Question about Ricoh Aficio Mp C2800 / Mp C3300 / Mp C3330 Black Toner Cartridge 841276
Sc 878 error how can i resolve it - Ricoh Aficio Mp C2800 / Mp C3300 / Mp C3330 Black Toner Cartridge 841276
  • Mohamed kassem Nov 10, 2017
    How can solve that error sc 878-01 ?
HOW TO RESOLVE C8 ERROR IN RICOH SP 111 PRINTER
Ricoh SP 111 with C8 Error:
The C8 is a fuser error. As a safety feature, the machine will be disabled (to prevent fire and what not.. )
The service manual says that SC542 is caused by a too low fuser temperature, after 5 readings.
Since the hot roller was 5°C below the reload
(operating) temperature the fusing thermistor is deformed or out of position or full of gunk (toner residue). Or there may be a piece of paper between the sensor and the hot roller.
The fusing lamp harness can also bee loose, broken or defective.
The fusing unit can be defective
After servicing the machine to solve the problem, the service
technician must execute a "Fuser SC Reset". Otherwise, the machine
will continue to issue this SC code and cannot be operated.
Executing Fuser SC Reset
1. After correcting the problem, open Smart Organizing Monitor.
2. Enter the service mode to display the Service Mode screen.
3. On the Service Mode screen, click [Fuser SC Reset]. This releases the fatal fusing error
which locks the machine.
4. Select "On" for Fuser SC Detect. This setting shuts down the machine if three successive
paper jams occur in the fusing unit.
Jul 27, 2017 | Ricoh Office Equipment & Supplies
Richo afico 5002 code sc 878
1. Improper firmware update.
2. SD Card size greater than 2 GB used.
3. Multiple ROM data folders in SD Card.
4. Improper Java firmware update.
5. Power failure during firmware update.
6. Power line issues on the outlet.
Replacement of the Controller Board is necessary in case SC Code 878 occurs.
Apr 11, 2017 | Ricoh Aficio Office Equipment & Supplies
What is error code 460 on a Ricoh Aficio SP C811Dn
SC 460 The problem may just be dirty separation components that a cleaning may resolve. The code refers to the following:
High voltage power: Separation bias output error
The status of the power pack is checked every 20 ms. This SC is issued
if the EGB detects a short in the power pack 10 times at D(ac).
1. Replace the high-voltage supply cable.
2. Replace the high-voltage power supply unit
3. Replace the IOB.
Aug 26, 2014 | Ricoh Aficio Office Equipment & Supplies
Need setting heather unit but not going out sc code
First resolve the sc code error defect,after you can acces settings.
Dec 27, 2013 | Ricoh Aficio 450 Copier
Sc 878 error how can i resolve it Sc 878 erro como posso resolver
Bad controller board (where the print cable plugs in) try reseating
Nov 25, 2013 | Ricoh Aficio MP-C305SPF Color Copier :...
Sc 536 error code
Ol? tudo bem! o erro funcional (SC 536) trata-se de um cooler ou do sensor de temperatura que parou de funcionar levando o sistema a parar de funcionar por medida de seguran?a, infelizmente trata-se de um daqueles problemas que s? a autorizada resolve.
Jan 14, 2013 | Ricoh Toner for Aficio 1060, 1075, 2051,...
Eror sc 878
sc 878 error what is the solution
Aug 07, 2012 | Office Equipment & Supplies
When i start ricoh ft7660, an error appears code sc 402. what can i do for resolving the problem?
sc-402 - transfer current leakage
Transfer belt defective . poor contact at transfer bias roller
Jun 24, 2010 | Ricoh Office Equipment & Supplies
I am getting an error code SC 534 on my Ricoh Aficio MP 6000.
The best I can find is that this is related to a malfunctioning cooling fan, I cannot find that specific code for your model, but all other 534 codes from that manufacturer are related to cooling fans
B010/B188 SC 534 Right fusing pressure motor HP error 1 - HP sensor defective
B010/B188 SC 534 Right fusing pressure motor HP error 1 - IOB defective
B010/B188 SC 534 Right fusing pressure motor HP error 1 - Motor defective
B010/B188 SC 534 Right fusing pressure motor HP error 1 - motor drive bound
B132/B200 SC 534 Duplex exhaust fan error - Paper exit fan motor M28 defective, indexed as 146, electrical component layout.
B132/B200 SC 534 Duplex exhaust fan error - check and or replace fusing exhaust fan / paper blocking fan
B132/B200 SC 534 Duplex exhaust fan error - replace duplex fan motors M29 or M30
B222/B224/G878 SC 534 2nd duct fan error - replace fan motor
B230/B237 SC 534 Fusing exit sensor fan error, BICU defective
B230/B237 SC 534 Fusing exit sensor fan error, Fan defective
D014/D015 SC 534 Duplex unit fan error - Fuser exhaust fan blocked or has paper in it.
D014/D015 SC 534 Duplex unit fan error - Duplex Unit fan obstructed
D014/D015 SC 534 Duplex unit fan error - Fan harness disconnected or damaged
D014/D015 SC 534 Duplex unit fan error - Fuser unit connector has paper obstruction
D014/D015 SC 534 Duplex unit fan error - Replace duplex fan
D023/D025 SC 534 Second duct fan error - replace the 2nd duct motor
D023/D025 SC 534 Second duct fan error - replace the IOB
D027/D029 SC 534 Second duct fan error - check connections and harness to fan
D027/D029 SC 534 Second duct fan error - replace fan motor
D037/D038/D041 SC 534 Fusing rear fan error: Check or replace harness
D037/D038/D041 SC 534 Fusing rear fan error: Replace BCU board
D037/D038/D041 SC 534 Fusing rear fan error: Replace fusing rear fan
D037/D038/D041 SC 534 Fusing rear fan error: Replace the DRB
Jun 13, 2009 | Office Equipment & Supplies
Gestetner DSm615 giving error SC:552,How do i clear it
Are you sure of the code? I don't have the exact manual for that, machine but the number seems strange. "5xx" errors are usually related to the fuser, so could be a bad lamp, thermistor, or fuse. see note to reset (if there is not a problem) as follows:
There are 2 levels of service call conditions.
Level Definition Reset Procedure
"A"
To prevent the machine from being
damaged, the SC can only be reset by a
service representative.
The copier cannot be operated at all.
Enter SP 5-810 (SC code reset) and
select “1”. Then hold down the Original
type key and the OK or ! key at the
same time (this does not require the
main switch to be turned off and on).
Feb 02, 2009 | Gestetner DSm615 Digital Imaging System
Ricoh Aficio Mp C2800 / Mp C3300 / Mp C3330 Black Toner Cartridge 841276 Logo
613 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
