Question about kawasaki Garden
How to roll up the tension coil for the pull string
Having problems with the 3-speed pull string it doesn't seem to work after installation?
Remove the recoil pull starter rope surrounded by 3 or 4 hold down screws depending on your make then you wind up the coil starter pulley about 5 turns counter clockwise hold it there you feel a tension as you go abouts turning. Which is what you want to do. Once you reach 5 turns hold it do not let go,with one hand and with the other hand take a vise grips and clamp down the rope so that you don't lose your tension install your pull cord handle,take out the vise grips , then you release your cord pull starter rope..
Jan 09, 2018 | Garden
Good morning,I have a homelite super2 chainsaw,the pull string doesn't roll back after pulling it to start... what can be wrong and how do i repair it. thank you.
recoil spring or internal movement worn
ask you chain saw repairer/ part supplier
you might be able to get a used off the shelf bolt on replacement or have to pull yours apart
by the pictures
not an easy pull apart repair
new coil spring can let go while refitting it
recoil rope holder is plastic and set into the side casing
looks like you have to undo that side casing of the saw including the rolled hold handle
index-00nkgcv3qozdkgxfkoitxhz4-2-0_0.jpg44-00nkgcv3qozdkgxfkoitxhz4-2-2.jpg33-00nkgcv3qozdkgxfkoitxhz4-2-3.jpg
Mar 07, 2017 | Homelite Garden
Pull string
you might have you coil set to close to the flywheel and the coil is not letting the flywheel spin like it is suposto sotheir for you string id to tin\ght when you hace the hood on so reagap the coil and sett it a little farther back from the flywheel by not to far back
May 14, 2013 | Mtd 22" Yard Machine Push Mower
I have a stihl fs 80, the starter cord will not retract after the first pull. The spring is still intacted but doesn't spring back when re-attached to weed eater.
One of 2 things come 2 mind, if the spring is still in tact it could be that the retract line might be slightly to long and forces the spring to over travel and lock up against itself. A simple test would be to pull the pull start to only 80%. If at 80% it retracts normally then shorten the pull string by a few centimeters . alternatively the spring may be over tensioned by a turn or two. to release pull the string out with the pull starter off the machine to about halfway, hold down the recoil to release the tension off the string and pull the string out towards you through the slot provided on the face of the recoil into a loop. Gently let the recoil slip one full turn at a time until there is just enough tension to pull the handle all the way back. if its too loose just revers the process one turn at a time. its not complicated, to do but can be tricky,
if DIY is not your thing, refer to someone better qualified,
Sep 05, 2012 | Garden
I just got this guitar. I pull the tuner control, strum the string and after the guitar tune itself, the G string still out of tune??
Are you sure you are struming the G string at the right point? One might be able to fool the tuner by triggering a harmonic on the strings or being too aggressive in the strum.
I would pull the peg and see if the string CAN be tuned manually. It is possible the G string is bad or somebody put the wrong string on there.
Remember that strings can be within about 10% of the breaking tension when in tune.
Also it appears that the thing can detune itself to nearby keys. Make sure you have the dial set correct when you pull it out to tune.
Feb 05, 2010 | Gibson Robot SG Special LTD Ebony
Had to replace E string on Baby Z. Having difficulty getting the string on guitar to wind Any assistance would be great!
Normally you leave string slack enough at the start so you can get 3 or 4 winds before it is at tension.
While winding, pull string sideways to keep gentle tension on the string.
They have cranks to speed up the winding process you caanbuy that are inexpensive.
Here is an excellent video of how to:
http://www.ehow.com/video_4396928_replace-strings-acoustic-guitar.html
Dec 28, 2009 | Dean Guitars Dean Baby Z Electric Guitar...
The string under the fabric bunches up until its in a big tangle and I have to ripe the fabric out from underthe needle and cut all this bunched up string from machine and fabric
Make sure bobbin is placed correctly and has tension. Make sure your getting tension from upper tension when putting pressure foot down, pull thread to make sure there is tension present and set tension to 4
Dec 03, 2009 | Husqvarna Viking 1
Rob poulan leaf blower how to rewind pull string
I invert and secure the starter housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so i tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension to retract properly.
If you're lucky you can pull the cord out enough for a pretension then slightly raise and add the withdrawn cord to the spool.
Both methods require about 2 turns of pretension to rewind the cord when pulled. HTH
Lou
Sep 05, 2009 | Poulan Garden
Bridge problem
There are different tension strings available. Contact your guitar store to find the right weight strings for your guitar as a first step.
Aug 02, 2009 | Fender Classic '50s Stratocaster Electric...
On my lettera 22 the string that returns the carriage came off,and I would like to know how to re-connect it. Somehow it winds around a round case with a spring in it. Every time you press a key the...
You can buy a roll of fishing line and make a draw string to match it. Cut a piece off about 14 inch.Tie a knot in one end and a small loop in the other. Hook the loop to the right side and pull it to the left under the carriage. Now wind the mainspring up to about five or six turns and push the small know into the slot. Carefully unwind until string is taught.
Jun 21, 2009 | Olivetti Lettera 35 L Typewriter
Garden Logo
35 people viewed this question
Top kawasaki Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
Phil Walker
Phil Walker
Are you a kawasaki Garden Expert? Answer questions, earn points and help others
