Question about Dell OPTIPLEX GX240 P4 1.7GHz 256MB 20GB DESKTOP (PCP417DELL)
My Dell optiplex Gx240 wont boot after installing new ram . It saids stopped at check point vcls.
When i put in new ram it wont work , but i can put in old one and it still works.
  • joecoolvette
    joecoolvette Oct 26, 2012
    1) What is the manufacturer code on the side of the ram memory module? 2) How many ram memory modules ('Stick'), are you using? 3) If just one, are you putting it in Slot 1? (DIMM 1) Using just one 'stick' of ram memory means putting it in Slot 1. The Processor reads Slot 1 first. 4) There are TWO ram memory slots. The Maximum TOTAL Amount for the motherboard, is 1GB. 1GB = 1024MB. EACH ram memory slot can support 512MB. It is SDR Sdram, and 133MegaHertz. (Or PC-133) Watch getting generic ram memory, and get it from a reputable dealer. Post back in a Comment.
  • Dell Master
  • 998 Answers
The new RAM has a problem. Insert one at a time and power up. You may have a bad RAM stick.
Posted on Nov 02, 2013
DickCanFixIt
  • 948 Answers
SOURCE: Dell Optiplex GX240 performance problem and fan noise
The fans on Dell power supplies are rather noisy and prone to failure. Find out if the noisy fan is inside the case or inside the power supply. If your computer has become slow you should scan for viruses and spyware. If the scan does not improve things it may be time for an upgrade.
The GX240 only supports up to 1 gigabyte of RAM, you should have the maximum installed. I would not spend more than $50 upgrading this computer, you can find better used ones in the $100-$200 range.
Posted on Mar 17, 2009
  • 68 Answers
SOURCE: how can I get my Dell Optiplex GX240 to [lay DVD's?
there are several free software packages online to play dvds etc just google search for the free stuff, and if that doesnt work you may have a dvd drive issue that needs to be looked at
Posted on Jun 22, 2009
zlittell
  • 30 Answers
SOURCE: why won't sound work on my dell optiplex 360
make sure you have the latest audio drivers on your dell
here you go install this
http://support.dell.com/support/downloads/driverslist.aspx?os=WLH&osl=EN&catid=3&impid=-1&servicetag=&SystemID=PLX_360&hidos=WLH&hidlang=en&TabIndex=
hope this helps
Posted on Aug 03, 2009
  • 252 Answers
SOURCE: Booting Problems With Dell Optiplex gx270 and gx260
Does anything show up on the screen when you access your BIOS?
Have you tried a fresh install?
Are there two video adapters installed (one integrated and the other in the AGP slot?
Posted on Oct 14, 2009
How to reset cooling fan alert on Dell Optiplex Gx240?
Are you using a four pin connector( connected to power supply)? if yes it will give you error. Connect the fan as shown in the image
Feb 04, 2016 | Dell OptiPlex GX240 PC Desktop
Dell OptiPlex GX240 PC Desktop cannot power up
Do you hear any beep sound when you power on the PC? Check the following componente PSU,video card (if you hear one long beep),or RAM memory if you hear 3 long beeps.
Apr 06, 2014 | Dell OptiPlex GX240 PC Desktop
Alert sound dimension
Please do a fresh install or try to use System Restore to go BACK before this problem happened.
Jun 08, 2013 | Dell OPTIPLEX GX240 P4 1.8GHz 512MB 20GB...
I have a dell optiplex gx240 that needs to be speeded up i think i need my registry cleaned up its not running as fast as i would like
You could bolt it to the front of an F16, try running CCCleaner or get a new processor and/or more RAM. All of these should speed it up,
Sep 14, 2012 | Dell OptiPlex GX240 PC Desktop
Computer does not boot up. Keeps on coming to the same screen that say - Alert! Previous attempts at booting this system have failed at check point (Vcls). For help in resolving this problem, please...
Hello - Did you recently add or change the RAM? The error your receiving is saying there is a RAM hardware problem.
Unless you have experience with working inside the machine (adding or removing components like ram) it probably will save you aggravation in the long run to get on the phone with Dell support.
Good Luck, Mikeywaf
Mar 05, 2011 | Computers & Internet
Dell optiplex gx240 keybord faiure boot
Replace the keyboard. Is you get the same result then the PS2 connector for the keyboard has died, from now on use a USB keyboard.
Jul 19, 2010 | Dell OptiPlex™ GX240 PC Desktop
Optiplex gx240 won't shut down hangs at "windows is shutting down" screen & I have to turn it off manually
Hi, you have one or more corrupted programs whitch are not closing down. You could try uninstalling any software installed since the problem started, or reset your os to a previos time when it worked properly; to do this start in safe mode by pressing the ESC button during boot up
Jul 04, 2010 | Dell OptiPlex™ GX240 PC Desktop
I have a dell gx240 im trying o make it boot and it just wont.i have used maxblast5 and 4 ive tried xp os and it wont install the hardrvives are used from an old computer,wht can i do to stsrtthe install
If your using the Dell recovery disk that came with the computer, chance are it wont install unless your using an identical hard drive as the original that was installed in it. You may need a new full OS disk. If you still have the original drive, may be able to ghost or clone the old drive and get it to work. There are quite a few programs for copying (ghosting, cloning) a complete hard drive image onto a new drive.
Dec 05, 2009 | Dell OptiPlex GX260 PC Desktop
GeForce 8400 upgrade problem
I would try two things: One pull the GeF 8400 out and boot as you normally did, install the drivers for the 8400. Then reinsert the Vid Card (8400) and when it looks for driver viola... If that fails:
Second if you can get in at all try the old F8 key on the boot up...and see if you can get in using SAFE MODE...and install your drivers from that point. Assuming the second set fails update the video driver using device manager.
That's a great vid card...good luck..leave a rating please.
Apr 30, 2009 | Dell OptiPlex GX240 PC Desktop
Mar 17, 2009 | Dell OPTIPLEX GX240 P4 1.8GHz 512MB 20GB...
Computers & Internet Logo
71 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
