Question about Motorola Mobility DEFY MB525 QUAD BAND ANDROID 3G HSDPA 5MP BLUETOOTH UNLOCKED GSM MOBILE PHONE
I can pair to my Holden cruz, but it won't connect. It use to but has stopped doing this a few days ago. Connected with my daughters phone when we tried it.
Iphone6 states "connected" to JBL Charge but no sound. Worked fine up until a few days ago. Both show paired.
Are they connected or paired now? Make sure you don't have any other device near that may have Bluetooth on. Like a laptop, PC,or tablet. Try forgetting the device, and reconnecting. If this fails make sure your phone isn't on wifi and cellular. If this all fails. I imagine its not the fault of your transmitter, but lies in the fault of your reciever, the JBL flip. Also, is it fully charged and is the speaker holding a charge? I'm a small Bluetooth speaker junkie, and I'm sorry but I am not impressed with these at all. There are much cheaper, and better made out there, than this one.
Apr 04, 2015 | JBL Charge Wireless Portable Speaker for...
Digix BT-100 Portable Bluetooth Wireless Speaker says not connected when I try to pair it with my ipod.
Kathryn,
The speaker can only pair with one device. I had the same issue pairing it with my phone and then to my iPad.
You simply need to unpair it with your daughters iPod by turning off the bluetooth on that iPod, turn off then back ON the speaker and connect again to your own iPod by turning on the Bluetooth, Selecting BT100 from the list and wait for it to say CONNECTED (not paired).
Hope this helps!
Nov 07, 2013 | Digix BT-100 Portable Bluetooth Wireless...
Having issues syncing my Uniden BT112 Bluetooth to my BlackBerry Bold. I used this Bluetooth with another telephone and don't have any of the old packaging. I don't have a pin number. Help!
Please follow the correct instructions below to successfully pair your headset with the phone.Make sure that the headset is sufficiently charged before pairing.
Charge the battery
Before using your headset, charge the battery for at least 8 hours. Charging the battery completely (and keeping it charged) will help you get the longest possible talk and standby time out of the battery.
Pair the headset to your Bluetooth phone
Pairing is like "introducing" two Bluetooth devices and giving them permission to connect to each other. If you want to use the headset with more than one phone, you need to pair it with each phone separately. Once a phone and the headset are paired, they can connect automatically whenever they detect each other.
1. Make sure the headset is powered off and the power adapter is not connected (you can't use the headset while it's charging).
2. Press and hold Power until the LED flashes alternating red and blue. The headset is in pairing mode and should be visible to other Bluetooth devices.
3. On your phone, start a search for Bluetooth headsets or handsfree devices. (This process may take several seconds, and it will be different for each phone; see your phone's manual for detailed instructions.)
4. Your phone should discover a device called a BT108, BT108 headset, BT109, or BT109 headset, When your phone asks if you want to pair with this device, answer yes.
5. When your phone prompts you for a PIN code or password to pair with the BT108 or BT109 enter 0000.
6. When the headset is paired, the LED turns blue and flashes every 3 seconds. Your phone might display a confirmation message, also.
7. Your phone might ask if you want to change the headset's name; generally, you should only change the name if you have more than one BT108 or BT109 headset that you use with this phone.
Connecting to your phone
Most phones connect to the headset as soon as you pair it; if yours won't, turn the headset off and back on. If headset still won't connect, check your phone's owner's manual for additional Bluetooth information.
Once the headset is paired:
Whenever you turn the headset on, it will automatically try to connect to whatever device it was connected to last.
If the headset loses the connection (e.g., if your phone is out of range), it reconnects automatically. To manually reconnect, press Power.
If the headset goes more than 1 hour with no connection, it automatically turns off.
If you need further assistance please leave me a reply.Hope you are satisfied with my solution.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
TinuAlbinAlex
Jun 15, 2011 | Uniden BT-108 Bluetooth Headset
I have a Avaya 2410 corded phone connected to a plantronics cordless receiver. When someone calls me it rings once and stops, and the call immediately goes to my voice mail. This is something that just...
Everything I have read on the voice mail problem refers to resetting that feature on the phone (the headset is just an innocent bystander). If you don't have the manual, you can contact Avaya for assistance.
Good luck from Headsets Direct!
May 11, 2011 | Avaya 2420 Corded Phone
I bought my daughter the Kodak EasyShare C143 digital camera for Christmas and it wasn't until a few days ago that she first tried to upload the pictures she took with it onto our computer. When she uses...
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Feb 20, 2011 | Kodak EasyShare C143 Digital Camera
SET UP BLUE TOOTH ON BUICK ENCLAVE
I have a 2009 Buick Enclave...a few months ago out of the blue, my blue tooth does not work...the phone rings in, but when I press talk on steering wheel...it goes quiet...it's connected but they can't hear me and I can't hear them....the phone worked fine, then one day it just started acting goofy...any suggestions? I have deleted, paired, unpaired!
Nov 01, 2010 | 2009 Buick Enclave
Motorola bluetooth H500
A few days ago I paired my razor to my blue tooth1.gif and t was working just fine but the next day it wouldn't work and every time I tried to connect it it would say I NO DEVICES FOUND. I tried reseting the phone but that did not work and I don't know what to do. Can you PLEASE HELP ME!
Jan 27, 2008 | Motorola Mobility H500 Wireless Headset
Motorola Mobility DEFY MB525 QUAD BAND ANDROID 3G HSDPA 5MP BLUETOOTH UNLOCKED GSM MOBILE PHONE Logo
15 people viewed this question
Top Motorola Mobility Audio Players & Recorders Experts
David Payne
David Payne
ka4iup
ka4iup
john h
Are you a Motorola Mobility Audio Player and Recorder Expert? Answer questions, earn points and help others
