Question about Kawasaki Commercial 30'' Gas Hedge Trimmer Kht750 ()
How to restring a kawasaki KHT750D hedge trimmer
4 Suggested Answers
bbreton
  • 437 Answers
SOURCE: the blades dont meet coming back.
Go to www.precisionope.com. Put your model information It asks for under oem parts. It will give you a parts list and diagram. See if you can find the part number there for the blades. That may be more help for what you are looking for.
Good Day.
Posted on Oct 10, 2009
jyackle5
  • 8197 Answers
SOURCE: We have a Kawasaki Hedge Trimmer TF22. I need to
The oil ratio for the trimmer is 50 to 1.
Good luck and please rate 4 thumbs uf for the free answer
Posted on Jun 26, 2010
Testimonial: "Thank you very much for your help. It was given to us by a friend but no manual"
  • 59 Answers
SOURCE: kawasaki khd 600A hedge trimmer just wont start.it
If you have gas in it, then the only other thing would be the carberator,,,,,,,replace the carb
Posted on Sep 24, 2010
Why does my kawaski khs750b hedge cutter start easily but stop when tilted in a certain position
Answered your own question : generally the fuel supply to the motor is through a small hole at the base of the tank , at full you could probably tilt more aggressively and the line is getting fuel , however as the fuel runs down the fuel is on one side of the tank and is essentially not getting fed to the motor , you'll notice tilting it from horizontal to left you will get cut off , tilt to right it'll keep running depends on the locations of fuel line however , cars pre fuel pump days had similar problems
Sep 19, 2014 | Kawasaki Outdoor New kawasaki Hedge...
In need of manual kawasaki hedge cutter
try the piratebay
its a utorrent thing. type in like kawasaki hedge cutter kht600d manual
Mar 13, 2012 | kawasaki Kht600d Gas Hedge Clipper Trimmer
Blades dont move
If the motor is turning and the blades are not moving it is likely that you have sheared the pin on the gear.
Aug 23, 2011 | kawasaki Kht600d Gas Hedge Clipper Trimmer
Hedger wont run unless it has choke on
Sounds like the carb is lean. Back out the adjustments 1 quarter turn and work from there. Also make sure air filter is clean.That should get ya going.
Dec 20, 2010 | kawasaki Kht600d Gas Hedge Clipper Trimmer
Kawasaki khd 600A hedge trimmer just wont start.it runs for a second and stops
Bit late to help the owner of this question and yes it could be a carbie issue but also check the idle speed. If it has dropped out of calibration and is idling too low it will start then stop. Try starting with some throttle, keep it running if you can until it warms up then let the throttle go back to idle. If it stops check to see if opening the idle screw solves it.
Sep 24, 2010 | kawasaki Garden
We have a Kawasaki Hedge Trimmer TF22. I need to know the ratio of gasoline and oil to put in it
Jun 26, 2010 | kawasaki Garden
The blades dont meet coming back.
Good Day.
Oct 06, 2009 | kawasaki Garden
Kawasaki KHT600S hedge trimmer cranks but won't throttle up
need a carb kit and a new fuel filter in the gastank
Aug 10, 2009 | Garden
Kawasaki Commercial 30'' Gas Hedge Trimmer Kht750 () Logo
57 people viewed this question
Top kawasaki Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
Phil Walker
Phil Walker
Are you a kawasaki Garden Expert? Answer questions, earn points and help others
