Question about Scion Vehicle Parts & Accessories
Scion xd ignition coil is malfuctioning
My 3rd ignition coil is constantly breaking, or at least that's what the diagnostics is telling me. I've changed it 3 times and it'll keep breaking. This will end up effecting my rev limiter and gives this bubbly sound when I get the rpm up to 1 1/2. I don't think that this is actually the problem because I just changed it today with a brand new ignition coil, same results. Is there any other explanation?
    New Friend:
  • 14 Answers
Try swap the other coils out with the one you took out, did you change spark plugs aswell? is the injector getting a pulse to open?
Posted on Sep 18, 2017
  • 22306 Answers
SOURCE: where does the rpm (rev counter) get its feed from
no it has only one coil,a bosch system ,coil ,dist cap and module for a 1995 car
Posted on Nov 28, 2008
  • 1586 Answers
SOURCE: 92 300zx rpm will not go over 2500 rpm pops from intake
This is a classic symptom of a bad mass airflow sensor. Nissan designed this as a protective feature on the car. If the mass air sensor goes bad, the computer limits the car to a 2400RPM rev limit to prevent damage.
The sensor is under the center nose panel between the headlights. Take that off and on the back of the airbox (which fills this space) you'll see a pipe coming out that meets at a "T" with another hose going across and down under the headlights. That pipe off the back of the airbox is the mass air sensor (it has a harness plugged in).
Posted on Mar 27, 2009
ollie reece
  • 1167 Answers
SOURCE: I own a 2005 Bonneville, it keeps breaking
have you tried replacing the cdi unit this controlles the spark to the coil ??? get back to me
Posted on Sep 17, 2009
Testimonial: "thanks"
  • 350 Answers
SOURCE: today my scion xd abs
Well you can drive without ABS the brake light came on because the ABS. I would have it serviced they might tell you the ABS unit is bad you don't need ABS they just prevent your tires from locking up during heavy break use
Posted on Jan 30, 2011
  • 177 Answers
SOURCE: I need to know the
2.imageThe firing order is 1 4 2 5 3 6 as numbered in the diagram
Posted on Feb 18, 2011
Where is the fuel pump relay for 2010 scion xd
look in your manual it will tell you
Oct 08, 2014 | 2010 Scion xD
What is the firing order for a 2008 scion xd 1.8l
Hi Terry
The firing order on the Scion XD 1.8L (2ZR-FE) 2008 is 1-4-3-2 Hope it helps
Sep 28, 2014 | 2008 Scion Xd
How to find and clear a/c drain in 2008 Scion XD?
Install a cabin filter. You have to remove the glove box to access the filter's home, but once you do this, the filter will catch all the crud that cloggs the system. It is very easy to install the cabin filter in a Scion XD. Just go to Pep Boys or your local parts store and get the filter. They cost about $15.00 and check out the video on "Scion Xd cabin filter".
Mar 25, 2012 | 2008 Scion Xd
How can I turn off the maintenance light of a scion xd 2008?
1. Set your odometer to Trip A 2. Turn off ignition 3. Hold odometer button down 4. Turn on ignition 5. Hold odometer button until Maintenance Required light stops flashing
May 13, 2011 | 2008 Scion Xd
Today my scion xd abs ligth and break ligth came on, what could be the problem and how unsafe can it be.
Jan 30, 2011 | 2008 Scion Xd
How to chAnge 2010 scion xd oil
any parts store can tell you what kind of filter you need for the car
May 12, 2010 | 2008 Scion Xd
Resetting maintainance light on a 2008 Scion xD
To reset your maintenance reminder system (even if the light hasn't come on yet), you'll need to turn your key to on (but don't start!) and make sure your odometer is on TRIP A. Then key off. Press and hold the Odometer/Trip button. While holding down on the button, key the ignition to on (Don't start the engine!) The display panel will count down from "------" to "-"Continue pressing the button until the Trip A is displayed. After this step, you are done.
Here can find one video about this procedure: Youtube vj7kK5i2tPc
I hope helps with this (remembe rated this help) Good luck.
Dec 29, 2009 | 2008 Scion Xd
MAINT REQD light won't reset
I am a Scion Service Manager. Really.
Here is how you do it:
Turn the key to the ON position (do not start it)
Observe the odometer display (it MUST be set to "ODO"),
and observe the mileage...
(Note that some Toyota & Scion cars utilize the "Trip A" setting)
Press in and HOLD the trip reset stick; do not release it.
Turn the key on.
Observe the odometer display. You will see 5 dashes, then 4, 3, 2, and then 1, followed by 5 zeros, and then, whatever mileage you observed when you started will return.
Release the button. The indicator is norw reset.
What this does: It adds 5K miles to the odometer counter.
Sep 05, 2008 | 2008 Scion Xd
Vehicle Parts & Accessories Logo
110 people viewed this question
Top Scion Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Scion Vehicle Part and Accessory Expert? Answer questions, earn points and help others
