Question about Dishwashers
How to clear a delonghi dishwasher error code 4
I need to clear a delonghi dishwaher error code 4. I have emptied the dishwasher and cleared the excess water from the dishwasher. Can this be fixed without calling for a service repair? There is no model number on the dishwasher and I have searched the DeLonghi website for a manual but it does not tell you how to clear the error.
  • 1 more comment
  • Anonymous Mar 30, 2009
    On the first use of the new delonghi dishwahser error code E4 came up. The dishwasher will not operate. Delonghi told me to checj the dishwasher was level - I have checked and it is. They had no advcie about what to do next - other than to call for a servcie.
  • Anonymous Apr 29, 2009
    I HAVE THE SAME PROBLEM ERROR 4, HOW TO I GET MY DISHWASHER GOING ???????????
  • Anonymous Mar 19, 2014
    dw67w service manual
Try removing all dish trays and salt softner lid, check if the salt softner compartment is full of water, if so place the machine on its side and allow all the water to drain from the compartment, once this is done your machine should be good to go. This is how i resolved my problem. The salt softner is located next to the water drain filter.
Posted on Apr 18, 2010
Delonghi Dishwasher
Can you please tell us the exact model of your dishwasher? What you can try initially is unplug the power cable of your unit for about 10 minutes, then plug it back in. See if that clears the error. Will give you follow up about the E1 error.
Oct 26, 2008 | LG 24 in. LDF 7811 Stainless Steel...
DeLonghi ceramic portable heater dch7093er model. PF error code. How do I clear
If The PF shows and emits a beep then the temperature sensor is malfunctioning. If the problem continues then call customer service at 1-800-332-3848. When you unplug unit the code should clear if not then there is a problem with unit. DO NOT try to keep running unit this could cause a fire.
Mar 02, 2015 | DeLonghi Heating & Cooling
What does 2e mean on my Frigidaire dishwaher
Hello friend, thank you for your post!
I see you are having trouble with your Frigidaire dishwasher and you are receiving error code "2E". However, it appears "2E" is an invalid error code. May I have you model number please? Typically you can locate your serial tag on the inside wall on the left hand side. With this information I can better assist you with pinpointing the issue.
In the meantime, let's attempt resetting your range. You can do this by unplugging it or flipping the household circuit breaker to the off position for roughly ten minutes. This usually clears false error codes. -Matt
Sep 21, 2014 | Frigidaire Dishwashers
Error code 4
If the fat that youre talking about is one solid color it could be grease essential to the operation of the dishwasher. Otherwise it may be food matter and the like. If that's the case, clear this out by hand, reassesmble, and run an empty load and check for leaks. Also, clean your dishers a little better before putting in the washer.
Good Luck
Dec 05, 2013 | Dishwashers
L have error code E3 on delonghi dishwasher
We have discoverd xactly why and sorted this on the bottom righthand wall there is a small circular sensor which measures the water temp during the washcycle. If you cover that with a plate pan or chopping board it cannot detect when temp reaches 47 degrees c so gets stuck on 1hr 32 min in the 2hr cycle. Keep that sensor clear and it will stop.
Feb 17, 2012 | Dishwashers
I have an error code f4 on my whirlpool adp 8966 dishwasher can you tell me what it means please
F4 indicates draining failure.Your washer drain pump starts and after 4 minutes the OWI(optical water indicator) detects that mashine is 'not empty'
Posible mailfunction reasons:
The drain pump must be defective/blocked
The siphon would have got closed
The control board would have got damaged
OWI defective
Apr 04, 2010 | Whirlpool 24 in. ADP6940 Dishwasher
Error code al03
AL03 indicates a time out on drain fault. Either there is a restriction or blockage on the drain side of the appliance or on the pressure side.If the machine empties ok you need to locate the pressure switch, remove the thin tube and blow back into the sump to try and clear the restriction. If the machine isn't emptying or empties slowly you need to clear the restriction/blockage in the drain hose, pump or sump.
Apr 03, 2010 | Hotpoint Dishwashers
After a wash cycle my unit leaves a film on my glass'
first thing you need to do is purchase a bottle of dishwaser cleaner from your groc store in the diswasher detergent section red the instructions on the label add it to the cutlery tray in an empty dishwasher upside down remove the paper seal off the top of the lid do not remove the wax seal place the bottle upside down in your dishwasher turn on hot water tap and run till it is hot next turn on your washer set it to wasn and let it run a full cycle. when washer finishes open it up when it cools and fill rinse dispenser in door with a good quality rinse agent like jet dry close dispenser and when dishwaser is full of dirty dishes turn it on the jet dry will make your galsses come out crystal clear w no film and the dishwaher cleaner will help all your dishes come cleaner.Use the dishwasher cleaner aroun 4-6 wekks it cleans all the inside of the dishwasher and removes a lot of **** aND RESIDUE THAT ACCUMULATES IN DISHWASHERS OVER TIME
Dec 17, 2009 | Dishwashers
Dishwaher
Control Lock means that the entire dishwasher is locked, for child safety purposes.  It's normally cleared by holding the "No Heat Dry" button in for 4 seconds or more.  It is locked again by the same procedure -- holding the "No HEat Dry" button for 4 seconds (or more).
Jul 30, 2007 | Whirlpool 24 in. DU1100XTP Built-in...
Dishwashers Logo
3,457 people viewed this question
Top Dishwashers Experts
