Question about Dryers
LITHONIA TH 400M TB HSG
What wires do i use to hook up to 110 volts
2 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: I need to use a 220 volt battery charger on a 110
Why not just get a meter pole with a 220 outlet installed near your parking space?
Posted on Mar 06, 2010
How to hook up electrical? 220v single phase? What color wires on which connections of the plug?
Identify the prongs. If you have wired a 110-volt fixture or plug, then you are aware that the different prongs connect to different colors of wires. The same principle holds true for 220-volt plugs, and this is very important to keep from tripping the circuit breaker. A three-prong plug will connect to two colored wires that each supply 110 volts and a bare copper wire which is the ground. One of these colored wires will be black, while the other one should be red, white, or blue. The four-prong plugs connect to a black and a red wire that each supply 110 volts, a white neutral wire, and a bare copper ground wire.
Read more : http://www.ehow.com/how_6830969_wire-220_volt-ac-plug.html
How to Wire 220 Volt AC Plug eHow
Dec 16, 2015 | Ovens
Wiring
see side of motor it will show you wires to move then hook up for 120 volt
Jul 25, 2013 | Pentair Whisperflo 3/4 Hp 115/230v
Proper wire hook up
black goes to L1 white goes to L2 make sure to look on side of motor to change from 220 volt to 110 volt either a knob or changing wires brown and white to different locations hope you didnt fry motor
Jul 26, 2013 | AO Smith 1.5 hp 3450rpm 48Y Frame 115/230...
Have a maytag dryer with no directions. My cord has black, red, white and green wires - the green was screwed to the outside of the old dryer. This dryer has blue, red, and a white with green - the green...
Hi lasanaritchi...
The blue and red will be your two 110 volt lines (2 X 110 volts equals 220 volt) and the white one will be the neutral, green wire will be ground
Go to this link and see a picture of how to hook up your dryeer cord...
Please take time to rate me.
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Jul 24, 2011 | Dryers
I have 240 timer switch and I wana use it for 120 ? How can I do that?
if the switch is rated for 240, then hook up the same way but use the 110 black and white wire for 110 volts to switch, instead of the red and black wire for 240 . on 110 black wire is always hot and the white is the neutral wire. the best wire to use is 12/2 with ground.
Jun 20, 2011 | Water Heaters
Maytag model MDE7057AYW 5600 Watts dryer runs ,but
5600 watts will not operate off 120 volts.
This is a 220/240 volt hookup.
There are 2 legs of 120 volts each that operate the dryer.
The only part requiring 220v is the heater.
Otherwise 120v routes through the various controls and relays.
Mar 12, 2009 | Maytag Dryers
COOK TOP WIRING
 You have Red and Black HOT wires and a Green Neutral - That is 220 volts. From the wall - Black is Normally HOT and White is Neutral. That is 110 volts. If that is a typical household outlet, is will only supply a demand at about 15 amps while running at 110 volts. Your Cooktop will most likely demand somewhere around 50 amps at 220 volts. - Short Answer - You will need to have a 220 volt supply line ran to the cooktop from the breaker. Easy to do but dangerous if you are unfamiliar with high voltage.
Apr 30, 2008 | Jenn-Air JED8430 Electric Cooktop
Wiring a stove
If there is no 220 outlet in the location where you're planning to put the stove then you need to run wiring to the new location. There are two seperate phases of 110 volts coming to your home. The voltage between each of these phases and the neutral wire is 110 volts. When your house was wired only 1 of the 110 volt signals was run to your 110 volt outlets. In order to create a 220 volt outlet you need both of the 110 volt signals run to the outlet.
If you have a straight shot between your breaker box and the location where you need the 220 volt outlet then this is not too big a deal. If you have finished ceilings and walls inbetween then this will be much more difficult.
If you're not comfortable with electrical wiring this would be a good time to call a licensed electrician.
Nov 18, 2007 | Ovens
Wiring thermostat
a standard propane regulator should work. check on the required pressure for the unit and get a compatible regulator. try grainger supply. thermostat connections are usually 24 volt two wire, opens on temperature rise. connections on the burner relay are indicated TH-TH.
Nov 11, 2007 | Mr. Heater MHU45LP
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
