Question about Car Audio & Video
How do I bridge Kenwood kac-8013D 1000 amp - Car Audio & Video
    Master:
  • 444 Answers
If it does not show that it is bridge able in the manaul it is not possible to do it,Don,t evan attempt to do it,You will fry the amp, The only Kenwood amp that is bridge able is the KAC-9152D, I have installed car audio (Equipment) End am a (Certified) Electronics technichain for over 35, Years.End repaired lots of amps where people have tryed that stunt,End were paying for there (Screwup) The only other amps that are allso bridge able are some of the old school 2 chanell amps.
Posted on Oct 26, 2012
  • 631 Answers
SOURCE: kenwood kac-7202 amp
150/ch into 4 ohms
230/ch into 2 ohms
Spec Sheet
Posted on Jan 11, 2008
  • 7 Answers
SOURCE: my kenwood amp
you need to check your wiring and check your rca wires to see if they are giving your amp a signal to put out
Posted on Nov 02, 2008
etirbynnor
  • 655 Answers
SOURCE: To bridge a Kenwood KAC-9102D
Hello laurogleal,
The Kenwood KAC-9102D is a mono amp. There is no bridging. Having two sets of terminals is just a more convenient way of connecting two subwoofers. The amp is stable down to 2 ohms impedance, so it is safe to run 2 4 ohm loads in parallel.
Hope this helps.
Posted on Apr 28, 2009
wikkidd420
  • 96 Answers
SOURCE: want to bridge my subs I have a kenwood kac-719
from what i have read about your amp, it is already a mono amp, and rated for 2 ohm's, so all you have to do is wire the subs in parallel (both positives together to positive and both negatives together to negative) or series/parallel if you have dual voice coils (both positive and both negative paired on each sub, then positive from amp to positive on one sub; negative on that sub to positive on next sub; then negative on sub to negative on amp) Note though, with two dual voice coil subs, you can have a 1 ohm load with the first set up, which can damage your amp. Let me know if this helps :)
Posted on Jun 11, 2009
  • 9 Answers
SOURCE: KAC-8070 kenwood 4-channel power amp
Audio section
Max Power Output (4 ohms, 1kHz)
Rear 70W + 70W
Front 35W + 35W
Max Power Output (4 ohms, 1kHz, 10% THD)
Rear 45W + 45W
Front 25W + 25W
Max Power Output (4 ohms, 1kHz, 1& THD)
Rear 37W + 37W
Front 20W + 20W
Frequency Response (-3dB)
Rear 2 Hz ~ 100 kHz
Front 5 Hz ~ 50 kHz
Posted on Jun 24, 2010
How to bridge a kenwood kac-9105d
Are you referring to something like this, using two different amps? It is a mono amp, meaning there's one amp in the box.
"KAC-9105D also has a Dual Mono Drive connection that allows you to strap two KAC-9105D amps together to power a single subwoofer."Quoted fromhttp://www.kenwoodusa.com/Car_Entertainment/Amplifiers/KAC-9105D
Here's a link to a page out of the Yamaha Sound Reinforcement book. the top shows a stereo amp (1 box, two different amps inside) hooked up to drive two different speakers, which is known as 'stereo' mode.It then shows the two amps hooked to the opposite sides of the same speaker, which is known as 'bridge' mode.http://books57.net/ampOuts.gif
Any help?
Feb 24, 2012 | Kenwood Car Audio & Video
I need an appropriate speaker for my kenwood amplifier kac-5202
This amp is stable down to 4 ohms bridged at 120 Watts or 2 ohms stereo at 60 Watts X 2. If you are going with the bridged mono hookup just make sure the impedance of your subwoofer is no less than 4 ohms. A good rule of thumb is to be at least double of what your amps rated output power is. So if your amp can put out 120 Watts into 4 ohms then get at least a 240 watt subwoofer.
Do not exceed the rated load for your amp, you will damage it. Here is the datasheet for your amplifier
http://manual.kenwood.com/files/B64-3031-00_En.pdf
Jun 12, 2011 | Kenwood KAC-5202 Car Amp
My kenwood KAC-7204--- the wiring is hooked up right, I just got a 2000 watt max sub 1000 watt rms, i was running the amp in bridge mode and it ran for 1 day than it turned off. I checked it and the fuse...
when i was running my sub off bridge mode this kept happening to me. I ended up just running two subs and for some reason the fuse stopped blowing. i think there is something wrong with these amps.
Jun 04, 2011 | Kenwood KAC-7204 Car Audio Amplifier
KAC-9104D Car Audio Amplifier: how to bridge...
Sorry this is a mono amp, you cannot bridge one channel
May 17, 2010 | Kenwood KAC-9104D Car Audio Amplifier
I a looking to qire two 10 inch kicker comps what is the best way to get sound out of this set up in a sealed box and kac 7252 amp 1000 watt
check the ohms on the subs if its single 2 ohm make sure you dont bridge it avoid 1 ohm unless the amp is class d duel 2s make 4 or 1 depending on if you series on paralel them duel 4s make 2 ohms or 8 you want to make a duel 4ohm 2ohm and put one on each chanel email me for better exp.
Feb 05, 2010 | Kenwood KAC-7252 Car Audio Amplifier
Want to bridge my subs I have a kenwood kac-719
Jun 11, 2009 | Kenwood KAC-719 Car Audio Amplifier
Hello laurogleal,
Hope this helps.
Apr 28, 2009 | Kenwood KAC-9102D Car Audio Amplifier
Connecting subwoofer to kac-7201 kenwood amp
from your sub connect one short piece of cable from + on one side to - on the other side using the same diameter cable as you are running to the sub from amp . this will leave you with + and - on opposite sides of speaker these will then run to the amp +to+ and - to- on the mono side of connetor which is one left + and one - right and the amp switched to bridged
Mar 22, 2009 | Kenwood KAC-7201 Car Audio Amplifier
Sub power comes on consistently for about a second and thuds
u might have bridged the amp below is ohm load, if that the case run the speakers in series instead of parraell !
Dec 25, 2008 | Kenwood KAC-9152D Car Audio Amplifier
My kenwood amp
Mar 11, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Car Audio & Video Logo
80 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
