Question about Kyocera Office Equipment & Supplies
Kyocera printer says printer not activated error code 30?
    Sergeant:
  • 260 Answers
Section I: Damaged Customized Form
  • Try to e-mail/print using a standard form or a Standard Report such as the Balance Sheet
  • If the error occurs as soon as Print or Email is clicked, skip to the next section
  • If able to select the standard form, and the form prints or emails successfully, See Article ID 11456 (Error: "Bad or missing form file") in Related Resources
for more help visit https://cbrtechsolutions.net
Posted on Oct 06, 2015
SOURCE: printer not activated, error code -30
I have fixed this problem, and I also know what caused it initially. First of all, this started happening after I installed software called WillMaker Plus 2009. For some reason, that installation also had created a new "Quicken PDF Printer." I think that was interfering with my default printer. So what I did, was completely unistall my default printer driver, turn the printer off, and then reinstall that specific driver from online. When I turned my printer on, my computer sensed new hardware, and took it from there. Fixed.
Posted on Aug 09, 2009
xptareq2000
  • 1447 Answers
SOURCE: error code 30 - printer not activated on Cannon 210
E3-3 = Paper jam
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD over current error – USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
Posted on Sep 08, 2009
puertobori
  • 7733 Answers
SOURCE: Won't print. Says printer
Try using the HP Print Diagnostic Utility in Windows - HP Customer Care (United States - English).
If you need more help come back.
Post / thumbs / testimonial are welcome!
Posted on Jan 06, 2011
  • 1218 Answers
SOURCE: HP psc 2210 all-in-one --
Check if you printer you are wanting to print from is the default printer to your system.
You can make the printer your default printer by clicking 'Start', and then click 'Printers and Faxes' to open the 'Printers' folder, if the desired printer does not have a check mark next to it, right-click the printer icon and then click 'Set as Default Printer'. You can right-click on the printer icon, and then click on the 'Print Test Page' to print a Windows self-test page.
http://www.fixya.com/support/t3506228-hp_printer_not_printing_activated_error
Posted on Jan 11, 2011
  • 256 Answers
SOURCE: printer not activated-error code 30
Sometimes, you may get printer not activated - error code 30 when you try to print using your printer. It may occur when you try to print a PDF document. Sometimes, your Antivirus scripts block you from generating the document and you may have to face this issue. If you have installed Antivirus software and you have encountered "Printer not activated" error, you need to disable script blocking. If this does not resolve the issue or you do not have installed Antivirus, you need to change the Calyx Document Converter printer settings. If it also doesn't work, you need to reinstall the printer driver in your system.
Posted on May 23, 2011
Kyocera fs4100dn with error code f245
The proviso of whether it's B or 8 holds.
http://www.copytechnet.com/forums/kyocera/82182-what-error-code-f24b.html
Feb 10, 2015 | Kyocera FS-4100DN A4 Mono Laser Printer...
How to fix system error c6050 on my km-3035
It is a fixing assembly error code. The thermistor doesn't detect heat. Kyocera you replace the fixing assembly. You may be able to reset.1087 1087 gets u into served mode go to reset and activate.power off and on.
Feb 02, 2015 | Kyocera Mita Km 3035, 4035, 5035 Fs9120dn,...
Kyocera service codes
It's a firmware mismatch error did you just replace the touch screen or the whole control panel
Aug 25, 2014 | Kyocera Km-4050 With Feed, Finisher, Bank,...
This error indicates a problem with user name, password or domain name. Username/Password or Shared Name/Folder Name. Domain name is not entered.
A complete list of kyocera error codes with description can be seen here:
Kyocera Error codes
Nov 07, 2013 | Kyocera Mita FS 3800 Laser Printer
How do you correct error c 0180 in kyocera copier machines?
If reseating connectors on mainboard do not solve then:
1087 1087 get in to maint.
004 START
Choose the 003 line by touching it and activate it.
Reboot when told to.
May 10, 2012 | Kyocera Office Equipment & Supplies
Como soluciono el error 7000 que me sale en la kyocera
Code 7000
Contents: Toner motor lock error A motor over-current signal is detected
continuously for 5 seconds since the toner motor is activated.
Causes: Lump of toner inside toner container.
Check procedures/corrective measures: Replace the toner container.
Causes: Defective toner replenishment drive system.
Check procedures/corrective measures: Replace the developer unit
Causes: Defective toner motor.
Causes: Defective engine PWB.
Check procedures/corrective measures: Replace the engine PWB
Jan 21, 2011 | Kyocera FS-2000D Laser Printer
Error code 7001:0014607
Kyocera Mita FS-3820N
Hello, This error code (7001) refers to a Toner motor error.
• Toner motor is overloaded. TNMOC is detected by sampling every other
100 ms in 2 seconds since the main and toner motors are activated following
the Replace toner Clean printer, message after the "Toner low" is detected.
Recommended action is to change the toner pack.
If this does not resolve the issue then the developer should be changed.
If neither of those resolve the issue, then likely the internal circuit board called the engine controller may be bad.
If this is the case the printer will need to go to an Kyocera Repair Depot.
I hope this has been of assistance.
http://www.fixya.com/uploads/images/prefab_21.jpg
Jan 18, 2011 | Kyocera Mita FS-3820N Laser Printer
Printer not activated-error code 30
Jul 12, 2009 | Cannon Office Equipment & Supplies
110 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
