Question about Electrolux EW1000i Front Load Washer
Leaking water Machine leaks water which appears to come from under machine, when filter has been cleaned out
  • Official Brand Answer
  • 4,342 Answers
I would suggest cleaning out the coin or filter trap to see if debris has clogged the drain lines. This may or may not be specifically for your model, however these are generics instructions that I found.
To check for a restriction in the drain line you will need to follow the steps below:
1. Unplug the washer
2. Pull the washer out to tilt it back so you can
reach the screws below the front panel and
remove it. (You will need something to catch
the water once the hose is removed from
the bottom of washer)
3. Loosen the bolt with the sliver clamp on the
bottom of the washer. The water will begin to
come out while your loosening the clamp. (Do
not remove any GREEN clamps)
4. Once the water is out, you can stick your hand
inside the hose to clean it out.
If any proves to be ineffective contact a professional so they can properly and accurately diagnose the unit for repairs. Unit could possibly have a damaged/cracked tub, a leak in the drain lines, or the water valve.
Posted on Oct 31, 2012
SOURCE: water leaking from washing machine,
check the outer tub for corrosion or cracks.
Posted on Dec 16, 2008
  • 91 Answers
SOURCE: Washer Empties Immediately
sounds like you may have a hole inside the inner tub, depending on the model an the labor might be cheaper to buy a new one, i priced one for my old kenmore an was told 150 DLS. AM IN chicago, but i took it apart found the hole an sanded the hole with some sand paper, used a little piece of plastic patch looks more like a window screen an then used about 3 layers of JB weld an it fixed so far, is been working for over 6 months, knock on wood........lol.............good luck..........
LEAVE SOME FEED BACK LET ME KNOW!
Posted on May 28, 2009
SOURCE: washing machine wont drain have cleaned filter
the waters not coming out the mechine
Posted on Dec 19, 2009
AGUSYUSTIARA
  • 116 Answers
SOURCE: Have an electrolux front loader. Water
d8715b1.jpgyou have to replace water inlet valve, may be the seal has leak or broken..hopefully help.
Posted on Oct 18, 2010
hattonhall
  • 349 Answers
SOURCE: My Electrolux Washing machine wont
There may be a hidden blockage. Try putting a garden hose into the outlet pipe, tightly gripping the joining point of the hoses and turning on the water briefly. This can sometimes clear things.
Check also that when the machine is set to the "Drain" position that you can hear the whirr of the drain pump motor. If you can, then the electrics are intact and the pump impelllor inside the pump may have come loose on its shaft or be jammed with a small foreign object. It would be necessary then to remove the pump and dismantle it, or just replace it with a new one.
As always I warn non-technical people to beware of attempting repairs. Not because they may not be mechanically apt...........it is more about them not being used to the Strict Self Safety Disciplines that experienced servicing personnel have in place that protect them from possible injury or even electrocution.
It is simply not worth risking life and limb by trying to avoid the cost of a professional service call after all a life is surely worth much more than that.
Importantly ALWAYS unplug any appliance from the power point before doing anything !!
Posted on Jun 29, 2011
Bosch avantixx front loader leaking underneath machine? machine only 2 years old
  • You will find a small door on the front bottom of the washing machine.
  • Open it.
  • Unscrew the filter and rinse it with running water.
  • Put it back in place and repeat the above steps in reverse order.
This should solve your leakage problem.
Aug 03, 2014 | Bosch Washing Machines
My machine is leaking from under the washer. It is almost three years old and has never done this before. Drain pump filter is clean and hoses going to and from the machine appear to be in good...
Unplug the machine, Take off the back access panel cover and see if you can see anything... Just be careful inside of cabinet has lots of sharp edges and such. Let us know if we can help with anything else
Nov 03, 2010 | LG WM2016C
Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine: my hoshizaki under the counter ice machine gradual...
Check condenser coil which is the coil on back with fins, sometimes with metal.mesh filter. If dirty or clogged up clean filter, blow out with air or brush and rinse out, careful not to bend fins. Sounds like issue to me. Unless the dump valve may be leaking by
May 18, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Loads of slimey grey water in filter drawer and horrible smells
First of all, you need to confirm if the leak is from the filter or the pump.
You can replace the filter seperately to the pump.
If you replace the filter, and it still leaks, then you are going to have replace the pump.
I would suggest that that you check and clean if needed the outlet pipe where the water enters the outside waste pipe.
Make sure that you do a boil wash periodically, to ensure that the drum and other internal parts are clean.
Clean the door seal and dry after each wash, it helps to leave the door slightly open
Please leave any comments that may have as regards to my suggestions.
Thankyou.
Nov 25, 2009 | Washing Machines
I have a Saeco Vienna Deluxe Model. We have been experiencing water leaking from the machine. It leaks under the tank and floods the counter or leaks into the spent coffee disposal bin. I removed and...
If it leaks under the water tank then you have to replace the gasket in the machine where the water tank inlet are.
If you have a leek inside the door, make sure the hole behind the brewing unit (in the chassis) are clean.
That you get a half cup of coffee one time and a full next time can be the electric board in the machine but can also be the flow meter.
Hope this can help you.
Best regards
/Mirran
Aug 25, 2008 | Saeco Vienna De Luxe Espresso Machine
Miele leak when switched on for wash, from filter unit front LHS bottom of machince
The leaks in a washing machine could be coming from many different places in the washer.
The first place you need to check is behind the washer, check the two fill hoses and the water mixing valve.
The next thing to do is to remove the front panel, set the washer on the regular cycle and turn it on to start filling.
Use a drop light and check all the hoses under the washer as the washer is filling. Make sure to keep your hands away from any moving parts.
If the hoses are ok, check the pump for leaks. When the bearings in the pump wear out, that is when the pump will get noisy and that could cause your Maytag top load washing machine water leaks.
Another place that the washer could leak water from, is the stem & seal on the holding tank. When washer leaks water from the stem & seal, the water leaks down the center of the transmission.
When the stem & seal need to be replace, the tub bearing has to be replace at the same time. This is an expensive repair if you have to pay someone to do it. If you do it yourself it will cost you about $110
Aug 06, 2008 | Miele Novotronic Premier 500 Front Load...
AWM8143
FA is the emergency shutoff switch that detects when water is pooling underneath the machine -> a leak.
"Check float switch under machine, empty any water from catchment tray, check for water leaks or oversudsing".
Jul 10, 2008 | Whirlpool AWM8143 Front Load Washer
Leaks water from left side of machine
you have to open the machine it probably the pump that need a seal kit to make sure you have to open the cover activate the machine and lock what leaking they is no miracle cure for our trouble you got to get dirty good luck cheers
Jan 30, 2008 | Saeco Vienna De Luxe Espresso Machine
Frigidare front load washing macine leaks water
Sounds like the dispenser is leaking somehow, there is no filter that would cause it to leak. Remove lid of washer by screws on back lip and inspect during fill to see where leak is.
Jan 20, 2008 | Washing Machines
Electrolux EW1000i Front Load Washer Logo
150 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
