Question about Samsung Washing Machines
I have replaced the pcb of my samsung fully automatic washing machine. when i start the machine it only drain the water nothing else work. please tell me is this the pcb prob or something else
Samsung washing machine model wa78k1 top load
heatman101
  • 43501 Answers
SOURCE: water not getting held in the tub
The fix for this is very simple. But you are not alone here this is a common problem that I need to write a tip about...
If the water is going right through then either one of two things is happening. Either the hose is not going up high enough before it goes back down into the pipe, or the hose end is stuck into the water in the pipe and the result is that the water then can siphon out.
First thing to check is that the hose is going up to a point at least as high as the top of your washing machine before it turns and goes back down into the washer.
Next, check that the water level in the pipe is not backed up so that the end of the pipe is in the water. There needs to be an air gap so that you break the vacuum on the hose after the washing machine is done pumping out. If this does not happen the water going in will just get siphoned roght out again...
Checking these two things will solve your problem and you will be happy and washing again!!
Also check out this tip that I wrote on washing machine maintenance..
Washing Machine Maintenance
http://www.fixya.com/support/r4312694-washing_machine_maintenance
heatman101
Posted on May 05, 2010
  • 113 Answers
SOURCE: Hi Unable to drain the water
You can take the hose that goes to the drain and lay it down. but when you do that the water will run out the hose so make sure it goes outside or into a floor drain. You pump is either jammed or broken or the solenoid that turns it on is out.
Posted on Sep 22, 2010
  • 298 Answers
SOURCE: dear sir, I bought top loading fully automatic
you can contact appliancerepairplanet.vstore.ca for help in this matter
Posted on Dec 08, 2010
thunderz
  • 232 Answers
SOURCE: Mine is a top loading
Sounds like the timer which is probly computorized in that model, If it is still under a service plan you should check and see,, Always buy one with no fancy plastic buttons, get one with turn knobs, the new stuff is money for repairs all the time. How old is this machine?
Posted on Mar 07, 2011
caroldon
  • 17130 Answers
SOURCE: I purchased a new washing
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there is gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Posted on Jul 02, 2011
Machine will not spin or drain
good day?
fully automatic machine? washing cycle is normal?
if yes, do the same.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, if clog your drain pump of some hair pins,cotton buds or coins or any small item,that the cause of water stuck,and it will long time draining or totally not running the drain pump.and its cause of stop of cycle of washing machine in rinse time or spin time,because after washing the pump must be on to remove water before start the next cycle.
Nov 02, 2013 | Whirlpool Washing Machines
Holding water
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 02, 2013 | Washing Machines
Washer won't spin
Good Day,
Avanti washer repair
Good Day,
Nov 01, 2013 | Washing Machines
Machine lacked about 23 minutes in cycle, it stopped with lights flashing. It will not drain, therefore cannot spin. It just beeps whenbi try to start it again.
Good Day,
Nov 01, 2013 | Whirlpool Cabrio Washing Machines
Machine stopped in mid cycle with the drain/unlocking light on. No error codes. Machine goes directly to the drain/unlocking position after start. Will not fill, spin, operate. Any ideas?
Good Day,
Nov 01, 2013 | Whirlpool WFC7500VW Washer
My Zanussi WJD 1257 washer/dryer's drying cycle has started finishing early. No error codes. The wash cycle works fine but the drying cycle is simply stopping prematurely. You can set it to dry for 45...
Good Day,
Nov 01, 2013 | Zanussi Washing Machines
Won't drain and showing F 01
Good Day,
Oct 31, 2013 | Maytag EPIC MFW9700S Front Load Washer
My Beko 81241 LW seems to be stuck in the Spin & Drain cycle (it's not actually on though) and the Start symbol is flashing. The time is also displayed (12mins). The door is also locked. Holding the Start...
Good Day,
Oct 30, 2013 | Beko Washing Machines
Water supply hose(cold) blocker dont work
i am sameer from india... i want whirlpool fully automatic washing machine pcb circuit diagram
Jul 28, 2010 | Samsung Washing Machines
Washing Machines Logo
35 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
