Question about Haier HLP21N Washer
It does not spin
It has a string that got undone, below the belt, i don't know how or where it goes
Brush won't spin when carpet cleaner is running
see this causes and fix it. God bless you
If the vacuum cleaner brush is not spinning, the brushroll bearing might be jammed. Try removing the brushroll assembly and cleaning all hair, string, lint, etc. from the brushroll bearing. If that doesn't solve the problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning, the brushroll assembly itself might be jammed. Try removing the brushroll assembly and cleaning all hair, string, lint, etc. from the brushroll bearings. If that doesn't solve the problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning, the brushroll itself might be jammed. Try removing the brushroll and cleaning all hair, string, lint, etc. from the brushroll bearings. If that doesn't solve the problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning the cogged belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace as needed.
If the vacuum cleaner brush is not spinning the drive belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace as needed.
If the vacuum cleaner brush is not spinning the belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace as needed.
Sep 27, 2012 | Vacuums
2005 Lincoln LSV8 (3.9) overheating ..no H2o in crankcase, had NO prob. until had P/S hoses replaced is it necessary to take the serpintine off to change the hoses on that motor? i've been told if
I don't know if you have to remove the belt to change the hoses, but I would think the pump would have to be removed to get to the hoses. If that is true then the belt would come off.
And yes the water pump could be running backwards.
It should be a simple task to check the routing of the belt. You should have a sticker on the engine or the hood showing the correct routing.
If not, you can find a diagram online or ask for one here.
Sep 18, 2012 | 2000 Lincoln LS
How to repair roller on Vacuum cleaner
it migh be the belt.stretched and hardened from heat replace and try again
Feb 02, 2012 | Electrolux Vacuums
Just replaced the belt & it spins until I put clothes in it?
It sounds like you didn't get the belt tight enough to handle the load of wet clothes. Suggest you use something to put more pressure on the belt while tightening the motor bolts. Although there is a recommended torque for the belt, most technicians don't measure when they replace a belt.
Jan 01, 2012 | Maytag Dryers
The brush wont rotate on my windtunnel vac but it still has suction. Could this be a broken belt?
Yep - that's usually the culprit if the brush stops turning. However, pull off the skid plate (bottom panel) and make sure you haven't picked up any string or some other obstruction that's wrapped itself around the brush & stopped it from turning. Things like hair/string don't always end up in the bag/bin sometimes if they're long enough they just wrap themselves around the brush.
Jul 13, 2011 | Hoover Vacuums
I don't know how to restring blk and decker #8209-04. I don't understand where the string is supposed to go. Never saw anything like it before.
You can get the manual on how to wind the string on the link below. It is under downloads on the right side. You will need to click on the pdf to download it.
http://servicenet.blackanddecker.com/Products/Detail?productNumber=8209#
Jun 13, 2011 | Garden
We are trying to replace the belt on the bissell 89q9 model. We purchased belt 8 and got in onto the brush however the brush doesn't spin anymore. Even trying to turn it by hand doesn't work. One...
Remove the beater brush assy & remove the
shaft & brgs that go through it 7 clean out the
hair,fuss ect,so it will turn
You need to take your vacuum apart once a year or more
to clean things so they continue to work
May 22, 2011 | Vacuums
Squeaking sound from fan belt
  • Take a can of brake clean and spray it on the belt while it is rotating. If the sound goes away for good it was a dirty or wet belt. If the sound goes away and come back it is more than likely a bad belt. Remove the belt and turn all the pulleys to see if they are spinning free. a stuck pulley can cause a belt to squeal too. If a pulley should catch a bit then perhaps the pulley could be part of the issue as well. Should all pulleys check good then put a new belt on. Don't forget to check the tension pulley for weak springs.
Regards, Tony
May 10, 2011 | Ford Mustang Cars & Trucks
Brush not spinning
Remove the bottom plate to see if the belt came off of the motor shaft, or perhaps it broke in two when the brush stopped turning. Hope this helps!
Jun 28, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
I was vacuuming with the Dyson DC 17 and sucked up a berber carpet string by accident and after cutting and pulling it all out of the bottom brush part, the brush no longer spins but the suction part...
The belt could be snapped. If this model has a brush protected belt then it has to be repaired by a service call. If however you can get to the brush roll belt by removing the bottom sole plate (turning over the vacuum so that you're looking at the base) with the plastic catches undone where you can see the belt then check to see if it has snapped. If it hasn't snapped then it may just need readjusting.
If you can't see the belt and has protective covers that can't be undone then the model has a brush control system that has to be replaced by someone who can do Dyson repairs.
Mar 12, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Haier HLP21N Washer Logo
23 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
