Question about Vizio L37 Television
37inch Vizio TV making buzzing sound from back
Six day old Vizio making buzzing sound from the back of TV, saw some other reviews but TV was older. Buzzing can be dround out by turning up volume but when you want to keep it low, you can hear it. Make have to take her back. Any Ideas!!
  • ricojava Jan 04, 2009
    I had same issue with a new VW37 LCD just purchased at Walmart. Vizio tech support said it should not be making the buzz sound and to exchange for another unit. In the meantime I noticed if you go into Setup, Advanced Video Settings, and then turn DCR off the noise goes down considerabley so perhaps just a quality issue overall vs. defect.
  • Anonymous Mar 22, 2014
    MODEL NUMBER R5067W
My tv is new too and also makes a buzzing sound and i turned the DCR off and it worked to thanks for the help!!
Posted on Jan 05, 2010
I bought my Vizio smart TV from ABC Warehouse 2014 it is not even 3 year old yet . when i truned it on the other day it maked a buzzing noise and shut off and it will not turn back on HELP PLEASE!
Something in the power supply gave out, your going to need a new board, don't order boards by model and make, use the part number on the board...you can get a replacement board from shopjimmy.com or ebay
Oct 21, 2017 | Vizio Televison & Video
Need help troubleshooting TV
You need to check your inputs. Make sure your tv is set to the same input that you are plugged into. Ex. If you are plugged into HDMI 1 then your TV SOURCE needs to be on HDMI 1.
Dec 30, 2015 | Vizio 37inch VO37LFHDTV1A FULL HD 1080P...
Hannspree tv is making a buzzing sound
First I am glad helped with the other issue.
This issue needs to be defined: do you hear the buzz when sound is at zero? I not the issue is in audio circuit or signal to set----If you hear the buzz with sound off it is likely something in the set vibrating hard enough to make the noise.
What causes this is a part that is not bad but noisy--there are ways to deal with this depending on set.
My real concern is if set is opened etc it will void your warranty!
If 5 days old most major stores will take it back or issue credit so you can replace the set----makers will often play a shell game--tell you it MUST go in for repair.
Most major stores have an unwritten rule here: set can be returned within first 30 days and exchange/replaced for ANY reason.
Seen ones returned because owner did not like the color of the cabinet etc.
If I know what type of set it is (has a picture tube, LCD etc and you have no warranty I can tell you what to look for and a possible way to fix it---Don't void the warranty if you have one by just opening it.
Saw a (will not call him stupid) person with a 1,000 set here yesterday which clearly had a problem and was 3 days old open the set and in doing so removed the labels there to indicate if someone has tampered with the set---now he has no warranty and a non working set.
May 01, 2012 | Hannspree (K206-10U1-005) Television
My refrigerator is six years old and for the past two months is making a loud buzzing noise. The frequency has increased over time. What could it be? It's an Amana side by side model ASD2626HE. Sounds like...
Saw your post a week late but the sound could be the start relay on compressor is weaking or if the water is turned off to ice maker the water control valve will try to fill ice maker if the ice make switch is left on and has no water. I will send a manual shortly, Sea Breeze
Apr 12, 2010 | Amana ASD2626HE Side by Side Refrigerator
Buzzing noise coming from Vizio HD TV speakers
It ur Vizio tv,The power supply board is the problems.The transformers in the power supply board have gaps in the transformers.The high voltage curents flow that make that buzzing noise.
Apr 07, 2010 | Vizio VW32L 32 in. LCD HDTV
Our 3 year old Vizio plasma TV just made a popping sound and the screen went blank, then about 30 seconds later, a horrible piercing buzz started and we had to unplug the TV to get it to stop...Any ideas?
It just happened to me on 4/7/10. My vizio p50hdm made a popped noise & did not turn on. I purchased the tv at costco on June 2005 w/amex card. I pulled my amex statements from 2005 then called costco with my member # and they found the transaction. If you purchased the tv before 4/2007 the item is grandfathered with the 100% customer garrantee. After 4/2007 the return policy changed to 90 day money back return 2 year warranty and you get an additional year if you purchase w/amex card for a total of 3 years. Be very nice to the Costco people even if they give you an attitude on the return of tv. I got a credit for $2200. I just purchased a samsung led tv 46 series6 back lit & internet. Amazing Technology. & I Love Costco
Mar 30, 2010 | Vizio L32 32 in. LCD HDTV
Loud buzzing noise on vizio tv
It sound like you may have sound processor problem which is part of the main board, I would also look at the 12vdc from power supply to make sure it is clean DC.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=l37hdtv10a
http://en.wikipedia.org/wiki/Capacitor_plague
Dec 22, 2009 | Vizio L37 Television
Vizio GV42l buzzing
Vizio makes an ok LCD, but if you notice they no longer make plasma. they stopped last year. Anyways. the buzzing sound is semi serious, it sounds as though you have a capacitor leaking. It is best to get it fixed before it goes out all the way, with it buzzing it will be easier to identify. Best of luck
Sep 12, 2009 | Vizio GV42L 42 in. LCD Television
Buzzing sound on Vizio Plasma TV
likely supply failure or shorted pannel driver. u should be able to unplug the pannel boards from the power supply. if the buzzing stops than its the pannel boards otherwise its supply.
Dec 05, 2008 | Televison & Video
Vizio Speaker Making a Buzzing Noise
My 32" vizio I bought a week ago does the same things.
Buy an external sound system for the tv. Turn the speakers off in the TV menu. Hook the sound system up to the out speaker hookups on the tv.
You will not only have better found, you will fix the speaker buzz problem.
Feb 19, 2008 | Vizio L32 32 in. LCD HDTV
Vizio L37 Television Logo
4,052 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
