Question about Fujitsu Computers & Internet
Can someone please help me get my laptop working through HDMI cable onto TV on a sony VAIO VGN-FW23G. I need to know the process to do this
I need instructions how to get laptop working through tv on a HDMI cable
1. Check the computer for changing output (some computers use <F5>, <F8>, depending on which brand they are. I believe Sony uses <Function><F7> or <F7>).
2. Check what channel the HDMI port is on (e.g. AV1, HDMI1, HDMI2, etc.) - you need to know this if your TV doesn't automatically switch to the new input.
3. Plug the HDMI cable into the TV HDMI cable-in port.
4. Plug the HDMI cable into the laptop HDMI cable-out port.
5. Turn on the computer.
6. Press the <Function><F7> simultaneously ONCE. The screen should flicker and show up on TV.
7. Sometimes you may have to go to "Display Preferences" and select Dual Monitors or external monitor if your computer doesn't do it automatically. Repeat Step 6 after.
** You may have to adjust Display Resolution to 1024 x 768 or lower in order for the TV to work. After it works at a lower display (800 x 600, for example), you can adjust the resolution to the maximum the TV can accept.
Posted on Oct 26, 2012
Pyrhyc
  • 2028 Answers
SOURCE: connecting PC to TV
Most tv's are not compatible in this matter. They were made to be a tv, and not a computer monitor. Some of the newer tv's are compatible. If they have a vga port then they are compatible, but may not support or have the resolution expected. The vga to s-video cables were designed mainly for the use of the newer computers with vga ports to older flat panel monitors with s-video ports, at the time that vga was first coming out. This cable is on the verge of obsolete. So, I don't believe that you're going to be able to hook the two together, and get the outcome you want.
Posted on Jul 26, 2008
HW_Dude
  • 87 Answers
SOURCE: How Replace CMOS Battery in Sony Vaio VGN-FS742 / PCG-7D2L?
Here is are disassemble instructions for you,
Good Luck
Posted on Jan 11, 2009
  • 54 Answers
SOURCE: Sony Vaio Laptop Display Screen problem
even if ur in warranty period they wont change ur display so try to take any serivece center and change other wise in any laptop try to get
any help so first just see sony engineer get his assiant usually they use have contact where u can get serviced
Posted on Feb 26, 2009
SOURCE: fn key for laptop sony vaio vgn-s460p
the function keys doesnt need any extra driver.
but if you want to use tha additional features of function key like save, load, close and many more then you can get the software directly from official website of sony. alternativel you can download hotkeycontrol xp by which you can reconfigure you keyboard to add extra feature and options
Posted on Jul 06, 2009
SOURCE: VAIO laptop VGN-FE865E drivers for XP Windows
Cannot find VAIO laptop VGN-FE865E drivers for XP Windows
Posted on Aug 30, 2009
Does the Sony VGN SF790 support hdmi cables? I would like to connect to my Sony Bravia TV
Hi.
No I'm afraid not. It only supports VGA out. If your TV supports a PC input then a male to male VGA cable will do. VGA does not support audio so you will also need an audio lead to connect to the TV too.
Regards.
Aug 13, 2011 | Sony VAIO VGN-FS790 Notebook
Is there any hdmi cable for sony vaio vgn-cr510e unit?
Hello there,
Unfortunately your laptop does not have a HDMI out port. However, you can purchase a special cable like this one http://www.amazon.com/VGA-HDMI-Cable-6-feet/dp/B002TUC64W/ref=sr_1_1?ie=UTF8&qid=1304695016&sr=8-1 It will connect your monitor port to a HDMI device.
I hope this has helped! Thumbs up are much appreciated.
May 06, 2011 | Sony VAIO VGN-CR510E/J 14.1" Laptop
I have a VGN-FS630/W and i am trying to use an external monitor, brand Envision, i got it working but it got disconected and now all i get is a White screen on my external monitor and my laptops screen...
Hi there
regarding that issue that you are having with the external monitor is not working with your sony vaio here are some steps that might help to have it working
connection between the monitor and laptop
- VGA ( blue adapter ) or DVI ( white adapter )
- check if the connected properly
- try to use a different VGA cable
- check if the monitor is detected by the computer
***please also do a monitor selftest on the external monitor***
- HDMI
- check if the tv is detected by the computer
- check the settings of the TV for the HDMI
hope this helps
Jan 11, 2011 | Sony VAIO VGN-FS630/W Notebook
VGA out not working
Try connecting any VGA device. I.e a projector.
Dec 04, 2009 | Sony VAIO VGN-FS740/W Notebook
How do I connect my sony vaio vgn-fs920 to a tv?
As far as I know I need:
1) to purchase that VGA - S-Video Adapter ?
2) to purchase S-Video Cable itself ?
3) to purchase something like audio AV cables as well ?
Does anybody know where I can buy VGA - S-Video Cable (without Adapters) if it's possible and DO I NEED TO BUY AUDIO CABLE IF I'M GOING TO CONNECT THRU S-VIDEO?
May 14, 2009 | Sony VAIO VGN-FS920 Notebook
Set Up PC to TV
What type of video card does your pc have??? if it is an nvidia card, you have to go to the control panel and set up for dual monitor..when you connect your laptop to an external monitor, you have to press control and f8 keys for couple of times ...that adjust the color to 256. Are you doing that?
Let me know
Apr 10, 2009 | Sony Vaio FZ31M Notebook
Connect SONY VAIO VGN-CR23G to tv
it's only a partial solution but channel 3 or 4.... or your tv may have settings for dvd or other. look at the remote. try hooking it up again and changing from regular cable to dvd or the other setting (can't think of it at the moment)
Robert
Jun 27, 2008 | Sony VAIO VGN-N130G/W Notebook
Sony fs630 laptop
What cable socket do the laptop use.....if you don't know,take photo and mail me.Why not use a normal av to dlp or av to hdmi cable..... should be available at any store. JJ
Sep 12, 2007 | Sony VAIO VGN-FS630/W Notebook
Computers & Internet Logo
210 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
