Question about Ryobi Garden
Ryobi bc 26 wont prime
Wont prime
  • Ryobi Master
  • 7,482 Answers
Hi joeytamayo72
1...Make sure your fuel tank is full
If it is then you have a problem with a cracked fuel line, or trash under the float valve of the carburator.
I will give you some things to do and check
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Also be sure to check and clean your spark arrestor in the exaust,if you have one installed on your engine.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of chainsaws and weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor or take a pictue for later reference.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil if your using a two cycle chainsaw or weedeater with the oil to the right mixture...too much oil as it can cause hard starting and excessive smoking.
If the chainsaw/trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Note:
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indention in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Bud
Posted on Oct 27, 2012
I would like a new charger Ryobi bc-1807t charger and 2 batteries. or a repair to my charger
home depot -lowes -most hardware stores--go online to buy the replacement for repair do a search for tool repair store in your area but might be cheaper to do replacement
Sep 09, 2016 | Ryobi Drills
New ryobi wont start
Be sure that you have the correct mixture of gas and oil. Prime the carburetor, adjust the choke, then pull the rope. Sometimes initially you may need to do the priming processes several times.
May 18, 2014 | Ryobi Garden
I have a Ryobi set ( elec saw, jack saw, tourch and drill,but my battery charger has gone kaput! I will like to buy a new battery charger BC-144T so I can use my Ryobi set. Where I can buy a new battery...
I checked a couple sites and would suggest calling RYOBI parts supplier at 1-877-545-4099 to ensure that you get the correct charger. They might ask you what the model nnumber and the voltage and type of battery so have these numbers handy. Let me know if you need more assistance.
Jun 15, 2011 | Ryobi Multi-Volt Battery Charger
Spool retainer wont come off. ryobi bc-30
Cambio de tanza en Forest Garden BA 634
Jan 02, 2010 | Ryobi Garden
I have a Ryobi BC 30 trimmer. It runs fine but
Are you using the proper size line? Check the ends of the spool. It will give you the size you need. Also while you are checking, locate the arrow that shows the direction to wind the line. Hope this is of some help...Lee
Oct 05, 2009 | Garden
MY RYOBI BC 30 WILL NOT RUN WHEN I SET TO C FULL
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance, just let me know.
Jim
Jun 29, 2009 | Ryobi Garden
Garden Logo
122 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
