Question about Samsung R Computers & Internet
I can't adjust the brightness of my samsung r439 laptop...what can i do??? pls help me...
fredcapra
  • 85 Answers
SOURCE: My laptop is Sony vaio vpcs111fm with OS of window
Go to the Sony web site. Go to support, and download drivers for the hotkeys. It sounds like the upgrade did not pick up all of the OEM features.
Posted on May 29, 2011
ziggy12
  • 105 Answers
SOURCE: unable to see the brightness symbol & volume
im not sure but i do mine by pressing fn button then pressing up or down
www.ziggy-links.com
Posted on Dec 14, 2009
  • 8909 Answers
SOURCE: Pci simple communication controller not
That is probably because it has lost a driver. Try rebooting, if that does not work browse Samsung.com for updated drivers.
Hope that helps.
Posted on Feb 26, 2011
  • 103 Answers
SOURCE: appearance of vertical red line
the graphis processor is separating fromthe mainboard due to heat and humidity, turn the computer off, press genly in about the middle of the keyboard then place an ice pack on the bottom senter of the computer this should reattach the processor to the board. Keep in mind that if the problem returns that you may need to open the computer and reflow the processor manually using a heat-gun.
Posted on Jun 30, 2011
ghost2233
  • 3606 Answers
SOURCE: i hv a samsung laptop
Hi, you can download the XP driver here:
http://www.samsung.com/in/consumer/pc-peripherals-printer/notebook/r-series/NP-R439-DA07IN/index.idx?pagetype=prd_detail&tab=support
Remember to unzip the file before installation.
Hope this will help you.
Posted on Aug 23, 2011
On my laptop screan it gon a bit dak and i ned help 2 fix this
Hi , I think your laptop brightness settings had been changed. So try this to increase and reduce the brightness , contrast. Select start-> control panel -> appearance & personalization -> display . There you will have options like Adjust brightness , Adjust resolution etc., on the left side of your window. You may adjust in this way.
May 20, 2014 | Samsung HCM422W 42" Rear Projection...
Can't use the webcam of this laptop,sumsung r439?
You need to install the driver/Software from the Web Cam manufacture website in order for the camera to work. Most of the camera from Microsoft will automacticly download and install. Some like creative or other brand you need to install the driver for it. You can go to the Web cam manufacture website and download the driver.
Hope this helped.
Feb 03, 2014 | Computers & Internet
Wifi driver for NP-R439
Here are all the drivers on SamSung's support site for this model. The drivers are for Windows 7 and XP.
http://www.samsung.com/ph/support/model/NP-R439-DT03PH-downloads
On the left hand side click drivers and then in the list look for the wireless driver for your Operating System. Windows 7 or XP.
For Windows 7 wireless
Windows 7(32bit,64bit)
5.60.350.21
2011.11.22
MULTI LANGUAGE
61.92 MB
Windows XP
Win XP
5.60.350.21
2011.11.22
MULTI LANGUAGE
32.9 MB
Oct 22, 2012 | Samsung Computers & Internet
Samsung monitor menu controls (contrast & brightness) inoperable
You're not supposed to be able to use the mouse to adjust these settings. These settings can only be adjusted from the buttons on the monitor!
Please read the user manual for your monitor for exact instructions.
Feb 19, 2012 | Computers & Internet
How do i adjust brightness in hp g60
Here's how to adjust the screen brightness for a laptop in Windows 7:
  1. Go to Control Panel -> Hardware and Sound -> Power Options.
  2. Click on "Change plan settings" for your laptop's selected power plan (either Balanced or Power saver).
  3. Now edit your plan settings by moving the sliders next to "Adjust plan brightness" at the bottom. You'll be able to change the brightness for when your laptop is On battery power, or when it's Plugged in.
  4. Once you've adjusting the brightness settings to your liking, then click on the 'Save changes' button.
Alternatively, here is another way: From the Windows desktop, hold the fn key and press the f7 key c00776226.jpg to increase or the f8key c00776225.jpg to decrease the brightness of the display. If using the function keys does not resolve the problem and you have a Lid Actuator on your particular model, check the movement of the Lid Actuator switch to determine that it moves freely and is not stuck. NOTE: The key numbers (f7 or f8 ) may vary depending on the notebook PC; however, the images on the keys should be similiar. If you reboot the PC after using the function keys to change the LCD brightness settings, the brightness may return to the default setting on some models, which is based on the power source-battery or AC. This is not an error. The notebook is functioning as designed. If the notebook returns to the default setting after rebooting on your particular model, use the function keys to change the brightness back to the desired settings.
Aug 23, 2011 | HP G60-120US Laptop
I have brought a laptop of samsung rv 509. i have installed windows 7. when i started windows my laptop brightness is low. but when i plug in power then brightness is good. how to solve it? i have used...
Samsung has a built in great power management. It will reduce power brightness to 50% or less if unplug from power cord. <<< it gives more times for power on the battery stays longer. BUT if you demand for some cases eg.PRESENTATION >>> go to CONTROL PANEL >>>power option >>> presentation. APPLY >>> OK
akee_akee@live.com
Aug 16, 2011 | Samsung RV511A01 Notebook
I want wifi driver for my samsung r 439 laptop.how can i download by internet?
You can get all drivers for your Computer at http://www.samsung.com/in/support/download/supportDownloadMain.do Just select PC & Office, then pick PC/Notebook/your model number. and it will come up with a list of all drivers for your laptop.
May 04, 2011 | Computers & Internet
Computers & Internet Logo
205 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
