Question about Samsung BN59-00678A Remote Control
Codes for samsung remote kie20080611
Code for cable box
  • 44 Answers
SOURCE: samsung plasma tv
Samsung codes for sky reomte 0060 065, 584, 037, 245, 476, 398, 516, 292, 318,
037
Click here for the link
Posted on Jan 21, 2008
SOURCE: controlling a Motorola DCT6416 III with a Samsung LN-T4661F remote
I have the same problem
Posted on Jan 25, 2008
SOURCE: samsung code for a comcast cable box
The Remote w/ On Demand buttons, it's the same as the DVD player code 1932. Hit the AUX button, press and hold SETUP until AUX blinks and enter 1932. Press the power button and it should turn off the reciever.
*UNLOCKING VOLUME CONTROL* You must until your AUX volume control in order to use your Comcast remote. To do so, you must select AUX, press and hold SETUP until AUX blinks. Enter 9-9-3 and press Vol - (down). This should unlock your volume control when you select AUX. I'm not sure how to set AUX as your default setting for volume, unless you were to program your AUX device as your TV and vice versa I'd suspect.
Hope this helps!
Posted on Oct 04, 2008
  • 12 Answers
SOURCE: Remote control code needed
look on the website of you dish company and they should have it listed but i do not recommend programming universal remots on tv as if could change setting that the consumer is not able to change back
Posted on Feb 07, 2009
SOURCE: tuning samsung tv into virgin media cable box
Make sure you have a Vigin Media branded remote control, then try your codes.
0079 Worked for mine.
Posted on Feb 28, 2009
I use a RCA remote to programe my cable box but my samsung tv get programe instead of the cable box.and now my samsung tv goes on and off. What's wrong?
The TV and the cable box are responding to the same code. You likely will have to find different codes for one or the other.
Jan 17, 2016 | RCA Televison & Video
Remote with no code search button. TDE system # SKU#33201048 looking for the code for sanyo flat screen tv and direct tv cable box and Samsung blue ray player
If your Samsung remote does not offer some sort of code search capability you may only able to control your Samsung DVD player by pressing the DVD button to turn it on. It may be more practical to purchase an inexpensive universal remote and use it to control both your TV and your DVD player.
Dec 26, 2015 | Samsung Televison & Video
I need philips universal 4 digit remote codes
Not sure I can help. You might do well to call Samsung 800-SAMSUNG. But I have the codes that should work if you were hooking the Samsung to a Philips set top box or cable box. Perhaps they are the same? (And how lucky are you that you landed this jewel! I love this unit!
Aug 05, 2014 | Samsung DVD-VR375 DVD Recorder/VCR
FIOS cable /set top box doesn't turn Samsung tv on or off or adjust volume
Check it by setting with an other code to your device brand, from the setup code list of the remote control. If you wish to get more information, check these links. Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Dec 14, 2013 | Samsung TV Set Top Box Remote Control
Need code to program a samsung bn59-00700a remotr to control a motorola cable box. the code listed in the manual does not work and none of the other coded for cable boxes seem to work either.
it makes no diff what type of remote u have, u have tried all the remote codes for the cable box, not clear on this, have you done a "code search" with the remote? here are all remote codes for Motorola cable boxes, this is the most current list, one of them will work
0552, 0148, 0952, 0453, 0654, 0754, 0048, 0752, 0254, 0947
Jan 24, 2010 | Televison & Video
Remote code for a samsung tv rcr4258
  1. Find codes for each device and brand below.
  2. Press and "HOLD" CODE SEARCH.
  3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  4. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. Release CODE SEARCH.
  6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
Mar 22, 2009 | RCA Universal Remote Control
Codes to operate a cable box with TV remote
Try code 038. If that doesn't work try 039.
Aug 05, 2008 | Televison & Video
Universal remote
Codes for Samsung (one of them should work on your RCA remote)
006,011,014,015,019,027,036,037,077
Programming Your Universal Remote.
The remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes:
  • TV-000
  • VCR-000
  • Cable Box-000
  • AUX is programmed with VCR code 037
For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists:
Apr 07, 2008 | RCA Universal Remote 3 Device Remote...
Samsung BN59-00678A Remote Control Logo
32 people viewed this question
Jerry Greenberg
Jerry Greenberg
