belt is a good time to clean out exhaust vent pipes and the squirrel cage fan, no lint, better air flow, less $$ to run
3cd9043.jpg the tensioner may push Up on the lower run.
  • open case, most front panels are removed including door, remember to disconnect door switch wires, set panel aside
  • pull drum out
  • check drum support rollers
  • check drum felts, bushes guides
  • locate tensioner pulley, belts have been known to pull them out of the mounting when it breaks, check , reinstall if out
  • pick up broken belt off floor of case
  • take belt to parts store and match it, despite the huge number of dryer models there are very few belts.
  • If any felts or rollers are worn,stuck,damaged take them too to the parts store, and replace in pairs, despite the huge number of dryer models there are very few rollers or felts
  • after ensuring rollers anf felts and bearings are serviceable, loop new belt around drum at the wear mark from prior installation, reinsert drum
  • loop new belt around motor pulley.
  • pull tensioner pulley against spring to end of motion
  • loop belt around tensioner pulley
  • allow tensioner to slowly move back by spring tension till the belt is taut
put front panel back on, plugging in door switch
plug in mains
dry clothes
takes longer to type than to do
Posted on Aug 29, 2008
SOURCE: How do I fit a new belt to a Whirlpool AWZ650?
Found this dead easy, take top off and back off. Inside undo the star shaped screws, there are also a few screws that are a different shape when removed, these secure the back to an air inlet. Suggest you take note of where the screws come from, even write a number next to the hole with a marker pen and note which screws and in what order. There is also an earth attached to the drum, this is the only wire I removed. Take this back section off. You should then be able to remove the drum by wiggling it out and turning it sideways in the dryer casing.Then remove the fan bottom left, 4 screws and a clip in the centre, the clip was difficult to remove without spreading it so you may need to squeeze it back into shaped before putting it back on. The tensioners will probably have come out of their locators so put them back into place, this is easy to see when you look at them. This is proabably a good time to vacum any dust out. Spread the tensioners hook the belt over the drive shaft only, not the tensioners, and let them spring back, these will then spread when the belt stretches around the drum. Put the drum back on and pull the belt around it, make sure its lined up with the original belt markings otherwise it will just pull the belt off of the drive shaft. Put all the screws back in attache the earth to the drum and put the back on then the top on. I'm not a technician and haven't done this before, it took about 1 1/2hrs.
Posted on Jul 28, 2009
  • 1891 Answers
SOURCE: fit new drive belt to tumble dryer
I need to know more. like how to instal belt or how to find what belt fits your dryer . need more info like mod # there 5 different belts for hotpoint . and several different ways to install them so model # ______________ needed . **** . pls .
Posted on Jan 02, 2010
Took the old belt in to measure and this new one seems to be about an inch to short. How do I stretch it to fit or is it wrong size all together?
You can't strech the belt, slacken the adjuster, fit the belt & re adjust. If it still doesn't fit, the belt is the wrong size
Sep 05, 2015 | Cars & Trucks
How to change serpentine belt on 2006 buick lacrosse
Start by drawing a diagram of the belt routing. Serpentine belts normaly have 1 spring loaded tensioner (1 pully will have a nut or 3/8 or 1/2 inch drive hole) That will be the tensioner. get spanner or ratchet to fit & lever the tensioner away from the belt. Remove belt. fit new belt to most pullys except the easiest to get to, lever the tenioner back & fit the belt to the last pully, Check the belt is on all pullys properly & your done
Jun 28, 2012 | Cars & Trucks
Change serpentine belt on 06 sienna
  1. 1 Check to ensure the Sienna's engine is cold, then make sure the Sienna is in park, the ignition is in the off position and the key is removed from the ignition to prevent any possibility of the engine engaging during the serpentine belt replacement.
  2. 2 Open the hood and locate the serpentine belt routing diagram sticker on the side of the engine casing. Study it for a moment before removing the existing belt. It is essential the new belt be installed exactly as the diagram indicates.
  3. 3 Find the tensioner pulley, the main pulley that controls the serpentine belt, and fit a 1/2-inch socket wrench over the self-tensioner on the outside of the pulley.
  4. 4 Pull the wrench to the left to move the pulley forward, which loosens the belt, then remove the belt.
  5. 5 Compare the old serpentine belt with the new, replacement belt for length, width and number of grooves on the belt's underside. Be certain the replacement belt is the right part.
  6. 6 Fit the new belt on to each pulley according to the serpentine belt routing diagram on the manufacturer's sticker, or according to the drawing made prior to removing the old belt. Fit the new belt on to the tensioner pulley last, again applying pressure on the pulley's self-tensioner with the half-inch socket wrench to loosen the pulley.
  7. 7 Release the pressure on the self tensioner and allow the tensioner pulley to ease back into place, thereby tightening the new serpentine belt with the appropriate tension.
  8. 8 Remove the wrench and close the hood.
Thank you and good luck,
Lee
Aug 26, 2010 | 2006 Toyota Sienna
Fit new drive belt to tumble dryer
Jan 02, 2010 | Dryers
Fitting new belt
Remove top cover and lower rear panel of washer
With some help, tilt washer forward, and fit belt round motor pulley first,slowly ease belt onto drum pulley and feed slowly round, turning pulley at same time, it will be very tight, so watch your fingers, you can align the belt after it is fitted. Please rate my solution.
Thanks.
Aug 19, 2009 | Washing Machines
I am trying to fit a new drum belt on a hotpoint aquarius vtdoo reverse action
You need to remove the top cover, remove the right hand side panel,ease the drum forward and fit the new belt.
It is very difficult to fit the new belt without the proper tool avialable from Hotpoint.
It can be done without the tool, but be prepared to stuggle
Dec 04, 2008 | Hotpoint Aquarius WMA52 Front Load Washer
Dont know how to put the new fanbelt on
If you open the bonnet and look to the left hand side you will see the jockey wheel that keep the belt tight tight. It has a square 3/8 inch fitting in it, put in a rachet of that size and take the tension off. Your belt will now lift off all the pulleys easy. If I was you I would make a simple drawing before you actually take off the drive belt as it runs over a number of pulleys and if you do the drawing easy to fit the new one on.
Once you have old one off fit new one and take the tension off with the rachet as you did prior to removing use your drawing to fit it correctly. I would also make sure your jockey wheel is fine prior to fitting the new belt listen for any rough bearing noise from it when you spin it.
Make sure you get the right belt from a ford dealership asthe length is critical of the new one even one a little shorter wont fit, dont be talked into buying one that seems nearly the right length, it must be the Ford one and the right length.
Sep 27, 2008 | 1998 Ford Explorer
FIT SEAT BELT
TO GET AT REPEATER LAMP ON O/S MIRROR ON A GOLF TDI SE 2004 REMOVE THE TOP COWLING AND THE GLASS NEXT TWO SCREWS AT THE BOTTOM TO REMOVE THE LAMP NO BULB BUT FIT NEW LAMP
Jun 20, 2008 | 2004 Volkswagen Golf
Dryers Logo
1,245 people viewed this question
Top Indesit Dryers Experts
Tim Whalen
paul
paul
Are you an Indesit Dryer Expert? Answer questions, earn points and help others
