Question about HP PSC 1510 All-In-One InkJet Printer
Scanner needs camera device fixed -
Got a reply back that maybe my scanner camera device wasn't working. Scanner/photocopier prints all black pages. Light flashes across glass properly though. Would it cost much to fix that image copier (camera) & could I do it myself easily?
    Genius:
  • 2,985 Answers
Are you using this as stand alone or through the computer? Whichever try the other way - If standalone try it through the computer. If in the computer try stand alone. If in the computer re install software. If all the variations do not cure it then its good bye to that one and onto the next - there is nothing that will fix.
Posted on May 13, 2007
HOW DO I MAKE A COPY FROM A COPY ON MY HP 2420
You cannot make a copy if you are thinking of it like a photocopier. It doesn't have a scanner built into it .
If this is what you are thinking there are several quite excellent scanners out there fairly cheap. The scanner will come with software that will make it and the printer behave like a photocopier. The scanner we use at home even has a button that we just press to scan and print a copy as well as software that gives more options.
If you want to just print multiple copies of the page then this you can do. You just have to go to print options on a program menu and tell it to print the page how many times you need. You can also change the number on the printer driver but if you don;t set it back after everything after is going to print a few extra copies.
Sep 13, 2011 | HP LaserJet 2420 Printer
Gestetner Aficio MP 1600 was connected to my System and I use it as photocopier, scanner and printer. The machine's Drum was changed of recent and it has failed to scan any of my documents. However, I...
Hello!
Changing the Drum does not affect the scanner settings.
You can print because your PC (computer) can see your machine but for scanner is the oposit. The machine must see your PC.
I think that in this machine you have an SD card with the scanner funtion. Try to take it off and then put it on again. (the SD card is on its side. In the controller box)
If you still have any doubt reply to me.
Aug 01, 2011 | Ricoh Aficio 250 Copier
Printer/scanner/photocopier. scanner not working. Any ideas?
Are you scanning to your computer? If you are getting an error during the transfer to your computer, check your firewall. I had a scanner (mine is a Panasonic) problem with the transfer to my computer. I corrected it by printing the properties of the scanner and found out the port number that the scanner used and opened the port in the firewall. Hope it helps.
May 04, 2009 | Office Equipment & Supplies
I have a problem with our HP3030 in that when I try to photocopy using the document feeder, the pages all come out with a double black line running down the centre of each page. The same problem comes with...
You're right. There is probably debris on the glass where the paper passes through. It's a common problem. You'll have to raise up the scanner so that you can see the glass. Then clean it off and you're back on business.
Apr 30, 2009 | HP LaserJet 3030 All-In-One Printer
Lines rule across my print out paper at photocopying mode
Make sure you don't have a scratch on the glass of the scanner. If you have a mark, or scratch that matches the line ruled on your print, then there is your problem.
It;s also possible the scanner is jerking as it goes across the bed, which is causing the line. Is the line solid, dashed, bold, thin or just kinda there?
Mar 14, 2009 | HP DeskJet F380 All-In-One Printer
Nothing working!
maybe...you might want to get fresh drivers, from www.lexmark.com and re install. might work.
Jun 01, 2008 | Lexmark X5150 All-In-One InkJet Printer
Print Okay , PhotoCopy Okay, Scanner Problem
If you are still having problems and are running windows vista what I had to do was go to this web site http://www.samsung.com/me/products/printer/multifunction/scx_4100.asp?page=Specifications and click on drivers in the box at the top and there is a separate scanner driver that has to be installed for it o work it has fixed my problem..
Nov 14, 2007 | Samsung SCX-4100 All-In-One Laser Printer
Scanner & black pages
The black printing usualy occurs when there is a faillure in the light, since your light is working fine, there may be a problem in the imaging device inside(camera) or the reflector. There is nothing wrong with the cartridge.
May 05, 2007 | HP PSC 1510 All-In-One InkJet Printer
HP PSC 1510 All-In-One InkJet Printer Logo
42 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
