Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Whirlpool refrig not cooling
I have a Whirlpool Gold GD5rHA Side by side, the freezer is 4 degrees above zero, frig is in the 50 degree range, What could be cause of frig not cooling?
  • 76 Answers
Is the fan in the freezer working when compressor is on? if not you need to replace it. do you have a large frost build up on the back wall of the freezer? if so you have a defrost problem, or back to the evaporator fan. If the fan is working you have a defrost problem which could mean a bad heater, timer, or bad defrost thermostat....
Posted on Jan 03, 2009
How do I determine and fix what is wrong with 2008 model whirlpool frig that the freezer I noticed first all food unfrozen then a couple days later refrigerator not cooling can hear running but contin
I ned more information to answer your question. What model do you have? This is very important to give you the correct information you seek. Thanks
Sep 16, 2014 | Whirlpool Refrigerators
Fridge and freezer at 50 degrees with settings on max cold. I can hear compressor cycling and all power is on. Suggestions?
Your Refrig/freezer should be set as follows:
Refrigerators: 36 to 40 degrees. Ideal temp is 37 Fahrenheit. Note: A temp above 42 degrees promotes bacteria.
Freezer: temp should be -5 to 6 degrees Fahrenheit. Ideal temp is 0 degrees.
Then check the door seals around the edges to see if any splits, tears or cracks have messed up the seal. This will cause your compressor to constantly run as it's trying to cool off the warm house is being sucked into the freezer (or Refrig). A sure sign the door seals are damaged is lots of ice in the freezer door area or water pooling in the bottom area of the refrigerator.
Wait about 4 hrs after you readjusted the Refrigerator/Freezer settings so everything settles down. If you still have problems then the coolant may need to be serviced (topped off) or the motor serviced/checked.
Don't procrastinate because a water heater and Refrig/freezer are the 2 largest energy users in your home- they run 24 hrs a day.
Hope this helps...
Nov 23, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Frig/Freezer - Frig side too warm at 60 degrees
Check for another fan to cool the fridge side. It could be bad.
murf427
Aug 01, 2012 | Whirlpool Refrigerators
1 month old whirlpool refrigator is almost 60 degrees in frig part and 10 below zero in freezer side
It sounds like one of two things, either the evaporator fan is not running(fan in the back of the freezer behind lower back panel) or the bi-metal thermostat that may be in series with it is open..
Also some newer models use a lower voltage fan motor, use to be all were 120 volts........
It is under warranty for one year so call for authorized service to repair it......
(all of the cooling on the refrigerator side is done by air circulating from the freezer side, also possible there is ice blocking the air flow somewhere)
hope this helps
Feb 11, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool refrigerator model GD5rha does not cool but freezer portion does.
replace the control board usually lights are out in refrige side also ans temp readout is also out part # 4334000 appliance parts pros $80.25 shipped
Oct 23, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold gs5shaxnl side by side-the ref. side has no power and when the door is opened there is a clicking sound until the door is shut -temp is 33 degrees-everything is working on the freezer side...
replace the control board Part#4334000 appliance parts pros $80.25 if you recently blown a light bulb in the refrige section this will also ruin the board
Oct 11, 2009 | Whirlpool Refrigerators
Freezer/Fridge not cold enough
check see if compressor on check control if on
Apr 05, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerator side too warm
SHOULD HAVE A AIR DIVERT ER CONTROL TO SEND MORE AIR TO FREEZER AND LESS TO FRIG SIDE TRY TO SENT MORE AIR TO FREEZER SIDE AND LEAVE COLD CONTROL COLD ENOUGH TO ACCOMMODATE THE FREEZER SIDE TO BE COLD ENOUGH
Jan 28, 2009 | Admiral 26 cu. ft. Side-By-Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
282 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
