Question about Danby DBC2760BLS (5 cu ft) Wine Cooler
The temp drops on one side and heats up on the other side
How do I reset the temp my heat pump switches from electric to gas. It runs much more economically on electri than on propane. The thermostat is a Honeywell th8000. Code 350 setting I believe. Thanks
Heatpumps are more complex than an AC unit. Yes, there is a difference between a heatpump and an air conditioner. Where the real difference lies is out side in the condenser unit. There's a defrost board out in the unit, and depending on the brand and model, one of the wires will need to be changed so that the gas furnace will not come on. The problem with this, heatpumps use the heat that is available from the outdoors and transfers it to indoor. When the temps outside drop below 50 degrees, there's not enough latent heat to transfer, thus calling the propane furnace to operate. Without the addition of the furnace, you will not be able to heat the area properly. The only way to remedy this, is to remove the propane furnace and replace it with an electric airhandler with a heat strip for "emergency heat". The emergency heat term is used when the temps drop below the temps I mentioned above and calls for the heat strips to come on.
Feb 03, 2017 | Honeywell Heating & Cooling
I have a triangle tube challenger boiler. D.W & radiant. It has a drop in temperature about 1.5 -3 min. after turning water on. In shower and in sinks. Was able to watch tank and feel water from laundry...
A lot depends on the size of the tank. And when it heats some systems only heat at night , this is ok if the system is large , on most heaters there is a thermostat on the side that can be used to set to a higher temp. the thermostat on your heater may be faulty.
Dec 04, 2014 | Water Heaters
I had the same issue...the temp is 30 degrees out side and like 50 inside...every time i turn on the heat the aux heat turns on...i tried to turn on the EM Heat but then the aux heat still turns on...i had...
You obviously have a heat pump. A heat pump is basically an air condition running in reverse. By way of example, during the summer time you will notice cold air coming from you vents and hot air being blown out of the outside section of you unit. And in the winter time it switches the flow of refrigerant (freon) and sends the hot air inside and the cold air out. So when the temp drops below about 45 and/or there is a high demand for heat inside the aux light will come on. When this happens it bring in the resistance heat (back up heat stripes) to accommodate for the added need for heating. Heat stripes do in fact burn a lot of electricity. My suggestion to you is not to make more than 5 degree increments of temp rise at a time on your t-stat. For instance if it is 50 inside, set the t-stat to 54, as the temp in the house rises you may continue to raise you setpoint...just never more than 5 degrees of room temp. Otherwise there is not much you can do for it on your own.
Dec 14, 2010 | GE Zoneline AZ55H09D Air Conditioner
Why does the temp drop
thats easy its the law of energy and surface area you have a deep fryer that has large area of aluminum and aluminum conducts heat very well on the plus side it heats the oil quickly. on the down side it loses heat very quickly too so the machine is always turning on and off to balance the heat loss. when you place food into it that drops the temp also.
Dec 21, 2009 | Masterbuilt 20010406 Deep Fryer
Engine temp drops when the a/c or heat is
The engine temp drops because the fan turns on regardless of heat or a/c. During summer of course with warmer weather it will be at a steady temp unless you the gets overheated by radiator or blown head gasket
Dec 15, 2009 | 1996 Ford Taurus
Blows out cold air at night , its set at 21degres but drops down to 15 degres after 12 pm at night untill about 5am in mornig when it goes back up to 21 degres there are 4 units in the office
Is the unit set on heating? If so, heat pumps or reverse cycle units will drop in efficiency and performance when the outdoor temp drops so this will be the reason why the temp drops so significantly. I would recommend setting the temp higher tha 21 or use another heater.
I take the time to answer your question, so please rate me.
Thankyou Mat
Aug 25, 2009 | Surround Air Heating & Cooling
Danby DBC2760BLS (5 cu ft) Wine Cooler Logo
43 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
