Question about Microsoft Windows 95 + Internet Explorer for PC
Old computer Windows 95
Boots up to a point where the alarm operating system fault initiated - seizes in that position. Any chance of fixing?
    Problem Solver:
  • 19 Answers
Make your problem more clear please
Posted on Jan 09, 2009
My computer is not detecting Primary or secondary IDE port. I can not open my CD. CD is not appearing in my computer.
If the computer boots up and starts it operating system (i presume it's Windows?), then yes it is finding your primary and secondary ports, but you may still be not seeing your CD / DVD drive in your file explorer or in My Computer.
This is a fault relating to a thing known as High and Low filters - it's an old problem in Windows where for no reason at all your CD drive can vanish.
Search the internet for a patch to repair high and low filters, it will be a very small registry entry file that you are looking for.
Once you've ran that, restart the computer and 95% of the time the drive will have reappeared again.
If not, start by checking that you can actually eject the CD drawer using its open/close button, and if you have a disc in the drive can you hear it spin ? If not, it may be a lose power cable at the rear of the drive, or a faulty power supply just affecting that drive.
Aug 06, 2013 | Computers & Internet
I have a original game PGA Tour 96, EA for windows 95. I want install this game in XP SO, but its impossible for me.
I assume you meant to say XP OS.
Many older games are not compatible with the newer operating systems.
Use your old computer with the Windows 95 operating system installed.
If you REALLY want to use the game, find an older Windows 95 computer
and buy it.
Aug 29, 2011 | Computers & Internet
What does it mean when your screen says error while initializing the NIC? Computer will open to desktop page. Only get black screen with blinking cursor.
Ouch, it sounds like your laptop cannot recognize your operating system. When a computer boots up it looks for an operating system (such as windows) on differnet devices. For example: 1. hard drive, 2. dvd drive, 3. network card. You may have a dead latptop and need to reinstall the operating system.
Mar 12, 2011 | eMachines eM250-1915 Netbook
How can i get certificate of authentication code for windows 95 in packard bell?
Microsoft is no longer supporting the Windows 95 Operating System hence it's no use of getting COA code. Try searching www.torrentz.com to download Windows 98 Operating System if you have very old computer.
Mar 01, 2011 | Microsoft Computers & Internet
Windows xp boots but the desktop will not come up
Log in using SAFE MODE. While laptop boots, press F8 and it will prompt for which mode to login. Select 'SAFE MODE'. Once logged in try to restore the OS to a previous good restore point.
If you've a backup of the registry key, it will help better. Just restore the registry from the backup instead of going for an old restore point.
Please come back and rate my solution if this turns to be helpful for you or also if you need more clarification. Thnx
Apr 01, 2010 | Computers & Internet
PC does not boots
Change the SMPS, preferably with 450 & above wattage. Also you must be using an UPS(uninterrupted power supply or battery back-up so there are no chances of voltage fluctuation. At the time of changing the SMPS also remove the RAM and clean the contact points with a piece of normal white paper..............sodeep
Jun 28, 2009 | Computers & Internet
Dual op systems
in bios setup usually under security you can remove user passwords.
you get into safemode for 2000 and in control panel and remove it form users administrator account
If your not interested in to os systems then you can format
Mar 06, 2009 | Compaq Armada 3500 Notebook
Toshiba equium l20-197 booting
Chances are that it is a driver problem, try booting in safe mode by pressing f8 during the initial bot up process and selecting safe mode, with or without networking, if your systems goes in to windows then you have a drive issue, as safe mode loads with only the basic drivers needed to run windows, hope that helps
Dec 14, 2008 | Toshiba Equium 100 PC Desktop
Disconnect and static
Hi mgee 7890,
The main thing you stated that makes me feel the issue is with a line. Maybe not ADT. Security systems sit idle until needed. However, if it is an older system and has a failure, it could seize the line and disconnect. But with the static issue, it does sound like an inside wiring issue. There may be a short in the connection to the alarm system. I would call an independent wiring person. They are cheaper and can test from end to end. When two companies like this are involved sometimes finger pointing slows getting a resolution. So this takes care of that. Also, if there is a short they will usually reconnect it so you know you have a good connection. If this helped, please rate my response. And feel free to respond if you have any additional questions.
Kay
Jackson Communications
Aug 01, 2008 | Uniden Cordless Phone
Need assistance
With Windows 95, you can reinstall th operating system without affecting your data or programs. If you have your original install cd, use this to reinstall the operating system
Aido
Mar 03, 2008 | IBM eserver xSeries 360 8686
Microsoft Windows 95 + Internet Explorer for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
