I've got a RWB heating control, its usually on
5 Suggested Answers
  • 27 Answers
SOURCE: Honeywell PRO TH4110d Prog Thermostat not responding
cfheck to make sur ethat the t-stat is set for your type of heat. if you do not go through the instructions sep by sep then you will have problems. if you have then call a professional.
Posted on Nov 26, 2008
  • 334 Answers
SOURCE: Honeywell RTH230B a/c problem
if you set the thermostat on 70 and your house won't get ant cooler than 72, there is a problem with your system,not your stat. I'm thinking you are low on refrigerant if it is somewhat working. when the unit is running, if you can get your hand on the larger refrigerant line under the black insulation, it should be cold, about 55 degrees.
Posted on Jun 19, 2009
technical114
  • 1851 Answers
SOURCE: Canoscan Lide 30 compatibility with Windows 7.
There are no official drivers for CanoScan Lide 30 for Windows XP, so your problem is obvious. I suggest you sending an e-mail at Canon including details about your scanner (date purchased, serial number in text form or scanned) asking them to develop driver set as this model is very trade and at shops since 2006 or 2007.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Posted on Feb 27, 2010
atocrxr
  • 135 Answers
SOURCE: 2 Rheem Protech 500 thermostats, 1 upstair & 1
Have you checked to make sure that all of the supply registers are open, the air filter is clean and nothing is blocking the return air grill?
It almost sounds like you could be cycling on a limit switch.
Usually on gas furnaces, the blower is controled by the onboard controls, in the cooling mode the thermostat will control the blower.
I would be looking past the thermostat, at the furnace it self.
I hope you find this helpful. If you continue to experience problems, please let us know and we will dig deeper. :)
Paul
Posted on Apr 04, 2010
Hi, I've a fagor feb20e Eco plus combi boiler in
There is a flow sensor in the circuit and it is not sensing the lower flow from just the hot water. When you put it on heat though it does.
May 31, 2013 | Water Heaters
My lg bd350 over heats after about an hour
Sounds like the motor is straining, pushing too hard. It should get warm but not hot. Something is stuck either in the motor or around the belts, usually a piece of shreaded tapr or dust from the tapes. Try cleaning it out with compressed air. Good luck!
Dec 28, 2012 | LG BD350 Blu-Ray Player
I have a 87 Cutlass Ciera. 2.8 engine. I've had
Check this link out.Here's how to replace,if this doesn't work,take back for refund..
Dec 03, 2012 | Cars & Trucks
Mazda Tribute v6 2002 5-8 seconds to start
sounds like a problem with the ignitionkey comuting with body control module verifying that it is the right key for the car. if you have another key and see if it does the same. reprogramming of keys may help. Prados have been known to have a similar prob.
Nov 17, 2012 | 2002 Mazda Tribute
Buffalo ministation not auto-playing or showing in my computer
i have exactly the same problem with HD-PCU2 500gb ministation (Buffalo). i have also gone through the solution given by John Adams. i cannot find the device in disk management, therefore i cannot format the device...is it going to work again..please help
Sep 03, 2012 | Buffalo Technology Buffalo MiniStation...
My Brother XL-2620 sewing machine has stopped working.
make sure the outlet it's plugged into works
make sure the power cord & foot pedal are plugged into the
machine correctly
if you've already checked those things,, & they are plugged in
correctly then a trip to the repair shop is needed
Aug 22, 2012 | Brother Sewing Machines
My 1992 Pontiac Bonneville died for no reason!
Not likely heat related
I would guess your fuel pump is worn out
& occasionally stops from mechanical or
electrical issues
You could check the pressure with a gauge
attached to fuel rail but on a 1992,I'm guessing,
again, that it is the original or second pump
You may just have to replace it to solve the problem
Jul 23, 2012 | 1992 Pontiac Bonneville
After spending a couple hours searching I haven't found anyone with a similar problem, so I hope someone here can help. I have an old RM 2807 that I have been restoring. I've managed to get...
This is a common problem with the OEM control boards. I replace the RM2807 control boards with the new "Dinosaur P-711 control boards which are quality made and will hold up in the long run. Here is a link to the control board you need.
Sep 17, 2011 | Dometic RM2852 Refrigerator
My laptop is simply not recognizing my futaba interlink controller via usb hub. i know the hub works because i plug something else in and it works fine...I'm thinking just bad controller maybe?
Well i'm having the same problem.
My mouse & keyboard work trough the hub, however when i plug an USB-stick in, it wont recognize it.
I've i put my USB-stick in another USB-port, it works.
So try putting your usb, in another USB-port, thats not from your hub.
Jun 19, 2011 | Computers & Internet
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
