Question about Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive
Wd anywhere backup wont allow macbook to shutdown
Just installed wd external drive. now i cannot  shutdown macbook. window asks to quit wd anywhere backup-but cannot quit.
I couldn't stop it from backing up, so used "force quit" from the activity monitor. It was still running a background service (WDMemeoAgent?). I stopped that from an icon left in my tool bar. I don't think I use it since it estimated 30-40 for the first backup of my home folder and it wouldn't allow me to pause or quit.
Posted on Jan 26, 2009
My WD 1TB my passport external hdd doesnt show up in my devices but the light is on and it makes a weird whirring sound, can this be fixed
You can download a program from WD called Data lifeguard Diagnostic for windows there is a floppy and a windows program. I made a bootable floppy and started my computer with the floppy and typed windlg.exe and followed the instructions...http://wdc.custhelp.com/app/answers/detail/a_id/1329/~/how-to-create-a-data-lifeguard-diagnostics-bootable-cd
Jan 01, 2013 | Computers & Internet
Hard disk media damaged
If it's damage and unreadable, you have to replace it.
External drives do go bad and if it was your backup you need to start backing up the backup.
Look into the Cloud Technology. Google will give you 5GB free to backup your data that you can access from anywhere.
Jun 03, 2012 | Western Digital Wd Elements Se 1tb...
How do I disconnect (uninstall) a WD External Hard Drive from my computer? I am using a WD 3200AAK WD External Hard Drive and want to install a 1 TB WD External Hard Drive. I would like to use the old one...
External hard drives don't need any program installed on your computer to run. Your operating system Windows, Linux should handle it as soon as you plug the usb in your computer. The programs included in your WD external hard drive are tools to backup your data.
If you try to hook up your hard drive to a Windows prior to XP, maybe your computer will not handle it.
It is always safer to safely remove your drive using the green arrow icon in the lower right corner of your screen. This way, the drive is shut down properly and you minimize chances of fails when you plug it again on another computer.
Hope this helps!
Feb 08, 2011 | Western Digital My Book Essential Edition...
Windows says: Error 12, Backupdestinaton not availabe ?
Hope this will helps
1.Quit WD Anywhere Backup - right click on the icon in the task bar
2. Go to C:/Users/<yourname>/AppData/Roaming/WD/WDAnywhereBackup/instances
3. In there you'll find the folders containing each of your backup plans
4. Open the XML document in there using an XML editor (I used XML Marker - simple to use and free from http://symbolclick.com/xmlmarker_1_1_setup.exe )
5. You'll see a line in there saying "<Key Name="dest" Value="\\unknown xx-xx-xx-xx.lan\Public\My WD_Backup" />"
5. Change the 'unknown xx-xx-xx-xx.lan' to the name of your drive - Use WD Discovery to remind you if you don't know. It's the name in the left column
6. Save the XML
7. Do the same for the XML file in C:/ProgramData/MemeoCommon/autobackup
8. Restart WD Anywhere Backup and it should be working again
Oct 29, 2010 | Western Digital My Book Essential Edition...
How do I back up my laptop I have installed the western digital external hard drive but do not know where to find the infor to back up my laptop
If the external drive does not have it's own backup software you can use windows backup by clicking START-ACCESSORIES-SYSTEM TOOLS-BACKUP.
Regards
Aug 24, 2010 | Western Digital Elements powered by WD 320...
My computer has 2 drives (C and D). My WD Passport will recognize and backup the C drive, but it won't backup the D drive. It doesn't split the files into pictures/video/etc like it does with the C, and...
Well, you don't have to use WD's software...you can better backup software like Acronis..you can back any files you want, or, the whole computer with installed programs, operating system and all. Are you using WD software, or windows? You can just select the files you want to copy from the drive in Windows, and just copy them to the drive, you don't have to use WD software.
If this post has helped, please vote.
Jun 15, 2010 | Western Digital My Passport Essential...
I bought a new WD Elements 350gb external hard drive and it came with a Memeo software CD. It says to insert CD before starting backup. I do not appear to be able to use this external hard drive as a plug...
This software is not linked with the drive (with this particular drive you only get a trial version anyway). Just remove the software from your PC.
Start > Control Panel > Add or Remove Programs > Remove Memeo/ WD Anywhere Backup.
Once you have done that, you can delete everything on it (assuming you never manually put something on it apart from the backup). If so, back it up onto your PC, another drive or CD.
Jan 25, 2010 | Western Digital Elements powered by WD 320...
My external backup will not back up and to use I need product number.Where can I find it?
The my book essential only comes with a trial version of Memeo / WD Anywhere Backup, which can only be used for 30-days. Your only option to use the backup software with the drive, is to purchase it. However, you could use another software or alternatively manually copy / paste your data over to the drive.
If it's any help, windows also has a built-in backup and restore function.
WinXP - C:\WINDOWS\system32\ntbackup
Vista - Start > In the search bar, type: Backup. Open the executable.
Win 7 - Open my cumputer > right-click on your C-drive > select properties > select the 'tools' tab and select 'backup now'
Jan 16, 2010 | Western Digital 320GB MyBook External USB...
How can I back up my data on my book essential?
This drive comes with Memeo / WD Anywhere Backup, so you could most like just install it on your PC and when it asks for the destination, guide it to the my book essential in my computer.
For step by step, use the link below (BTW: the product key is normall on the install guide, but most of the time, if you have your drive connected, it will detect it and auto-register without the need of a product key):
http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=3530&p_created=1238718201&p_sid=_Tgc12Tj&p_accessibility=0&p_redirect=&p_srch=1&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9Mzg1LDM4NSZwX3Byb2RzPSZwX2NhdHM9JnBfcHY9JnBfY3Y9JnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9aG93IHRvIHNldHVwIHdkIGFueXdoZXJlIGJhY2t1cA!!&p_li=&p_topview=1
If you do not want to use the backup software, then copy / paste your data onto the drive.
Jan 15, 2010 | Western Digital My Book Home 320GB...
Formatted (on PC) 1TB WD hard drive cannot be altered on Macbook
What OS are you running? What is it formatted as FAT32 or NTFS and how big are the partitions. Various operating systems, hardware and formatting schemes have different limitations. If you want to use the drive in Leopard formatted with NTFS which is the only way to create partitions larger than 20 or 30 GB you may need to install an NTFS file system driver like FUSE.
The other option is to format it as HFS and install Macdrive 7 in Windows to use Mac formatted drives in Windows.
Hope this helps.
Dec 27, 2008 | Western Digital 250GB MyBook External USB...
Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive Logo
620 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
