SOURCE: 2000 DODGE CARAVAN TRANSMISSION LEAK
A good mechanic should replace the seal with in 2-3 hours, mainly tearing apart your drive wheel on that side along with the drive shaft. This is a good time to replace the drive shaft if any of your CV joints are leaking.
Good Luck!!
PHX
SOURCE: 1998 Volvo V70 with potential transmission problems?
Yes, it's the 'pnp' switch (also known as the inhibitor switch) which is on the side of the transmission.
I own 2 Volvo 960s (3 litre automatics) which are similar in many respects ... and have that flashing arrow. It's a well known fault and you don't have much to worry about.
Rather than write it all here, you can read what I wrote as an ebay guide about it at http://reviews.ebay.co.uk/Volvo-960-Automatic_W0QQugidZ10000000003233806
I did put similar info on my website at http://www.glennsmart.btinternet.co.uk/volvo960.html with photos
Though the ebay guide is better ...
If you haven't got time to read it ... forget the flashing arrow and put a bit of black tape over it ... My wife's car has (192,000 miles) had that arrow flashing for 3 years. My car (100,000 miles) has had that flashing arrow since I bought it 1 year ago.
I did change the pnp on both cars ... but you also need to have the computer error reset by Volvo to have the light extinguished. Don't worry ... keep driving.
SOURCE: 1999 ford expedition - transmission slip?
the flashing O/D light usually means you have a bad speed sensor that sends speed info to the engine & trans computer.
Vehicle Speed Sensor
The vehicle speed sensor (VSS) (Figure 42) is a variable reluctance or Hall-effect sensor that generates a waveform with a frequency that is proportional to the speed of the vehicle. If the vehicle is moving at a relatively low velocity, the sensor produces a signal with a low frequency. As the vehicle velocity increases, the sensor generates a signal with a higher frequency. The PCM uses the frequency signal generated by the VSS (and other inputs) to control such parameters as fuel injection, ignition control, transmission/transaxle shift scheduling and torque converter clutch scheduling.
Some trans use an OSS, Output Shaft Sensor instead of a VSS. Depends on which trans you have, 4R100 or 4R70W
Transmission Control Switch (TCS) and Transmission Control Indicator Lamp (TCIL)
The transmission control switch (TCS) is a momentary contact switch. When the switch is pressed, a signal is sent to the powertrain control module (PCM) to allow automatic shifts from first through fourth gears or first through third gears only. The PCM energizes the transmission control indicator lamp (TCIL) when the switch is off.
The TCIL indicates overdrive cancel mode activated (lamp on) and electronic pressure control (EPC) circuit shorted (lamp flashing) or monitored sensor failure.
Output Shaft Speed (OSS) Sensor
The output shaft speed (OSS) sensor is a magnetic pickup, located at the output shaft ring gear, that sends a signal to the powertrain control module (PCM) to indicate transmission output shaft speed. The OSS is used for torque converter clutch control, shift scheduling and to determine electronic pressure control.
SOURCE: 2002 Volvo v70-Transmission is shifting hard in lower gears
Find a transmission servicer that is not afraid of tackling a Volvo problem. This is probably why the car was for sale in the first place. Good luck!
