Question about Zanussi FS1455W Front Load Washer
Smelly Washer Hi. I have a zanussi 1455W washer. I use a liquid ball to wash with. My problem is that the powder dispensing drawer always smell fusty and I have to clean it regularly with a dish washing brush. Anyone any ideas for getting rid of this problem?
    President:
  • 1,462 Answers
Dont't use liquid detergent - this is the cause of the smell. it is a well known problem. use powder in the drawer
Posted on May 14, 2007
How do you clean a Maytag Neptune top loading washer
Tip: Prevent a Smelly Washer With Powdered Dishwasher Detergent
I have a great tip for making a smelly clothes washer smell fresh and clean, given to me by a Maytag repairman. Simply run dishwasher detergent powder, not liquid, through your machine with no clothing in it, about once or twice a month.
It works and it is cheaper than the specialized products that do the same thing. Use the same amount you would use of laundry detergent for your particular machine.
Aug 16, 2015 | Maytag Neptune Washing Machines
Tip
Stop Washing Machine Smell, Mold, and Mildew
Your washer is not smelling so clean and you wonder first why it is like this and then how can I fix it?
With the popularity of the front load washer and the low water usage associated with then comes other problems. Because of the low water consumption the dirt grime and residue that would normally be totally washed away, some is left as a film in the washer. Cold water usage can contribute to this by adding to this film. The make up of certain commercial fabric softeners and detergents can make the problem worse by giving the bugs food. Animal fats in some products are great food for the molds and mildew.
Some washers also let a bit of water lay in them after the wash this gives moisture which also helps to grow molds and mildew. When you close the door tightly after washing, this traps all the water in the washer and prevents the rubber door gasket, the soap dispenser, and other parts of the washer from drying out.
Here are some things you can do to prevent these problems.
Always leave the door to your washer open after use.
Leave the dispenser drawer open also.
Use liquid detergents instead of powdered, they will leave less film
Use the minimum detergent possible to get your clothes clean, more is not always better.
Use fabric softener sheets in your dryer instead of the washer liquid.
Check that ALL clothing is removed from the washer.
Periodically wipe down the rubber door gasket and check for mold or stuck socks
Use hot water when practical, like when washing whites. This will help remove the film.
If you have a problem here is what you can do to help fix it.
Wipe everything down with a solution of vinegar water.
Pour vinegar into the dispenser drawers. Then add ½ cup of vinegar to your washer and run through a clean cycle with hot water.
You can periodically add the vinegar to your wash load to help keep things under control. This will naturally disinfect and clean your washer while you are doing your regular wash. This is especially good to use if you will not be using your washer for a few days again. The residue of vinegar in the washer will help to control the smell and mold formation.
If you are buying a new washer, do some research before buying. Some machines are more prone to this problem then others. A bit of research may help you to aoivd the headaches of having a washer with this problem.
on Jan 28, 2010 | Washing Machines
How do you use the tub clean?
Read these instructions carefully before
beginning the TUB CLEAN cycle.
Open the door and remove any clothing in
the wash drum.
Open the dispenser drawer.
Add liquid chlorine bleach or tub cleaner.
Some powder or tablet tub cleaners which
are manufactured for this purpose can be
used.
(NOTE : Do not add any laundry detergent
or fabric softener to the drawer when using
TUB CLEAN.)
- If using liquid chlorine bleach
Add liquid chlorine bleach to the bleach
compartment of the drawer.
(NOTE : Do not exceed the maximum
fill line and do not pour undiluted liquid
bleach directly into the wash drum.)
- If using powder cleaner
Remove the liquid detergent cup and
add powder cleaner to the main wash
- If using tablet cleaner
Add tablet cleaner to the wash drum
directly.
(NOTE : Do not add tablet cleaner to the
drawer.)
Close the drawer and washer door.
5
Select TUB CLEAN and press START.
NOTE : It is recommended that TUB CLEAN
should be repeated monthly.
If mildew or musty smell already exists, run TUB
CLEAN for 3 consecutive weeks.
After TUB CLEAN is complete or when the washer
is not used, leave the washer door open for better
ventilation and drying inside of the washer
Jul 05, 2014 | LG WM2701HV Washer
I do most of my shopping online and liquid bleach sometimes doesn't ship without breaking. Is it OK to use dry or powder bleach? I have the whirlpool cabrio top load large capacity model.
It should be okay to use dry bleach, if you follow the instructions on the bleach. Some bleaches require dissolving in water first, others can be used dry.
May 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Dispenser - which tray to use for liquid detergent?
Liquid goes straight into the wash before you put it on, you can get a liquid ball that you fill and put in with the wash, dispenser just for powder which goes in 2 or fabric softner.
Mar 01, 2011 | Hotpoint Ultima WF860 Front Load Washer
Wont take fabric conditioner clothes dont smell nice machine smells yucky
poor a bottle of bleach in the washer .....run the washer with no clothes...the blead should kill any mols or mildew causing the yucky smells......boil some water and poor it in the fabric conditioner hole, this should loosen anything clogging it...thanks
Nov 05, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
The rubber seal at the front of the machine has gone mouldy. I have cleaned it before with bleach but the mould comes back all the time
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Oct 21, 2009 | Bosch Nexxt 700 Series WFMC6401UC Front...
Smelly washing machine
IMPORTANT: Read thoroughly. DO NOT add detergent or other laundry products to this cycle.
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. If the bad odour persists, repeat the procedure 1 or 2 more times. This may be necessary if this is the first time you have run this cycle.
7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
8. Repeat the cleaning procedure monthly.
To maintain the washer freshness:
1. Use only HE High Efficiency detergent.
2. Leave the door open after each cycle to for better ventilation and drying of the washer interior.
3. Use warm / hot water in your machine unless the fabric you are washing requires cold.
4. Use the correct amount of fabric softener.
5. If your laundry room is damp, use a dehumidifier.
6. Clean the door seal of visible residue.
Oct 10, 2008 | Kenmore 24832 Top Load Washer
Zanussi FS1455W Front Load Washer Logo
134 people viewed this question
Top Zanussi Washing Machines Experts
jimorris77
Marvin
Marvin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
