Question about Cannon Kitchen Ranges
Cannon cambridge 10282G new clock/timer has 5 pins old one 4 pins ??
10282G
4 Suggested Answers
ginko
  • 19396 Answers
SOURCE: Diehl Timer 4 pin wiring
The documentation for this timer is not available for download, you can enquiry about this device here :
Posted on Oct 15, 2008
SOURCE: I bought a new 1GB ram(DD2) when i insert it it nt work bt whenever i insert it with old 512MB ram then its work bt in bios setting only show the 1GB ram
Maybe 1GB is the maximum amount of memory that your system will hold. And maybe your system likes memory to be in pairs, so when you put the 1GB in by itself it didn't work, but when you put it in with a 512MB it works.
Posted on May 19, 2012
Testimonial: "thanxxxx but i did it"
  • 17 Answers
SOURCE: Can anyone provide the correct wiring instructions for a replacement oven 6 button timer (C00224982)unit for a Cannon Harmony Duel Fuel Cooker. Old unit has 4 terminals, new one has 6. No instructions
Hi, I would contact your supplier, it could be that they have supplied the wrong unit or that it has been modified since original manufacture, these things sometimes require links but normally all the kit required is in the box along with instructions.
If the unit is correct the supplier should be able to tell you what the connections are in relation to the existing unit. Hope this helps.
Posted on May 23, 2014
How can I get my cannon Cambridge oven to work it seems like the minute button has come undone
unfortunately the oven clock has to be set correctly or else will not work
Mar 07, 2015 | Ovens
15265 In-Wall Digital Timer - I am replacing an Aube with this new timer. Timer is to operate a wall plug (outdoor soffit). Timer is inside. The old switch had 3 wires - only two were connected (I think...
GE -15265 manual
http://waterheatertimer.org/pdf/GE-15265-manual.pdf
Ah, the usual how to connect 4 wires to the old 'was-3-wire and now-2-wire' problem.
I tested and wired these timers.
Aube timer has internal rechargeable battery, and therefore does not need another wire to run internal clock.
GE timer has extra wire to run internal electronic clock, just like alarm clock is plugged in.
Heres what to do in simple format
1) Timer-green-wire connects to bare ground wire.
2) Old timer has 2 wires. Take both wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
3) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires. This action will complete circuit to internal clock.
4) If electric box does not have white wires described above, then connect timer-white to bare ground. This works because bare ground and white neutral both connect to neutral busbar inside breaker box.
5) Turn on electricity, push in timer door for manual override. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
If light does not come on, double check that outdoor bulb is good, and that breaker not tripped.
Timer can also be reset in event of short. Reversing red and black wires will not short timer.
Add a comment of you need more help
http://waterheatertimer.org/See-inside-main-breaker-box.html
Nov 30, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
Installed new T104 timer 3 mos. ago. Bldg. owner says the dial "hangs up" on pins--has to use manual on/off. Wiring is correct.
1) The clock motor might be bad if trippers hang up on pins
2) The timer might be exposed to dirt dust and moisture, in which case the T-104R raintight might be better
3) The tripper pins rotate around until they contact the tripper lever >> the pins push the lever >> new Intermatic timers have a bit of white grease on the lever where trippers contact
4) Test the manual override to see if it clicks back and forth crisp and clean >> the trippers click the manual override back and forth, so if override is sluggish, then timer might be bad >>> buy new timer and swap out insides without changing box
5) Sit and watch the timer and see if trippers hang up or they skip over the tripper lever> you might need new trippers. This seems odd with a new Intermatic timer.
6) The building electricity may have gone off and the timer is not set on current time and the bldg owner doesn't know how the timer works.
Timer accessories at Grainger
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
Oct 22, 2010 | Intermatic T104-20 Indoor Hot Water Timer
I have a BTC keyboard, Model #: 9000A. A wire became broken in the PS/2 male plug. I need a Schematic so I can solder on a new plug. I know this is a very old keyboard, but I like it and do not have the...
Unfortunately there is no color code for the cables in the PS2 connector. All the details that I can give you is that if this is the PS2
The pin #1 moves DATA.
The pin #2 is not connected or DATA2 (usually not connected)
The pin #3 is GND
The pin #4 is VCC for power (+5 VDC)
The pin #5 is CLK for Clock
The pin #6 is not connected or CLK2 (Usually not connected)
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, accept my solution.
Thanks and regards
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Oct 18, 2010 | Computers & Internet
Have model T103 Intermatic Timer that have been turning on the store lights for the past 20 years. Recently the timer does not turn the lights on in the morning and I have to manually flip the switch to...
Sounds like you need new ON pin
http://www.grainger.com/Grainger/INTERMATIC-Timer-Tripper-2E054?Pid=search
The ON-OFF pins rotate around until they come in contact with a lever. The clock motor pushes the pin forward until it clicks the on-off lever. The pins are softer metal than the lever, so the pins wear out.
If you need a new T-103 timer some day > the new timer mechanism can snap right into the old box without changing boxes.
If the dial is not rotating, then you can replace the T100 series 125 Volt clock motor (the T103 clock motor is 125V)
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=Wh40&op=search&Ntt=Wh40&N=0&sst=subset
Oct 12, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Clock turns untill pump turns on then stops. does c8866 timer work with well control box?
If I understand correctly, you are controlling 240V water well pump with Intermatic C8866 Repeat timer.
So you must be using pump to irrigate, and want to turn pump on at certain times of day for short periods ... and want this schedule to repeat continually non-stop.
1) The c8866 repeats the same program every 4 hours so this is good choice for irrigation and it just turns the circuit on-and-off so it works fine with well control box (unless you want more complex programming).
Many types and prices of cycle timers
More cycle timers
Let me give a buckshot answer and see if I hit one of the targets you have.
2) C8866 according to manual:
a) You have on-off trippers
b) First ON tripper turns on load for 32-40 seconds
c) Each additional ON tripper will lengthen ON time by 30 seconds
3) To lengthen ON time: add successive ON trippers into dial. Each successive tripper adds 30 seconds. Let's say you want ON time to be 3 minutes, you need 6 successive ON trippers.
Maximum timer setting is 240 minutes, so your ON-OFF program repeats every 4 hours.
10 Tripper pins come with timer.
Buy more pins at Grainger for 2.69
4) Did you say the clock stops running after hitting the tripper? If so, maybe you need a bit of grease on the pins ... or a new clock motor? Buy clock motors at Aplus
5) Review the wiring
Hots from Breaker connect to COM and CLOCK poles
1 Hot to Load connects to NO normally open pole
Other Hot to load connects to CLOCK pole
6) You can reverse ON-OFF programming by the following:
Change Hot to Load from NO to NC pole and this will reverse on-off programming
Oct 02, 2010 | Hardware & Accessories
Clock does not work to turn pool filter on and off. do I need a new timer mechanism or clock motor
Things to check:
1) Is yellow dial rotating? If not, then clock motor is probably bad. T-100 240V time clock motor sells for $16 at grainger.
Also timer may not be getting 240V so check manual override.
2) If clock motor is turning, but manual override never clicks on-and-off, then pins are probably worn out. Buy pins at grainger
3) Does manual override work? Does it click crisp? If manual override clicks crisp on-and-off, and pool filter turns on-and-off normally, then a) the circuit is getting 240V and b) the timer mechanism is ok ... so clock motor is probably bad.
4) If manual override snaps crisp but pool timer does not turn on, then then circuit breaker could be bad, wire is loose, motor has gone bad
Test for 240 across poles 1 and 2
... or timer contacts are worn out & you need new T-104
See back of mechanical timer
5) If manual override is loose or sluggish, then you need new T104. You can buy a T-104, T-104R, T-104M etc ... and the interior body will snap into old box.
Note: Do not buy T-101 or T-103 as these have 120V motor.
Sep 29, 2010 | Intermatic T104M 208-277Volt 40-amp Timer...
Hello I have an older T103 Intermatic which controlls outside lights. It is no longer turning on lights and is making an unusual clicking noise. Can it be repaired or should I install a new...
You can replace the clock motor for $16 ...
... but if the mechanical timer mechanism is worn out, then that is not repairable. To check mechanism, lift timer dial and rotate tripper pins out of way, then click manual override on-and-off >> if override works fine, and lights come on then motor is probably the problem.
If you buy a new T103, the insides might snap right into old timer box without needing to replace the box. To remove insides, depress retainer spring located at top, tip out timer, and lift to remove. New timer has 4 tripper pins. Save old tripper pins, and tape them inside box.
Sep 09, 2010 | Intermatic T103 Indoor 120-Volt 40-amp...
My Ge Mechanical Time Switch (Model number 15087) is losing time. Is there any way to adjust the timer so that it keeps correct time?
There is no adjustment if timer clock is running slow.
Timer clock motors run slow when the motor starts to fail.
There are no replacement clock modules this timer.
Buy a new timer at Home Depot, and swap out insides of timer using 1/4" hex nut driver, and then return defect timer in new box.
http://waterheatertimer.org/GE-timers-and-manuals.html#15207
Aug 05, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
Kitchen Ranges Logo
20 people viewed this question
Top Cannon Kitchen Ranges Experts
Paul Carew
reyaazm
Level 1 Expert
Tom Chichester
Are you a Cannon Kitchen Range Expert? Answer questions, earn points and help others
