Question about TallyGenicom 6312 Matrix Printer
I want pdf menual 6312 line printer
Service menual
    New Friend:
    Problem Solver:
  • 5 Answers
Can send email to attach pdf for tallygenicom 6312
Posted on Nov 30, 2013
2 Suggested Answers
  • 114 Answers
SOURCE: t6312
The problem coming from your logic card hammer bank cable . Need to be replace logic card and hammer bank cable.
Posted on Jul 18, 2010
Tallygenicom 6312 line printer online light is blue and fault light red both at the same time. the printer does not display anything on the screen.
Sounds like your Controller has failed. There are for kinds depending on graphics options.
Here is a link for the the standard controller. I can get you a part number for the other ones if you need it.
MRP provides IT Parts Product Supplies and Services
Dec 27, 2015 | TallyGenicom Office Equipment & Supplies
WHERE DO I GET RIBBONS FOR THIS UNIT
Contact Printronix in Irvine, Ca. Printronix took over Talley/Genicom and they support these printers.
Mar 13, 2014 | Genicom Tally 6312 632 Adp Lp1500 Network...
How to print pdf document in lipi 6306 printer
It depends on what you mean by printing a PDF.
You can not "Direct Print" PDF documents on the 6306, you will need to pass the document through an appropriate printer driver / filter depending on the operating system used.
Simply sending a PDF document to the printer will not work
If you are using Windows simply print the PDF from Adobe Acrobat using the appropriate Windows Printer driver. If you can print a Windows Test Page, you should be able to print a PDF document- The quality of the print may not be of laser printer standard- Remember this is a Line Dot Matrix printer
Apr 03, 2013 | Tally 6312 Matrix Printer
Telegenicom 6312 printer has a paper out problem
there is a sensor that check the paper its mey be broken or jamed
Nov 10, 2011 | Tally 6312 Matrix Printer
Sir, We have a Genicom 6312 L Line Printer. This printer is attached with UNIX (5.9) system. It was working fine till few days back. Recently we changed the Logic Card. After this the printer is not...
If the printer does not print from Unix via parallel interface, it may be nessesaey to set the BI-DIRECTIONAL setting within the Parallel interface settings to OFF.
Sep 21, 2011 | TallyGenicom 6312 Matrix Printer
The print job for the TallyGenicom 6312 is a coupon and has a barcode in it, and the barcode is not readable by the barcode reader. The printed barcode looks perfect. And, the barcode reader has no...
Try to adjust the "Bar" setting in the Graphics menu. Here you can specify the density of the barcode. I have seen the best results using the Medium setting.
Jul 12, 2010 | TallyGenicom 6312 Matrix Printer
T6312
May 19, 2010 | TallyGenicom 6312 Matrix Printer
Problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
Apr 20, 2010 | Tally T6218 Matrix Printer
NEW PLATEN FOR TALLYGENICOM 6312
I would recomend you ensure the printer has the latest firmware as the way the pritner deals with platen problems has changed. I belive the latest firmware version is version 4.0.
The platen can be calibrated with the Technical Access Menu.
The Technical Access Menu is enabled by holding down the LINE FEED and ENTER buttons for 5 to 6 seconds until the printer flashes up Tech Access On.
The menu path to the Platen Calibration is;
TEST>DIAG>CAL ENGINE>PLATEN, then follow the instruction on the display to remove the paper and ribbon etc
Jul 12, 2009 | TallyGenicom 6312 Matrix Printer
TallyGenicom 6312 Matrix Printer Logo
81 people viewed this question
Top TallyGenicom Office Equipment & Supplies Experts
Kolbrun...
none
Raj Patel
Are you a TallyGenicom Office Equipment and Supply Expert? Answer questions, earn points and help others
