Question about Tally 6312 Matrix Printer
Hammer volatge 2 fault error replace cable and logic card but problem not solved
    New Friend:
  • 3 Answers
Hello
Please Check Your Hammer Bank Cable Proper Both Side (Logic card And Hammer Bank Side)
If Your Cable Is Proper Than Your Hammer Bank Problem
So Please Replace Your Hammer Bank
Regards
Yogendra Sharma
Posted on Sep 19, 2013
What does HAMMER VOLTAGE 1 ERROR indicate?
There is a short on the hammer drive circuit. It can be caused by the
HammerBank
TALLYGEN 093524 HAMMERBANK T6306 Refurbished
The Main Logic, the link is for the standard one, but if you have a Graphics selection then you will need a different one.
TALLYGEN 086153 CONTROLLER KIT STANDARD T6306 Refurbished
And in rare cases the hammer bank cables, but you will normally see a break in the cable if that is the case.
May 26, 2014 | Tally 6306 Matrix Printer
Hammer bank fault in p500b printer
check your fan it is working fine or not otherwise logic card fault detection circuit having problem. low value resistance may open
Feb 28, 2014 | Printronix Office Equipment & Supplies
I've TallyGenicom 6312 It was printing and suddenly stopped and display the following error: Fault: Coil 26 and doesn't print anymore. Please help!
This error is is indicating the printer detects a problem with one of the coils which make up the hammer bank.
You can try checking for any obstructions in the printer, in particular check the ribbon shield is no bent or out of place and may short out any coils.
Further then this to identify the problem may involve disassembling the printer. Ensure the hammer bank alignment is not messed up or you will need to replace this!
Check the cables from the hammer bank to the logic board for any damage, check the cable makes good contact.
Further than this you may be able to test each of the coils with a multi meter to see if there is a fault with a coil, if there is it is likely the hammer bank will need to be replaced as it is not passable to service this in the field.
Mar 26, 2011 | TallyGenicom 6312 Matrix Printer
I GOT PROBLEM IN TALLY 6303.ERROR CODE IS HAMMER VOLTAGE 1 FAULT, CAN U HELP ME WHUCH IC OR CHIP FAULTY
It could be the problem with your Hammer bank/ Hammer bank cable or MLC, Some cases dusty hammer bank .
Sep 25, 2010 | Tally 6306 Matrix Printer
T6312
The problem coming from your logic card hammer bank cable . Need to be replace logic card and hammer bank cable.
May 19, 2010 | TallyGenicom 6312 Matrix Printer
How I can solve hummer voltage 1
You must check the adjustment of your AVR and the Machine Voltage Switch.
Feb 15, 2010 | TallyGenicom 6306 Matrix Printer
The 6306 L showing HAMMER VOLTAGE 1 ERROR WHAT SHOULD I DO
ERROR IS BECAUSE OF DRIVER IC FAULTY IN LOGIC CARD
PLZ CHANGE THE HAMMER DRIVER IC IN LOGIC CARD
Dec 13, 2009 | Tally 6306 Matrix Printer
My IBM 6400 comes up with the error 086 Controller 15V fault on power up and therefore fails to get to the 'ready' state. Please advise on diagnosis of fault
The manual recommends replacing the hammer bank logic cable even if there is no damage to cable seen. You might do the cable shorts test recommended on page 263 of service manual
Oct 13, 2009 | IBM 6400 Matrix Printer
15 Volt CTL fail
Hi Serap,
If a fault condition occurs in the printer, the status indicator on the control panel flashes on and off, and the message display indicates the specific fault.
For the operator-correctable faults, After correcting the displayed fault, press the CLEAR key to clear the error message and status indicator and resume printing. If the fault message reappears, contact your authorized service representative.
If a fault is not correctable by the operator, you may try two steps to clear the fault before calling your authorized service representative:
1. Set the printer power switch to O (Off), wait 15 seconds, then turn the printer on again. Run your print job again. If the message does not appear, it was a false indication and no further attention is required.
2. If the message reappears, press the CLEAR key. If the message disappears, it was a false indication and no further attention is required. If the message reappears, call your authorized service representative at 1-800-243-3338.
Message Explanation Action 15V CTL FAIL* Controller voltage failure. Contact authorized service representative.
Call 1-800-243-3338
As far as software for the flash file is concerned , I have checked with their officaial sites , but they donot have any firmware updates.
Thanks
Mar 27, 2009 | Printronix Line Matrix P5010 Printer
Showing hammer voltage 2 error
the problem comming from logic board. need to change the logic board and hammer bank cable at the same time.
Apr 05, 2008 | Tally T6218 Matrix Printer
Tally 6312 Matrix Printer Logo
65 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
