Question about Hisense Televison & Video
The TV is in 480p how do I get it in 1080p. I have an HDMI cord from the TV to the FIOS cable box.
Agent Aaron
  • 265 Answers
SOURCE: Panasonic 1080p Plasma TH-42PZ80U Home Theater Setup Question
Hey Gamer1827,
While I personally can't provide you with any model-specific home theater system recommendations, there are a couple of common ways that you can generally configure your home theater.
Connecting several devices directly to the HTIB system may typically allow you to minimize the number of remote controls necessary, as long as the HTIB system supports the use of a universal remote. Should you not necessarily care if you have to change back-and-forth between two remotes however, you may have a wider variety of possible configurations available.
In order to use only HDMI cable connections to set up your home theater, you most likely would need an HTIB system with three HDMI ports: one for your TV, one for your PS3 and one for your cable box. Each device would require a separate HDMI cable running between it and the receiver. This option (in theory) would allow you to use one universal remote to control each device, assuming that they are all compatible with the same remote.
Another common configuration you might wish to try requires you to connect your cable box and PS3 directly to your TV. By doing so however, you might limit yourself to using an optical digital audio cable to make the connection between your TV and many HTIB systems. In this configuration, the cable box and PS3 would again have their own separate HDMI cables, while the optical digital audio cable would need to be run from the Digital Audio-Out port on the back of your TV to the Digital Audio-In port on the receiver. This option essentially treats the HTIB system as an expansion device, instead of the center of your home theater configuration.
Should you need any additional information or suggestions, remember that you may always speak with a sales representative at your local Best Buy™ store for further assistance.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Posted on Jun 12, 2008
mistersony
  • 320 Answers
SOURCE: Sony HDTV flat - no picture with HDMI cable and Verizon FIOS box
Probably a handshake problem with the cable box. It is common for cable boxes to have HDMI handshake problems. Hook the box up using the component cables and you should be fine
Posted on Oct 18, 2008
jsinex2421
  • 62 Answers
SOURCE: No surround sound when attaching hdmi to TV
Try running the optical TOSLINK cable from the TV to the receiver. If the TV doen't have a digital optical output, then try going into the menu on your cable box and setting the audio output to the digital optical out. Also check your TV menu and make sure NETCOMMAND is diabled. Some of your newer HDTV have Netcommand that allows the TV to control other devices through the HDMI cable.
Posted on Jan 10, 2009
SOURCE: Philips TV HDMI CEC EasyLink tries to control Cable set top box
I finally found a fix to this! YAY. I thought I might have to return the TV. I have the Phillips 42PFL5603D, but should work for other models.
On the TV press menu picture settings---picture---dynamic contrast (turn off) AND active control, turn off
If you have Comcast Moto box: on the Cable box go menu--->setup--->cablebox set up---RF BYbass set to ON
If you have a non-Comcast Moto Box, I'm sure there is an RF bypass setting in the menu. You'll just have to look for it. Another fix was close saying to only turn of the active control, but it took all 3 of these for it to work consistently. The latter let it work for all of 30 seconds.
Posted on Mar 13, 2009
  • 4 Answers
SOURCE: My HDMI 1 input is set to display in 480p not in 1080p???
I think you have to change the settings in your HD box. Look on the diplay window of your HD box, if it says 480 there, thats where you need to change it so it will change then on your TV.
Posted on Apr 14, 2009
Pioneer elite 2006 50" tv How can I change from
You can't change the resolution on the television itself. You change the resolution on whatever you have connected to the television. Let's say it's a cable box or a blu ray player you've got connected to the television. First off you have to connect it to the television with a component (green, blue, red, white, red) cable or an hdmi cable. Then you make sure it is only connected to the television with either a component cable or an hdmi cable. This may sound ridiculous but there are some people that have their cable boxes and blu ray players connected to their televisions three different ways ( an hdmi cable, a composite cable, and a component cable) when they only need to have it connected one way.
Select the proper input on the television. Set the cable box or blu ray player's resolution to 1080i or 1080p (in the case of the blu ray player if it the tv will allow it).
Apr 05, 2011 | Pioneer Elite PRO-1140HD 50 in. Plasma...
I own an insignia 42"
The TV resolution is set by the video sources, not at the TV, in this case, your Dish network box is the one that is sending out 480p so the TV will display what it is being fed with.
What does Dish TV say aboyt this problem? How about the setup menu on the Dish network box?
Your TV works the same as your PC monitor, except that your monitor does not have a tuner, you adjust the resolution at the PC not at the monitor. 480p in = 480p display.
Please leave rating if it helps.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Jan 31, 2011 | Televison & Video
New TV is hooked up from satelite cable via HDMI wire. We have it plugged in the HDMI port # 1. When we turn on the cable, the little box pops up saying HDMI and 480P. I ready the specs for the TV and...
jason_janick
You have settings in your TV and satellite receiver to set the resolution for the picture. I would first go into the TV settings and use 1080p for the TV resolution. Also, in the receiver setting, you have the HDTV setting. From the main menu, press 6 (System Setup) and then 8 (HDTV Setup). For TV Type change to 1080i. The Aspect Ratio should be 16:9. I hope this helps.
Ray Calo
DISH Network
Dec 28, 2010 | Element Electronics PLX4202B 42 in. Plasma...
My new set displays only 480p SD on all my HD channels. Am I missing some settings in the menu's or is something more sinister going on? Any help would be greatful, I'm drowning watching sports!
hi,
u can enjoy full hd 1080p video through only ur tv inputs as 2 component video and 2 HDMI. the tv is seted to receive videos up to the resolution 1080p automatically (need not have any setting). just check the output of ur cable box or BD player, is it outputs full hd. if u are using the tvs internal tuner u will only get 480p.
ok
Dec 20, 2010 | Sony KDL40EX400 40 in. HD-Ready TV
How do I go from 480p to 1080dpi on my 65inch HDTV
If you're using an HDMI cable your display will automatically adjust the settings based upon the video source. Make sure that your source is capable of outputting 1080p. If it's an HD Cable Box or DVR, the maximum resolution it can display is 1080i. If you have one of these HD boxes, set it to only display 1080i as there will be a delay every time you change channels from a channel that is not naturally at 1080i.
If your source is a standard DVD player, it can only display images in 480i (or 480p if it is Progressive Scan) and therefore your TV will display the picture in 480 resolution. If your source is an upconverting DVD player it will display up to 1080p however, Keep in mind that DVD's are in 480 resolution and that regardless of upconversion (or upscaling, though improved, the picture will not be in HD.
The only way to achieve a true 1080p (not dpi... that's dots per inch... that's a printer term. The "p" is for Progressive Scan as opposed to an "i" for Interlaced) is from a 1080p source, i.e., a Blu-Ray disc player playing a Blu-Ray Disc with the use of an HDMI cable. Component Cables can achieve 720p/1080i only with your TV as it does not support 1080p over component cables.
As an aside, there are some media players that support 1080p output and some DirecTV Boxes and DVR's d oas well for 1080p Pay Per View movies.
Nov 23, 2010 | Mitsubishi WD-65733 65" HDTV
How do you set our vizio to 1080p it is currently set at 480p
You really don't think you set the TV for this, if the TV supports 1080p and the device was 1080 capabilities then the TV will recognize this. If you using a cable box make sure your using the HDMI port on the cable box. I have seen in the past cable companies just using the component ports.
Jan 03, 2010 | Vizio GV42L 42 in. LCD Television
I Have A Vizio 32LCD and my problem is i am trying to get the PS3 to play with the HDMI I have a HDMI cabel hooked up to the hdmi input on the back of the set and it is hooked up to to the HDMI input on...
Adjust the system's video output settings. Select the best output settings for the TV in use.
1. Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2. Select (Display Settings) under (Settings) in the home menu.
3. Select [Video Output Settings].
4. Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1
HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p
Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i
Composite / S Video *3 480i 576i
AV MULTI / SCART *4 480p / 480i 576p / 576i
*1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5. Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
6. Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
7. Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
8. Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the button.
9. Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see (Settings) > (Sound Settings) > [Audio Output Settings] in this guide.
Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
Mar 25, 2009 | Proscan 42LA30H 42 in. LCD Television
HDMI output from AVR-4806
You say your connected from the DVD to the Denon with an HDMI cord and the Denon to the TV with an HDMI cord and you get no DVD video? can you get the Denon setup menu? if so change the res. output on the DVD to 480p, 720p or 1080i but not 1080p
Feb 15, 2009 | Denon AVR-4806 Receiver
Picture is not good
Good choice on the TV. I'm getting the same TV real soon.
I've been with Directv for over 7 years. And they have upgrade the boxes alot. Just wait until you get your new box the H21. It will be the difference between night and day.It looks great with the 720p TV that I currently have now.
Right now your PS2 and the old Directv box is only putting out 480p. Which will look ugly on the 1080p. You'll have to wait until you upgradethe box and use HDMI cords. PS3 puts out 1080p.
Look at the Directv web site, they should give you a big discount on the upgraded box for being with them for so long. They did for me.
Feb 07, 2009 | Philips 47PFL7403D 47 in. LCD TV
Televison & Video Logo
127 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Electro Med Services...
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
