Question about Craftsman 18" 2.4 C.i. 40cc Chainsaw Intake
45 lbs. of compression...........good or bad?
Ignition & fuel system OK! Will not start, or run. Only has a total of about 4 hrs. running time on it. It was hard to start from day "ONE"!
  • Craftsman Master
  • 7,482 Answers
If it is still under warrenty then return it for a new one...
Compression should be around 90-110 lb. per sq inch.
Sounds like ring problems, valves, etc.
If it is not under warrenty, time to trash it...because the engine is shot.
Please take time to rate me
Bud
Posted on Oct 27, 2012
93 Honda Civic dx will not start. new fuel pump igniter, has spark
sorry if you guess and guess wrong. really, must be expensive.
ok got spark (and timing is good, timing light test)
if test fuel ( use instant start in a spray can) fails, with spark
then engine is bad, compression is checked, see near 80 not 150+ PSI , the timing belt has slipped. if not changed by the book
they slip and the engine grenades (or bends valves)
this is an interference engine, never ignore the belt.
there is an acid test order.
1 compression good.
2 spark good, and timed
3 fueling is last. (if spark plugs dry add fuel, by hand)
cant burn fuel with no compression and spark. well with EFI it cant run right with bent valves either.
here is Chad running an engine (any) with no gas tank
even his battery is dead. and has external battery. for 12v power.
a real trooper.
ive done this 1000s of times. in 60 years.
his engine only makes 80 psi (old) and still starts.
but EFI will never do that not that low. compression
the cam slips and goes retarded compression drops to near 1/2
and the valve timing is so bad, the exh opens late and pollutes the
next last intake charge. the card house falls and then the valve bend.
take if from me, nostarts are a blessing on any honda
maybe it saved your valves.? do the service on time./
Dec 29, 2013 | 1993 Honda Civic 4 Door
Pontiac Aztek 2001 - 3.4l (non-GT); Codes: P0135, P0141, P0420 all O2 + Converter. Ideas on problem?
P0135 bank 1 sensor 1 open or short in wires,bad connections,bad sensor ,or bad ecm. P0141 bank 1 sensor 2 same diag as P0135. P0420 cat below threshold open or short, or faulty Ho2s sensors.you may have several problems. start with sensors circuit if good change sensors if not trace to ecm if reading not right replace ecm if all good replace sensors clear codes retest drive two drive cycles for cat to clear tests. then with no dtcs present test fuel pressure , injectors,then ignition system ,timing valves ,map,maf sensors,throttle sensor,crank sensor cam sensor, compression.
Aug 02, 2012 | 2001 Pontiac Aztek
The engine turnes but it wont start.
Free Auto Repair Advice by Professional Mechanics
Troubleshooting / Car Engine Cranks but Will Not Start / Engine Crank But Wont Start 2
* Why does my engine stall at idle?
* How do I change my spark plugs?
* Why does my engine stall?
* Why does the engine stall after replacing the battery?
* Why won't my engine crank over?
* How to retrieve trouble codes
* How to test fuel delivery system
* Engine cranks excessively
* Engine has excessive smoke
* Rapid ticking sounds when engine is cranked
* How to tune up your engine
* How to jump start your engine
* How to test an oxygen sensor
* How to open a car hood
* How a flywheel - flex plate works
Engine Cranks But Will Not Start
For an engine to run, you need three things to happen inside the engine, compression, fuel and ignition, without any one of these components the engine will not run. Follow the repair guide below:
Engine Configuration with Camshaft Operation
Compression - Engine compression caused by crankshaft rotation and pistons moving up and down inside the engine block. If the timing belt or timing chain fails it will cause the camshaft to become out of correlation with the crankshaft or allow the camshaft to stop rotating. Either of these conditions will cause the engine to lose compression and sometimes cause internal engine damage.
Fuel Delivery System - The fuel system includes: fuel pump, fuel injectors, pressure regulator, fuel filter and pressure lines. This system is used to supply fuel under pressure to the fuel injection system, the lack of fuel pressure or volume will cause the fuel delivery system to fail and the engine to stall or not start.
Ignition Spark Delivery System - The ignition system components include: spark plugs, spark plug wires, distributor (if applicable), crankshaft angle sensor, camshaft angle sensor, ignition coil, ignition module, knock sensor and PCM (engine control module). The engine relies on the ignition spark to be delivered to the combustion camber at the correct time. If the ignition spark stops or is delivered at the wrong time the engine will not run or run poorly.
If your engine cranks but does not start follow this troubleshooting guide:
* Step 1 - Anytime you have a problem with electronically controlled components such as an engine, transmission, ABS brake, or SRS (supplemental restraint system, Air Bag) inspect all fuses using a test light and check the under hood power distribution center and under dash fuse panels. If all fuses test ok continue to the next step.
* Step 2 - To check for problems with electronically controlled components such as an engine, transmission, ABS brake, or SRS (supplemental restraint system, Air Bag) and the fuses test ok a trouble code scan is needed to identify any system trouble. Use a simple scanner tool to retrieve trouble codes and see if they relate to the specific problem, like a crank angle sensor failure code. If the trouble code present does not pertain to the immediate problem like an EVAP code ignore it until a later time, after the car is running. The reason we repair non-related codes after the engine is running is because sometime false codes can be triggered by the engine not running. Once the engine is running again the code present might cycle and turn itself off. You might say "if the engine doesn't run shouldn't it have a trouble code?" Sometimes conditions occur that will not be detected by the computer, example: if the fuel pump fails the computer cannot detect the failure, so the engine doesn't start and the computer thinks everything is ok with no codes. If no trouble codes are present proceed to the next step.
* Step 3 - The spark plugs in your engine are used to ignite the compressed fuel air mixture. If the condition of the spark plugs are fouled by excessive fuel or carbon the engine will not start, backfire or run rough. Remove all spark plugs to inspect their condition. Please use this spark plug condition reference guide to see how the spark plugs are operating.
* Step 4 - Determine if the engine has compression, this can be done a number of ways but the most complete method is to perform a compression check. Remove the spark plugs and perform a compression test on one cylinder. If one cylinder has compression then the remaining cylinders usually will be close to the same. Crank the engine over about 5 seconds, normal compression readings should be between 125 psi and 160 psi on each cylinder. If no or little compression exists additional tests will be needed. The most common reason for an engine to lose compression is a timing belt or timing chain failure. If low or no compression exists remove the oil fill cap and observe camshaft rotation when the engine is cranked over. If no rotation exists the timing belt or chain has failed. If your engine has a timing belt and you cannot see the camshaft easily remove the upper bolts to the timing cover and gain visual access to the belt, recheck cam rotation by cranking the engine over. Sometimes a timing belt or chain can jump causing the camshaft to lose correlation with the crankshaft and therefore causing low compression. The best test for this condition is to remove the timing belt/chain cover and inspect timing marks. If the compression is ok proceed to next step.
* Step 5 - Test the ignition system output, ignition systems can vary in configuration but operate on the same principal. Ignition systems can consist of a coil, pick up coil, crank angle sensor, cam angle sensor, spark plugs, spark plug wires, distributor cap, ignition rotor and a distributor and any variations of these components. An ignition coil is a voltage stepper coil that transforms a low voltage (12 volts) signal into tens of thousands of volts needed to jump the gap of the spark plug. This coil is activated by an ignition module triggered by using the camshaft/crankshaft angle sensor; timing is adjusted by the ECM (computer).
Hope helps (remember rated and comment this).
Aug 11, 2010 | 1999 Chevrolet Blazer
Can,t get truck to fire ,just put fuel pump in . checked fuses,made sure fuel is pumping
the truck has to have the basics . Spark fuel and compression in that order. Remove a plug wire from a plug either remove the plug or install a different one in the end on the wire and crank the engine with the plug laying on engine ground in good view and see if there's spark. Being you did'nt mention what motor is in the truck, desiel. 10 cylinder gas 8 cylinder gas 6 cylinder gas 4 cylinder gas I can only guess at what kind of engine were working on. The gas engines have spark plugs as the desiel has glow plug heating system and direct fuel injection. Silveradoo is a trim level and theres 1/2 ton 3/4 ton 1 ton and 1 1/2 ton versions. They all have fuel pumps and if they have more than on tank or a desiel they can have more than one. The gas engine v8 has troble with the ingtion and the module is the most likly for the cause of no spark but the mileage wasn't stated so I have no idea where to start. if it still is'nt getting fuel with the new fuel pump it's still possible that is'nt running or if it is its wired backwards and is pumping backwards. If the fuel pressure checks OK (above 50 lbs. that part shold work. Below 45 lbs they might run but they won't start. Compression has to be good 100 lbs or more on any engine. most chevy engines are much more in good shape.150 or even as much as 220. low compression and it was running OK the last time it ran sort of says the timing chain skipped as the compression normally does'nt go away quickly. The exception to this is overheating and racecar type blowups. some engines after overheating will have little or no compression and if started with added fuel and revved up they can unstick rings and or valves. and go back to normal. the reason for the overheating needs to be found as this happens again the motor might not come back to life.
May 13, 2010 | 2000 Chevrolet Silverado
I have a Silverado 1500, 4.3 with 132,000 miles. After start, it runs fine, no signs of malfuntion. However it takes extended cranking to start. The fuel pump & filter was replaced 10,000 miles ago....
You need 3 things.
Compression
Good hot blue spark to all plugs.
Good gasoline and proper fuel pressure. 63-64 lbs.
If you have all 3 then move on to injector pulse to all injectors.
You may be weak on fuel pressure . even a couple of lbs low on a cold start will cause a no start. Double check cold start cranking fuel pressure. If under 63-62 lbs you have problems. One test is to give it a squirt of carb cleaner not starting fluid. If it starts then you have a fuel pressure problem. Run the full fuel pressure test and post back pressures. Here is the guide lines on testing.
Hard to start cold.
Check cold start fuel pressure.
Check engine running fuel pressure.
Check engine running on the road fuel pressure.
Then shut it off and watch for fast leak down.
Pinch off at rubber part or block off return line and check full pressure.
Later V6 and V8 gm engines should have 60-66 fuel pressure.
Cold start should be 64-65 lbs of pressure.
If you do not have full fuel pressure on a cold start the injectors will not squirt fuel.
Do not leave home without it.
Engine running should be 60-66 lbs pressure depending on engine load.
Full pressure with return pinched off should be 75-85 or more.
And if it has a fast leak down after shut off you have a leak.
Also you mentioned that you replaced the fuel pump, it's common for the $15.00 wire harness from the fuel pump to the frame will break and there is a bad connection till the wires heat up. You can try this trick, turn your ignition on for 30 seconds "engine not running" and then turn it off for for 5 seconds and then try to start. This will energize the fuel line if the fuel line check valve is bad which is a part of the fuel pump and will heat up the wire harness which will make a better connection and see if the engine starts easier. Regardless, inspect the wire harness for corrosion and the ground is good. Good luck and keep me posted.
Dec 15, 2009 | 2000 Chevrolet Silverado 1500
I have an 89 Jeep Wagoneer inline 6. Its not
You got the ignition cover, what you need to do an cylinder compression test and also check your injector for voltage while engine running hook test light to battery pos on neg and neg on pos, at injector harness check for pulsation, if you have pulsation elec. system ok, if good compression bad injector.if bad compression piston ring's or valve's.
Dec 08, 2009 | 1989 Jeep Grand Wagoneer
Boat motor, runs fine with no load, will die out after 4 minutes under load at max rpm.
if boat was stored for more than 30 days with ethanol gas then you have a fuel problem. but before you start to do any work on the fuel system do yourself a favor and check compression. since you didn't give any engine make or model. I can't give you specific specs, but the cylinders need to equal each other within 5lbs and the pressure should be over 100 lbs. Again I would be more specific if i new year make and model. next you really need to test the ignition system. Get a "spark gap tester" and test all the cylinders for spark. if you have good compression and good spark then nine times out of ten its fuel. remove fuel from boat gas tank. clean fuel lines and primer bulb. change and clean all fuel filters. if engine running doesn't improvement clean carbs. if it is carburated and not fuel injected that is. Again I would be more specific if i new year make and model. if its fuel injected the same compression and spark test apply but the fuel system requires computer diagnoses
Oct 31, 2009 | Boating
My Polaris freedom(jet ski) starts and runs good
Tools(1) A compression gauge (2) a spark gap tester.(3) A Clymer service manual for your engine. (you can purchase from your local dealer. I know all these are expensive but if your going to be a polaris tech you will always need them. Troubleshooting (1) check compression. Look at your Clymer manual for specific psi.all cylinders need to be over 100 lbs and equal each other within 5 lbs.(2) check spark. use a spark gap tester all cylinders should jump a half inch gap. if you have good compression and good spark, fuel is the problem nine
times out of ten.Ethanol gas is proven to stay stable in fuel systems for only 30 days in 90 + degree heat. Drain gas tank,clean fuel lines replace and replace all fuel filters. Polaris has a gravity filter under seat, clean it. Finally replace spark plugs, I know spark plugs probably don't look bad but this is a C.D.ignition. Fresh spark plugs means less resistance for the ignition system. The ignition system is week compared to automotive. Test drive polaris, if the problem is still there then there is further steps to take. If your polaris is fuel injected. Pull out your clymer manual. what is great about the Clymer Manual for Novice techs is it gives detailed info on your polaris. Troubleshooting tips and teaches you how your polaris works. If its carburetor then you should clean carburetors. Inside the carbs is another filter that needs to be cleaned. Its not difficult you just make sure you put everything back in proper order. take pictures if you need to.
Sep 18, 2009 | Boating
1980 VW rabbit, manual/fuel injection: I am
it starts from cold because the auto choke is on ,allowing a richer mixture ,try removing the sender unit in the tank and seeing if the connection from the pump to the outlet connection is ok or leaking causing a loss of fuel pressure
Aug 02, 2009 | 1983 Volkswagen Rabbit Pickup
This car is unsolve able ???????
Hi, This Might have nothing to do with your problem, but you have nothing to loose by the sounds of it, the breather pipe from the bottom of the sump (behind the starter motor) to the top of the rocker box, mine was clogged up with slug like greese causing sencer problems and giving false information to the computer. (running rought) you got nothink to loose, try it.
Chris
Aug 19, 2008 | 2000 Daewoo Lanos
Craftsman 18" 2.4 C.i. 40cc Chainsaw Intake Logo
97 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
