Question about Xtreamer Pro
By xtreamer pro is power led flashing and want start the main screen on TV. I tryed more times to close the power supply and after ca 10 min started again but with remote on is only the red led blinki
Attached to TV with HDMI cable. Till yesterday has working without problems.
LG LED TV 55LN5600. Backlight goes off after maybe 30 minutes. The sound is on. picture is on (tested with flash light). Replacing power supply board did not fix the issue.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 04, 2017 | LG Televison & Video
Replaced power supply and reset still on light no sound just a flashing green light
Remove Mains Plug and press Standby switch from LED Panel for 30 sec.
Press Input & Ch Down Switch from LED panel and plug in and start LED
LED will start and "K" will appear on screen
Press Ch Down & Vol Down switch at same time
You will get 1/10 page on screen
Go to 9/10 page by pressing left & right button from remote
Select EEP and press Ok button from remote
After 30Sec remove main plug and restart LED.
Dec 13, 2015 | Sharp AQUOS LC-32D44U 32 in. LCD TV
After replacing power supply and resetting tv still only have green flashing light
Remove Mains Plug and press Standby switch from LED Panel for 30 sec. Press Input & Ch Down Switch from LED panel and plug in and start LED LED will start and "K" will appear on screen Press Ch Down & Vol Down switch at same time You will get 1/10 page on screen Go to 9/10 page by pressing left & right button from remote Select EEP and press Ok button from remote After 30Sec remove main plug and restart LED.
I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. Still have sound & can see a picture with a flashlight shining on the screen.
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Oct 19, 2015 | LG 47LN5750 47" LED TV 1920x1080, 120 Hz,...
My tv Sony bravia KDL 55HX800 Like 55" Turns off by self like 5 to 10 min after i turned on some times more... After turns off i can count 7 red led flashings ....
Fault to the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Jun 07, 2015 | Televison & Video
My LCD is flashing the power and opc twice and at the same time follow by the opc light 3 times
The power supply board of the television is dead,do you know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope it work with the help of the solution...
Aug 04, 2011 | Sharp Aquos LC-52SE94U 52 in. LCD HDTV
Morning, My Panasonic Viera TH-42PZ70B TV will not start up the red led is flash 7 times.
Either there is problem in your power supply or main board. There are many SMPS on the power supply board. First check the voltages coming out of the power supply & supplying to the main board. The voltages are printed on the power supply board. The top one is power supply & bottom one is main board.
sonsunny
Jun 17, 2011 | Panasonic Televison & Video
My tv doesnt show any images and the panel has the light of fopc on
Common problems on Sharp LCD tvs as tv it is agings,tv Power LED and OPC LED,LEDS lights flashes happen to mine Sharp tv many times and i had it two years,do this many times,tries to turn on the tv.By trying pushes the power button the remote again if OPC LED and power LED,LEDS lights flashes together.Everytimes the OPC LED and power LED lights flashes,just push the power switch on the tv remote and wait for the tv main Tuner signal board to kick in the backlight to light up tv to work.Have to do this like three or four times before the power supply board to kick it in to make Tuner signal to work.If u require to this more than 5 or 6 times the main tv Tuner signal board it is shorting out and beyond trying to kick in by the power supply board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
May 31, 2011 | Sharp LC-32SB24U 32 in. LCD TV
My Sharp LC-42-D62U won't power up. The power light blinks twice, then the power light and the OPC light blink together once. any fix to this problem?
Ur Tuner signal board have problems or dead.Ur power LED light indicator stable for a few mins before the power LED light,and the OPC LED light indicators flashes?After the POWER light and OPC light indicators flashes,just push the power button again for the power recycles again.Probally have to pushes the power button 3 or 4 for power light and opc light indicators flashes,the LCD backlght will lght up and work.Sharp tv have this problems alot,very common in Sharp LCD tvs.
Apr 17, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
No POWER
How many times does the POWER led flash per second? (Dont worry about the OPC).
1x (steady constant blink) = Lamps or inverters
2x = Power Supply
3x = Main Unit
If i am reading it correctly, looks like the POWER led is flashing 2x, which means it is a power supply failure. Either way, your TV needs to have a board replaced, there isn't anything you can do to fix it yourself. Try locating your local sharp authorized service center to repair your TV (1-800-237-4277)
Mar 13, 2008 | Sharp AQUOS LC-32D43U 32 in. LCD...
Xtreamer Pro Logo
334 people viewed this question
Top Xtreamer Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Xtreamer Audio Player and Recorder Expert? Answer questions, earn points and help others
