Question about Wahl Designer 6 (8355100)
I took my wahl clipper apart and put them back together now its making a REALLY LOUD noise!!!! PLEASE HELP!!!!! I have a wehl designer
4 Suggested Answers
  • 3 Answers
SOURCE: I took my Wahl clippers apart to clean ......
Okay I fixed mine. this is I what I did and it works now take the big blade and put it on a table, take the little blade and put on top of the big blade if you look closely at the big blade you can see where the little blade went, make sure you allign the blades. next take the white thing dont know what you call it bit it rotates the blades put that on the little blade, take the gold piece align with holes to the big blade and take the silver piece allign with holes and then put the screws back in. when you put it on the clipper make sure the white piece goes in the hole that rotates the blades and sould go in fine
Posted on Jun 20, 2009
  • 30 Answers
SOURCE: Noisy wahl hair clippers
1st remove the blade. Once the blade is off grab the blade drive between your fingers, if it moves side to side without any spring pressure than the drive arm is loose from the armature. If that is tight, than the armature may be loose and lifted out of alignment. There are two screws on the right hand side of the case which hold the armature. If the screw is phillips head it is standard thread, if it is torx head it is reverse thread. loosen these screws and press down firmly on the armature. The top of the armature should be even with the top of the motor coil. If the drive lever as mentioned earlier is seperating from the armature then this should be warranty repaired by the manufacturer.
Posted on Sep 21, 2009
  • 10 Answers
SOURCE: can i get detailed instructions to reassemble
Same problem here. Wish there was instructions online somewhere.
Posted on Jan 03, 2011
How to reassemble blades on wahl stable pro 8800
Do you have more parts in your hand than 2x screws and 2x blade parts? If no then pop the small cutter blade onto the plastic blade drive with the drive engaged into the diamond shaped hole in the cutter blade. Make sure you put the cutter blade on with the teeth facing forwards and the correct way up. The top side (goes towards clipper) is pretty much flat except where teeth taper. Next lubricate the small cutter where it is going to touch the large comb blade when you fit it. Now put the comb blade on and fit the 2 screws. Line up the blades & tighten the screws.
Apr 20, 2015 | Wahl Whal Stable Pro Pet Animal Clippers...
How do I reduce my clipper's rattling noise and still be able to cut properly?
The power screw is the correct way to adjust the problem you describe. If you have attempted to adjust it as instructed in the user manual and have not had satisfactory results, there may be a problem with the clippers.
Most Wahl clippers have a 1 year or longer warranty. You can call Wahl for warranty service at 1-800-334-4627
Nov 12, 2011 | Health & Beauty
I took the bland off of my wahl model 9860-1101. And the pin spring came out and I don't know how to put the pin sring back in. How to I put it back together?
Your best bet is to send it to www.mannyssharpening.com Contact mannyssharpening@yahoo.com they are a Wahl Dealer they have all the parts for Wahl clippers.
Mar 13, 2010 | Wahl 9916-800 Groomsman Beard Trimmer
Sep 16, 2009 | Wahl Magic Clip Clippers Hair Trimmer
Loud buzzing on Wahl "Designer" model clippers
There is a "power screw" located on the side of the clipper opposite the switch. This may need adjusting. Take a screw driver or coin....and with the unit running......turn the screw back and forth until the clipper stops making noise. The proper position for the most power is to turn the screw intil it makes a loud noise, then turn it back just enough to get rid of it.
Jul 03, 2009 | Wahl Designer 6 (8355100)
Jun 08, 2009 | Wahl 8550
Wahl Designer 6 (8355100) Logo
148 people viewed this question
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Anglia Clipper...
Falling star
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
