Question about Dacor ECD230 Epicure Electric Double Oven
Dacor model# pc52305 beeping , displays F1 - Dacor ECD230 Epicure Electric Double Oven
abhishek33
  • 1239 Answers
SOURCE: dacor cps130 wall oven f1 error
hi The range timer is usually located in the control panel on top of the range. If you suspect the timer is faulty, don't try to fix it yourself. Remove it and take it to a professional service person for testing. Here's how to remove the timer:
Step 1: Remove the back service panel to the control panel and release the spring clips that hold it in position, or remove the retaining screws.
Step 2: Push the timer forward to release it.
Step 3: Remove the electrical lead wires from the timer housing. If, when disassembling the timer, you notice that the electrical wire terminals look burned, remove these leads and buff the leads and the terminal points with fine steel wool. Burned and/or dirty terminals can cause the timer to malfunction, but a good cleaning can solve this problem.
Step 4: Replace the old timer or install a new one of the same size and type, if this is necessary. Connect the new timer the same way the old one was connected.
Posted on Nov 06, 2008
localwonder
  • 6784 Answers
SOURCE: Dacor error codes
HI. the F-1 code is a System Watchdog Circuit failure code.
Press "Cancel", if beeping continues after 30 seconds, replace the main control board (also called clock or ERC).
Concerning the F-5 code. This is an oven temp sensor failure code. have it replaced asap. ((Check the wiring leading to and from the control and sensor for cracks and fouled structure. if the wiring is bad, replace the harness as well)),
Posted on Aug 01, 2009
TheMobilian
  • 8220 Answers
SOURCE: Dacor oven beeps and shows F1 code
-F1- Alarm “System Watchdog Circuit”
The system will detect a failure in the internal watchdog element relay circuits and will activate a
cancel feature. F1 will be displayed in the time digits and will beep until the cancel button or another
function is selected. An F1 failure could be detected in cook or time of day mode. With an F1 failure
the ERC is picking up a command to supply heat without receiving an input from the membrane. The
watch dog circuit is designed to prevent this.
If the beep continues after pressing cancel check the main control (ERC)
Dacor
Posted on Aug 20, 2009
reyjoshua07
  • 1157 Answers
SOURCE: dacor model ersd30 how do i fix an F0 error code
Hi dan8260,
If you're encountering F0 error code, it is due to a stuck function key. You need to replace the touch pad to fix this error. If the touch pad is part of the clock, you need to replace the clock or ERC.
Hope it helps.
Thank you for using FixYa.
Posted on May 18, 2011
ZJLimited
  • 17970 Answers
SOURCE: My Dacor MRE30S beeps and displays the F1 code. I
F1 error is, as Dacor describes it, a system watchdog circuit used to monitor the bake element relays for a possible failure such as a command to supply heat without receiving an input from the switch membrane. These element relays which are mounted on the ovens relay board turn the L1 and L2 line voltages on and off to the bake element. If either of these relays were to actuate without a key press, the watchdog should catch the operation and display an F1 error...
Once the error has been displayed, it is cleared with the cancel button, and should no longer occur, but if it does, the recommended repair is to check the ovens main control and replace as needed. Because this error was reoccurring, the control board was the likely candidate for replacement, but the completely intermittent timing of the error seemed to indicate something else in this range was amiss. Looking at the wiring diagram for other components which may be at fault lead me to the front of the range, and the item that was the real reason for these random errors.
The door latch mechanism is used during the self clean cycle to ensure the door remains closed and locked until complete. The latch contains two micro switches used to monitor the position of the latch motor allowing the control board to know the position of the door and latch. What was discovered is one of the switches had been shorting to the frame due to an excess buildup of grease and grime from years of use. This short circuit was being interpreted by the main control as a problem, thus the reason for the F1 error.
Check out http://www.dacorservice.com Click on "parts catalog" and it'll have parts break downs.
Posted on Jul 31, 2011
F1 error relay circuit failure
Hi This is the Alarm system watchdog circuit :
The system has detected a failure in the internal watchdog element , relay circuits and will atcivate a cancel feature. F1 will be displayed in the time digets and will beep until the cancel button or another funtion is selected. An F1 failure could be detected in cook or time of day mode. With an F1 failure the ERC is picking up a comand to supply heat without receiving an input from the membrain. The watchdog circuit is designed to prevent this.
If the beep continues after pressing cancel check the main control ERC board.
Dec 09, 2011 | Dacor MCS130 Millennia Electric Single...
What does a beeping sound with F1 symbol mean?
Error F1 means that your Dacor Oven indicates element relay circuit failure. To resolve this issue the control board should be replaced as it has gone bad.
Good luck.
May 13, 2011 | Dacor ECD230 Epicure Electric Double Oven
I have a Dacor ECS130 and when we turn it off the F1 code comes up and it beeps forever. i tried uplugging the membrane switch from the control/clock module (with the power off) and there is no F1...
Hi
Thanks for using FixYa. Error F1 in your Dacor Oven indicates element relay circuit failure. To resolve this issue the control board should be replaced as it has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 26, 2010 | Ovens
Dacor
Aug 20, 2009 | Dacor ECS130 Epicure Electric Single Oven
PCS 130 Keypad
Dacor probably won't cover anything. F1 is either the touch pad or ERC (clock). If it stops beeping when the touch pad is uplugged from the ERC then the touch pad is the problem if not it is the ERC. Call Dacor Customer service to get a price on the parts and to voice your displeasure.
May 22, 2008 | Dacor PCS130 Preference Electric Single...
Dacor error codes
Apr 25, 2008 | Dacor ECS127 Epicure Electric Single Oven
Dacor cps130 wall oven f1 error
According to the manual, this is an element relay circuit failure. Call the tech.
Dec 04, 2007 | Ovens
Dacor ECD230 Epicure Electric Double Oven Logo
Top Dacor Ovens Experts
Dan Webster
Dan Webster
ashburton
Jaime Hernandez
Are you a Dacor Oven Expert? Answer questions, earn points and help others
