Question about Panasonic PT-LB50U Multimedia Projector
The projector lamp does not turn on
I have a Panasonic PT-LB50U LCD projector. When I turn it on the bulb comes on momentarily, the power light blinks green for about a minute and then turns to blinking red and the lamp indicator comes on. I bought a new bulb and the projector has the same problem. Where can I take the projector to get it fixed or can you tell me what to do on line?
David
  • delimantjean May 11, 2010
    Toshiba TLP-T50 it can switch on but the reis no display
I have done this on several of our PT-LB50U's with sucess every time.Remove lamp cover and lamp.Then remove top of case by removing 6 screws on bottom.Remove metal shroud that would cover lamp 2 screws and remove 2 screws that hold lamp plug and move it away.You will see a little blue lever for saftey switch move it back and forth from top and bottom put back together and should turn on.
Posted on May 13, 2010
  • Greg Heath
    Greg Heath Feb 25, 2011
    A simpler approach is to remove the lamp cover off the back and poke a toothpick down the slot where the pointy bit on the underside of the cover protudes down into the machine. see if you can unstick the little blue switch this way.
I have the same problem. I do not find any blue lever type safety switch. I have replaced the new Lamp
Posted on Sep 15, 2013
  • vijay Sep 15, 2013
    Please help me
Did you ever get this fixed? I have the same problem.. please let me know.. thx
Posted on Mar 31, 2010
    Problem Solver:
TOSHIBA TLP-T50 CAN SWITCH ON BUT NO DISPLAY/ MAKE GUN SOUND FROM THE SPEAKER
Posted on Jan 09, 2009
How to do lamp reset on panasonic pt-lb50u projector.
To reset the lamp hours, turn on the projector. Then press Menu and use the Up/Down arrows to highlight Options. Press Enter then highlight Lamp Runtime. Press and hold Enter for 3+ seconds until the Lamp Runtime screen is displays. Press the Power button (any other button cancels the reset). When the Power button LED turns red, unplug the power cord to the projector. You can either use the remote or the controls on the projector. Reconnect the power cord after a few minutes.
The reset instructions are on page 62 of the user manual. The manual is available from Panasonic here: https://support.panasonic.co.nz/docstore/PT-LB50U%20Operating%20Instructions.pdf .
I hope this helps.
Jun 18, 2016 | Panasonic PT-LB50U Multimedia Projector
How do I get rid of a password on the projector so I can use the projector (PT-LB50U)
Menu
security
enter
input password on---off
Have a good day!
We supply original projector parts: lamp, bulb, Lcd, Lens, DMD, motherboard, powersupply ... with high quality and competitive price.
Jerry China
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Feb 06, 2014 | Panasonic PT-LB50U Multimedia Projector
Panasonic PT-AE700E projector light does not turn on, instead the fan runs on high for an infinite time until turned off
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
May 04, 2013 | Panasonic PT-AE700E Projector Lamp
After changing the bulb image will not come on and solid orange light appears
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
Jan 11, 2011 | Panasonic PT-LB50U Multimedia Projector
Just replaced bulb and Lamp red light still comes on when you plug in the Panasonic PT-LB1OU lcd projector. Screen display states: Replace Bulb
Replace power board: ETXMM519MBGB
Or replace transistor Q107 on this board with a typical pnp for switching power supllies,there's not a part number for it on the manual.
Dec 15, 2009 | Panasonic PT-LB10U Multimedia Projector
Unit powers on momentarily, bulb comes on for about 4 to 5 second
if a fan is blocked from turning then the power up self testing will detect a problem and stop it from further operation. thats why you have to unpug it
Mar 20, 2009 | Panasonic PT-LB30U Multimedia Projector
My Panasonic PT-LB50U LCD projector flashes red lamp indicator and will not light up. I replaced the lamp and it still will not light. The old lamp only had 20 or so hours on it and it does the same thing....
this worked for me what i did is: turn on projector then undo the light panel when its on the projector then will cut off, now the light panel pushes down on the hidden safety switch take a screw driver and push down on the switch, the projector will turn on then wait for about 8 sec then release the projector will turn off, repeat step several times until the light flickers, then do a couple more times and the light should come on and should stay steady turn off and let cool for 10 min, this worked for me hope it works for you!
Aug 12, 2008 | Panasonic Televison & Video
Projector won't turn on after I replaced the lamp
re insert the lamp and check your connection. if that does not work then replace lamp or have lamp checked.
Dec 03, 2007 | Nview Z215 10.4" LCD Panel with Video(16.7...
Panasonic PT-LB50U Multimedia Projector Logo
896 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
