Question about Pride Go-Go Ultra X 3-Wheel Travel Scooter
How can i remove the seat from my ultra x gogo scooter
3 Suggested Answers
hawk127311
  • 350 Answers
SOURCE: where and how do I replace my battery for my pride
Do not use batteries with different amp-hour (Ah) capacities. Do not mix old and new batteries. Always replace both batteries at the same time.
MANDATORY!
Battery posts, terminals, and related accessories contain lead and lead compounds. Wear goggles and gloves when handling batteries and wash hands after handling.
WARNING! Always use two batteries of the exact same type, chemistry, and amp-hour (Ah) capacity. Use 12 Volt deep cycle batteries.
1.Remove the battery pack from the Travel Scooter.
2.Carefully turn the pack upside down.
3.Remove the eight (8) screws from the perimeter of the battery pack.
4.Carefully turn the pack right side up and remove the lid.
5.Disconnect the black (-) and red (+) battery cables from the battery terminals.
6.Remove the old battery.
7.Place a new battery in the battery pack.
8.Connect the red battery cable to the positive (+) battery terminal.
9.Connect the black battery cable to the negative (-) battery terminal.
10.Position the lid back onto the battery pack ensuring all wires are inside the pack so they don’t become pinched.
11.Carefully turn the pack upside down.
12.Reinstall all screws and tighten.
13.Charge the new batteries for 8-14 hrs before the first use.
I hope this helps and good luck!
Posted on Feb 24, 2010
mikemary945
Curt's solution is right on. However, I just changed the batteries on my wife's Pride Revo, and ran into something that other Harry and Harriet Homeowner might want to know. I got the scooter cases apart, and disconnected the batteries, and then couldn't get the batteries out. It was like they were cemented in the case. Not being a pro, I was afraid to put too much pressure on them, but finally got a screwdriver out to pry between the case and the battery. It was then that I heard the sound of Velcro separating. This was our original scooter, with the original batteries in it, and it seems that the factory thought it would be a good idea to use industrial strength Velcro to anchor them to the bottom of the case! Had to keep prying to gradually loosen them, and three hours later, finally had them changed. Note that this was on an original, factory installed set of batteries.
Posted on Oct 12, 2012
How to remove seat & battery
Hi' I have a pride gogo scooter, to take the seat off just take the pin out and then push the swivel lever up and then just jiggle it and it lifts off. To remove the battery remove the canopy thats situated under the seat,then undo the strap and disconect the the front battery plug(harness) and the do the same with the rear one then your battery will lift out.
Aug 21, 2015 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
My gogo ultra is showing fully charged and horn beeps, when i put key in it beeps fast 10 times and 5 beeps after
5 beeps usually means scooter is out of gear, but since the lever is in the drive position and the scooter gearbox/differential is engaged, it seems that the controller is not sensing the gear change. Possibly a faulty micro switch in the motor housing can be the cause of this, usually the micro switch is pressed down by the drive lever and if the switch is pressed down the motor controller knows the scooter is in gear.
Feb 11, 2015 | Pride Mobility Products GoGo Ultra X...
Wiring diagram on a gogo scooter
The wiring interconnects on these scooter are all modular and the blow up assembly diagrams are all you need to trace the wiring and replace components. Aside from a dealer log in to the manufacturer's website you can go to southwest medical's website and get all the information on the wiring and parts. Hope this helps.
SC40X Go Go Ultra Replacement Parts
Mar 01, 2014 | Pride Mobility Products GoGo Ultra X...
Scooter beeps but will not go
Make sure it is placed in gear, sounds like it is in the Neutral free wheel position.
If the scooter moves easy when you push it, it's just in free wheel.
Feb 13, 2014 | Pride Mobility Products GoGo Ultra X...
Pride GoGo Ultra X battery meter needle
you could have a bad throttle pot o speed pot possibly a key switch problem aswell. Hi I a Phillip the "DFW Mobility Specialist"send me a email at dfwmobilityspecialist@yahoo.com if you live in or near the Dallas Fort Worth area.
Apr 10, 2013 | Pride Mobility Products GoGo Ultra X...
Have GOGO scooter, when you turn it on the alarm sounds and will not to anything, it has been fully charged.
Princess try the freewheel lever make sure its in the drive mode and turn the scooter back on Hope this helps
Mar 26, 2011 | Pride Mobility Products GoGo Ultra X...
I have bought a go go scooter which does not have a manual
evilyn Goto pridemobility.com click on scooters then find the picture for GoGo Ultra click on the picture and on that page on the right you will find owners manual click on that and download your manual Hope this helps you
Sep 19, 2010 | Activeforever Pride GoGo Ultra 4 Wheel...
My gogo-ultra will not run. it has been stored
hi,
Check the connections between the battery and motor, if the rear come apart check there connections there,
If the connection with the batteries string loaded, rough them up slighty with a wire brush but be gentle and is there freewheel lever right in position for drive.
Regards
GeWiz.
Oct 24, 2009 | Pride Mobility Products Go Go Ultra X 4...
PRIDE GOGO ULTRA X Beeps and Cuts off
Please make sure your charger is okay, can you try another charger ?
the other thing is , the FREEWHEEL lever can it move itself say when you go down a kerb , what are they replacing ? do you have the part ? send me a photograph if you do ?
Jun 10, 2009 | Pride Mobility Products Go-Go Elite...
Pride Go-Go Ultra X 3-Wheel Travel Scooter Logo
81 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
