Question about Polaroid i1035 Digital Camera
Date & Time will not stay current
I was give the Polaroid i1035 as a 2008 christmas gift. I am having to set the date and time over when the camera is cut off then back on again. Also, the digital time is not progressing hourly. Can some one please help.
  • 2 more comments
  • edean64 Jan 16, 2009
    same problem here with the date
  • bakere19 Feb 21, 2009
    This happens to me as well. Every time the camera is shut off it changes the date to 1/1/1970 and Windows thinks the date is 1/1/2098. They need to issue an firmware update NOW.
  • Anonymous Feb 26, 2009
    Same to me
  • rfrat Mar 05, 2009
    I am having same problem with time and date holding when camera is turned off and back on again.
Same thing happened to me too! lol. However after you press the menu button and click "default setting", go set your date and time again. Then turn the camera off. Turn it back on and you will find that the date/time is correct!
Posted on Apr 11, 2009
How do I set the time date stamp
• Setting Date & Time Use the Date & Time function to set the date and time of your camera. This function is useful attaching date stamps on captured images. Your camera uses a 12-hour time format. 1. Press the navigation controls to adjust date and time value. By holding down the up arrow or down arrow keys, the numeric values change continuously. 2. Press OK to apply changes.
or you can get help from manual here
https://images-na.ssl-images-amazon.com/images/G/01/00/00/10/67/62/13/1067621330.pdf
at page 73
Good Luck
Jan 09, 2011 | Polaroid i1437 Digital Camera
How to change date and time for Polaroid i531
Press the menu button, scroll sideways (press lightening icon) to Setup (tools icon), then down (disp) to highlight date and time. Press Set or the lightening icon to select the date and time setting, then press disp or the opposite upper part of the rocker to change the numbers, and the lightening or flower to move between the various date and time settings. Press Set when you are through.
If you leave the battery out of the camera for 48 hours, you will be invited to set the date and time at the next switch on.
You can download a manual for a similar camera, the i1036, at polaroid.com, but there does not seem to be a manual for this specific camera there. Try THIS LINK
Dec 05, 2010 | Polaroid i531 Digital Camera
In polaroid pdc 5080 digital camera no longer save the date.my camera doesn't save the date .every time when i start camera its ask to set the date first.
I have that problem with my camera too but after a while... I gave up retype-ing the date and time, so know every picture is on Jan.1st 2004 at 00:00:00 :D I have tried as many things as I could TO fix it but.. nothing came through...
Jun 18, 2010 | Polaroid PDC 5080 Digital Camera
The date and time will not stay after setting, is there a flash update?
This is a firmware glitch. If you disable the startup image, the date and time is not saved. To fix this issue, you must re-enable the startup image.
Turn on the camera and press Menu (M). Press the right side of the circular directional button to select the wrench. Press OK/Edit.
Next, navigate down to "Opening" and press OK/Edit. Select ON and press OK/Edit. Go back up to Date/Time and set the date.
Restart the camera to see if it works.
Jan 19, 2010 | Polaroid i1035 Digital Camera
Polaroid a520 will not keep the date
You may want to set the factory defaults by going into the main maenu.
Nov 22, 2009 | Polaroid a520M Digital Camera
How do i set the date on my polaroid i735
This is straight from the "Polariod i735" Manual.
"• Setting Date/Time, Display On/Off
Date and time can be displayed on the picture by the following steps:
1. Set the camera to Still Image mode.
2. Press the button.
3. Press or button to select (Date Stamp).
Date StampOffDateDate & Time
4. Press and button to select the desired setting."
For the full PDF manual go here:http://www.google.com/search?q=polaroid+i735&rls=com.microsoft:en-us:IE-SearchBox&ie=UTF-8&oe=UTF-8&sourceid=ie7&rlz=1I7ACEW_enUS345US345
Hope this helps!
Sep 29, 2009 | Polaroid Cameras
Setting Date/Time on Polaroid a530
I contacted Polaroid help desk and they were clueless. They said there is no way to set the time after messing around with the camera for 10 minutes.
When you pull the photos off the camera it does record a date and time. I believe they forgot to add the option in the setup menu so you cannot get to it. I asked for them to send me a differant camera and the help desk rep laughed.
I guess thats what I get for buying a cheap camera.
Sep 12, 2009 | Polaroid A530 Digital Camera
Date and time removed
it better to take the master batterys in the cam
Mar 27, 2009 | Polaroid T830 Digital Camera
Can't get the Date off the Pictures
First you have to go to the set up menu and set the correct time and date, then you can go back to the settings and select OFF for time and date. If you do not set the correct time and date , that default date stays in the picture.
Jan 21, 2009 | Polaroid i830 Digital Camera
Time & date reset
Very often the date/time is maintained by a very small watch type battery built into the main board - there is no opportunity to replace this.
Dec 29, 2007 | SVP DC-12D Digital Camera
Polaroid i1035 Digital Camera Logo
336 people viewed this question
Top Polaroid Cameras Experts
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
