Question about Haier HLP21N Washer
My maytag bravos ecoconserve washer wont spin and sometimes wont unlock unless i unplug it and plug it back in even when i pause or end the cycle
2 Suggested Answers
  • 52 Answers
SOURCE: Washer won't spin or drain
The problem is most likely the lid switch assembly. The lid switch is a safety feature that will **t allow the washer to go into the spin cycle unless the lid is shut (so ** wandering children get caught inside).
If the switch is working, you should hear a click when the door closes and makes contact with it. If the lid switch is defective/broken, the washing machine usually won't drain or spin. If it's bad, you will need to replace it. It should be mounted inside of the cabinet, just under the door of the washer (on most models). Please let me k**w if this corrects your problem.
Posted on Mar 10, 2008
Maytag is clicking when its going to weigh clothes and spin at the end of cycle
It's a faulty relay on the control board. If you remove the top panel and remove the boards you will find a spot burned out on one of the relays. If you know how to solder then you might be able to repair it.
Mar 04, 2014 | Maytag Bravos MTW6600T Top Load Washer
Maytag bravo mvwb750wq 28"
Have you tested the lid switch, if it is not making the washer will not spin. try using a pen or small bladed screwdriver to depress on the switch to see if you hear it clicking, although sometimes it wont work even if it clicks when they go bad. The washer should work as normal till it gets to the spin cycle, then without the lid switch working it won't go any furthur. You can try jumping across the leads to see if this gets it to spin and this will tell you if the switch is bad or not.
Mar 08, 2011 | Maytag Washing Machines
My maytag bravos 580 quit working. It stopped towards the beginnging of a cycle. It kept beeping and lights went around and around the dial. It wont let me change the cycle and wont shut off unless I...
Hello & Welcome to FixYa
LD error code means long drain, you can try to check the drain hose and clean it completely. Also take out the agitator and check any stuck clothes there. After this if the problem is back then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Jan 16, 2011 | Maytag Bravos MTW6600T Top Load Washer
My maytag clothes washer Bravo quiet series 300, keeps flashing a Sd error code. Or it may be 5d
What does the Sd code mean?
This code indicates that excessive detergent suds occurred during the cycle. The washer will not be able to spin out water with the excess suds. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the washer pauses the wash action and adds water for additional rinsing. This pause allows the bubbles in the suds to break. This process is necessary and may occur several times to eliminate the suds.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
Use only HE High Efficiency detergent for BravosTM washers.
Is "Sd" displayed and the wash cycle dial is flashing?
This indicates the washer was not able to clear all the excess suds from the washer. Re-select your desired cycle using cold water. Press Start/Pause. Do not add detergent.
Is "Sd" displayed and the wash cycle dial is not flashing?
If "Sd" is displayed and the wash cycle dial is not flashing, allow the machine to continue running, even if it appears that nothing is happening. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the wash action will pause to allow the bubbles in the suds to break, and the washer will add water for better rinsing. This rinsing process is necessary and may occur several times to eliminate the suds.
Is the drain hose kinked or clogged?
Make sure that the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose.
To remove the error display, press Power/Cancel or Pause/Cancel once.
If Power/Cancel or Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start/Pause.
NOTE: If the error remains on the display, and all of the other questions above have been checked, call for service.
Dec 27, 2010 | Maytag Bravos 3.8 Cu. Ft. Washer
Error code UL with 12 minutes remaing on each load
hi,
This error code indicates that an unbalanced load is detected.
if the load is unbalanced, the washer will display this code while attempting to balance the load at the end of the wash cycle and before the final spin. If the code remains and the wash cycle dial is flashing after the recovery routine has stopped, open lid and redistribute the load. Close lid and press Start/Pause.
If the washer is not level, the washer may be more sensitive to unbalanced loads. The washer must be level from side to side and from front to back. The front and rear feet must be in firm contact with the floor. Make sure the locknuts are tightened.
Sep 06, 2010 | Maytag Bravos MTW6600T Top Load Washer
My Maytag bravos wont spin out
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 23, 2010 | Maytag Bravos MTW6600T Top Load Washer
Haier HLP21N Washer Logo
1,714 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
