I have a 40in. Apex flat screen tv and dont know how to program for digital channels or if i have to buy a digital converter box
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Unless it has a digital tuner built into it you will if using it need a converter especially if using an antenna.
Posted on Oct 26, 2012
  • 4234 Answers
SOURCE: analog to digital conversion on Aquos?
First of all, the change is actually goping from analog over-air broadcasting to a digital signal. Second, if you have cable or satelite, you don't need anything. The only time a converter is required is if you use rabbit ears or an external antenna. In your case, the TV DOES have a digital tuner so you DO NOT need a converter in either case.
Dan
Posted on Sep 23, 2008
pilot210
  • 39 Answers
SOURCE: Apex Digital TV Model: 1919. Worked fine for a
Power supply issues or shorted horizontal output transistor. Probably not worth having repaired unless you DIY....
Posted on May 18, 2009
  • 814 Answers
SOURCE: Does my Insignia come digital cable ready or do I need a convertor box?
Yes you do need a digital converter box to get the digital signals converted for the analog television. The television is not set up for digital signal reception. For more information on this problem and technical help you can got to the Insignia website.http://www.insignia-products.com go to the customer support section and tell them the model number of you television and about the question of needing a digital converter box.You can also call them at their customer support telephone number 1-877-467-4289 and give them the same information. They will be able to explain the need for the converter box. I hope this information helps you with your problem.
Posted on Jun 03, 2009
  • 92 Answers
SOURCE: olivia 42'' flat screen and cant get any cabel channels
make sure that you're not using a cable box. then when you do the channel scan, make sure that you pick cable instead of antena.
Posted on Jun 18, 2009
SOURCE: built in tuner not working since digital transition
I do not know if you will get this message but if you do. Here goes. The protron PLTV3250 does indeed have a digital tuner that can be used with an over the air antenna. You need to push "source" on the remote until DTV is selected. With this selected and your coaxial cable from your antenna hooked up to the digital connector (not analog) on the back of this tv you can then press Menu and you will see a totally different looking menu that you are probably not used to seeing and then from there you can do an auto scan for the digital channels and it works great. I have rabbit ears hooked up to this Protron PLTV3250 and this has a beautiful picture. Far better than the picture I get from just the standard digital Directv receiver. You do not need a seperate digital tuner box to use with this TV. It does indeed have an ATSC digital tuner and it works great. You probably are selecting Source "TV" in the menu and that is not what you select for this TV to use the Digital Tuner. You need to select DTV from the source menu. Good luck and please let me know if you already knew this or if this helped you. Thanks, Tom
Posted on Dec 19, 2009
How do I get channel with my Dynex televison?
Yes all over the air channels are now digital. Make sure that your TV is on the correct source. You can get a decent converter box at Walmart for around 20 to 50 dollars
Feb 02, 2015 | Dinex Dynex DX-LCD26-09 26 in. HDTV-Ready...
I have an Apex AT2402 TV and bought a Magnavox DTV Digital to Analog Converter box , and I only got 3 channels after the channel search. I tried it 2 more times with 2 different antennas I had and it
Digital signals don't come from antenna. They come from the internet, or from a digital satellite receiver.
Then when you get the digital signals, you have to pay the provider for the channels you want to receive. As long as your provider does not know and did not sell you any channel you wont be seeing one.
Jan 25, 2015 | Apex Digital AT2402 24" TV
I use an RCA box. Never had any problem.
How far away are the television broadcast antennas?
If they are farther than 40 miles, that may be the problem.
Hope this helps
Apex digital250A digita tv converterl
The outside antenna gets threaded onto the RF connector that says antenna in. Then either connect another RF cable to the tv and select ch 3 or 4 (switch on back of box) or use the yellow,red and white cable to the tv. If you used the three cables use the remote to select the input you used. Just advance the channels until you find the picture. If you used the RF cable, just tune to channel 3 or 4 whichever you used. Now do a channel scan with the remote that came with the converter. Once that is done you will have to use that same remote to change digital channels.
Jan 01, 2014 | Apex Digital LD4088 LCD TV
No video from an Apex digital converter box to TIVO
You may have to set the channel 3/4 switch on the lower right rear of your TiVo to match the output setting of your Apex converter. If your Apex converter is equipped for L/R audio and video output you will get better results using a three-conductor cable to connect to your TiVo.
Dec 08, 2013 | Toshiba DVD Recorder AND Series2 TiVo...
Dont remember the code for the remote to my television
Hello
Try with these codes. These codes are of universal remote control with Apex Digital.
015 226 037
May 10, 2011 | Apex Digital AT2702 27" TV
I have an APEX, model no AT2708S, s/n DF282374776, MFG no D128C3SV2A237477 that i purchased new several years ago. Will I need a converter to access over the air channels now?
Yes,this tv is an analog tv,free air tv channels are all digital now.Tries walmart,Target stores,might still sell these digital converter boxes.Not,tries websites like Amazon.com,Ebay.com they still sell these converter boxes.
Nov 25, 2010 | Apex Digital AT2708S 27" TV
We have an apex tv in our 1995 rv it comes on with a blue screen and channel 44 with air under it and if i put in any other local station is does same thing air
This TV does not have a digital tuner and since the digital transition now requires a digital converter box to receive over the air television. The name may have made this a little confusing seeing how the manufacturer's name is "Apex Digital". I hope this helped.
Good Luck....
Jan 17, 2010 | Apex Digital AT2008S 20" TV
Tv digital
You will need to purchase a converter if you do not have sat or cable and desire to bring in off-air channels...accordianman
Jan 13, 2008 | Apex Digital AT2702 27" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
